HISENSE TN-2188AD-1-
TV - EPROM
490.0byte
EPROM
Looking for similar hisense manual?
    HISENSE TN2188AD1 TN 2188 AD 2188AD
Hisense Main Board RSAG7.820.12363
Hello, does anybody has a hint for me and/or schematic for the Hisense RSAG7.820.12363 mainboard?
Issue TV : no startup, from standby,  red led TV flashes continuously, remote checked, no component, connector, solder joint  seems visual defect, no hot spot with IR camera, guess power supply or safty circuit defect.
br markus
Hisense LCD3201EU
Tisztelt Kollégák! Hisense LCD3201EU Gépkönyvet, kapcsolási rajzot keresek a fenti LCD TV javításához. Bármilyen javítási tapasztalatnak, információnak, tanácsnak örülnék. A hibajelenség elég kusza: rövid, bizonytalan működés után lefagyás. Az általános dolgokat már nézegettem. Köszönöm a segítséget! BigTom
Hisense H60N5705 automatically switches off
Dear all,
this TV, Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
The problem started to occur suddenly, during a video conference. It was switched on with the remote control, continued to work for a while and then switched off again.
The room technician changed the power cable (?), the HDMI cable (??) but the problem of course remained.
I asked if it changes anything by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60’ which is not easy to handle) to the lab and asked me to check it.
I still have to open it up, but I don't have the schematic diagrams and should proceed by trial and error, although I imagine a problem with the power supply stage.
How do you suggest I proceed, since I don't do TV but RF ?
Thank you for any help,
Best
Maximus
Hisense LCD 3203EU nem áll meg csatornakeresésnél
Sziasztok! Segítség kellene!Egy cimborám szólt,hogy a fent nevezett tv-je furán viselkedik.Bár már nem igazán dolgozom a szakmámban és LCD-hez pedig semmi tapasztalatom mégis a hiba elmondása alapján talán eeprom vagy opció probléma lehet.Azt mondta először nem állt meg csatornakereséskor nem tudja beállítani a csatornákat és most pedig a távirányítóra sem reagál (a távszi jó )mindha kizárta volna magát a tv-ből???!Esetleg valakinek volt már ilyen tv-vel hasonló tapasztalata vagy ötlete ? Előre is köszi :help:
