KENWOOD DP-R5080 R6080 R8080V.
1.1 MB
    KENWOOD DPR-5080 DPR5080 R6080 R8080V. DPR 5080 6080 8080 V. DP R5080 DP-R5080
KENWOOD KRF-V 5030 TÁVIRÁNYÍTÓ HIBA / MEGODLVA /
Kérdezni szeretnék ! A fenti készülék és a hozzátartozó DVD nem reagál a távirányítóra. A távirányító oszcilloszkóppal vizsgálva az infra led kimenő jelét infra vevővel rendesen küldi a jelcsomagot, a rezonátor 3,64 MHz a rajta mért freki gombnyomáskor - 3,61 Mhz. Mivel sem a hozzátartozó DVD lejátszót sem a Recievert nem működteti gondolom a távirányító lehet ludas. Ha van tapasztalatot szívesen várom segítségeteket. előre is Köszönöm!
Kenwood KA-V9500 Service Manual
Hello,
I am working on a Kenwood KA-V9500
and I am looking for a Service Manual.
Any info is greatly appreciated. smiley
Thanks,
Dan
Kenwood KT1060 tuner
Keresem a KT1060 tuner kapcsolási rajzát, kérem aki tud segítsen. Üdvözlettel: Feri
Request for Firmware or Help – Kenwood M-9000 SS stuck on "Waiting for PC Wizard"
Hello,
I recently purchased a used Kenwood M-9000 SS micro Hi-Fi system, but unfortunately, the unit is not functioning correctly. When I power it on, the display is stuck on the message "Waiting for PC Wizard", and the device becomes completely unresponsive – it does not react to any buttons or remote control inputs.
From my research, it seems that this issue may be caused by a missing or corrupted firmware, particularly related to the Sunplus SPHE8202 chipset used inside the device.
I have been trying to locate the correct firmware file (possibly DVDROM.BIN) that matches the hardware (the board ID may be BD305890BB9B50), but so far, I have had no luck finding a working download source.
Could someone please help me with:
  • The correct firmware file for this model
  • Instructions or guidance on how to recover the system using a USB flash drive
  • Any experience with solving this "Waiting for PC Wizard" message on similar Sunplus-based systems
Any help or direction would be greatly appreciated!
Thank you in advance.
Best regards,
Dejan Todorović
