GRUNDIG CUC 2030 DUMP
TV - EPROM
1.8 KB
EPROM
    GRUNDIG CUC 2030
GRUNDIG CUC 7303 TV T51-830/4 text Függőleges hiba
Sziasztok! Csatoltam a tvröl egy képet ez a helyzet: de elöször csak középen volt egy vékony csík ,smiután függ ic-t cseréltem 100mikrós kondival együtt,ez lett a következö szituáció,amit a kép ábrázol! Amugy 25 voltot megkapja az ic csak a kimenetén az 5 ös lábon 2.5 voltot mérek nem többet! Végignéztem már a szokásos dolgokat amiket ilyenkor illik kondik ellenállatok stb.. Mondjuk az a zéner dioda nincs benne ami az ic mellett van közvetlenül.. Valami tipp?
Grundig CUC120 - Super Color A 7100 - CRT TV - Screen - Cinesc. is black
UPDATE: Note: This Model and CUC220, CUC720 almost identical My family b. this TV in 80' And worked ~15 years In 90' Black screen ... with Pot. in 100% Brightness, Contrast. In the end 90' puff doesn't work at all. Someone try repair but ... the same black screen. They reported ... try fix and get > Brightness In past 6 months, I repaired and new life come from the set, but now we get too much Brightness In your opinion ... the person try Adjust ... fix what? ABL - Automatic Brightness Limiter setup, regul.? R2533 R2538? Thank you for your comments, info. Ruy Please your comments: Brightness and Colour Pot. -> OK But Contrast Pot.: I can' rise ... NO FOCUS and washed out -> I only see a Blank RASTER. Best Regards, Ruy
__________________________________________________________________________________ ORIGINAL / PAST MSG Hi,
Super Color A 7100
The other sub-models in pag.1 - pdf
right bottom
elektrotanya.com/grundig_cuc120.pdf/download.html
The screen is black ... and we notice from time to time (when the image is very brig.) some small part of image.
Very few dots.
I tested the G1 2X V, G2 5XX V, Heather - G and J Volts in the neck of Cinesc.
Power Supply I tested +A 115 V, +C 200 V , +B 12V, +M 19V
In Pag. 6 - SSB and SB?         T2533
Thank you,
Ruy __________________________________________________________________________ Work with servers - OpenBSD, NetBSD, FreeBSD, Linux. Love Oscilloscope :-) , Repair, Satellite Dish, Multimeters. Have a Big Satellite Dish farm.
Grundig STF55-1001/7 TXT : szin es sor hiba
Szerencses napot minden tanyazonak. Remenykedek hogy a ti segitsegetekkel nekem is szerencses nap lessz a mai. A fent emlitett keszuleknek a kovetkezo problemaja van ; bekapcsolas utan ,rangatja a kepet es szakadozik a hang is + nincs szin, es par masodperc utan hejre all a sor meghajtas es a hangis, de szin tovabra se jon meg. A yungel stv8216 SMD valtozat, 8v,3,3v,125v rendbe ,a jungel hutesre melegitesre nem valtozik.Kerem a kolegakat segitsenek egy ket tanaccsal ha tudnak Elore is koszonom
Grundig 40VLE8041 S chassis:SX dump keresés/Megoldva
A fenti gépbe keresnék tartalmat,és hogy melyik memóriát kell átirni,mert kettő is van benne.
Stand-by ból se ébred,a led pedig halványul.
A pendrive-os frissités igy nem lehetséges.
A kijelző LTA400HF16 talán C01
Köszönöm.
A megoldás lejjebb.
Köszönöm.
