Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdvözlet.Új Mazda 6 TE tip.A forgalmazó szerint M-02 és Pioneer a rádió tipusa.Szerelt valaki vagy ismeri ezta tipust? Lehet-e bővíteni, van e kimenet rajta? segítséget előre is köszönöm. Öreg Tom.
Üdv mindenkinek.
hozzám került egy nem mai Pálfi audio féle mosfetes erősitő.
az egyik oldal "fele" (4 végpanel van benne) nagyon melegszik..szabályosan süt kb fél peren belül..
nagyon házi készitésűnek tűnik..
nem nagyon ismerem ezt a szerkezetet..valaki tudna adni infót..doksit..rajzot esetleg róla?
Köszi. Üdv.LF
Bár már volt régesrégen egy hasonló topic, de az le van zárva így nyitottam egy újat.
A beteg egy a címben jelzett szalagos magnó. Tünetek: Gyorscsévélésnél előre nagyon lazára tekeri az orsót, így ha pl. félig beletekerek egy orsóba (mindegy hogy kicsi vagy nagy) és utána lejátszásba rakom, akkor meg is rándul többször is az orsó, azaz "összehúzza" a lazán feltekert szalagot. Ugyanez van visszafele tekercselésnél is, de ott talán nem annyira laza a szalag. Lejátszáskor viszont semmi gond. Így ha végigjátszok egy szalagot (akár olyat is ami lazán volt felcsévélve), a végére érve szépen szorosan fekszik a szalag az orsón. Amit még megigyeltem hogy a feszítőkar jobb oldalt lejátszáskor majdnem teljesen fennt áll, azaz jó feszes (lehet úlságosan is), viszont sosem lengedezik, szépen stabilan áll a helyén. Lejátszáskor nem nyávog, szépen stabilan lejátsza az anyagot. Egyedül a csévélés a gond.
Néha olyat is csinál hogy csévéléskor egy idő után belassul a tekerés, vagy lejátszás után nehezen akar megindulni. De ezt nem túl sűrűn produkálja.
A másik problémám a kimeneti hangerőszabályozó poti (bal oldalon ami van). Ez keményen kontakthibás, a bal oldal recseg, de nagyon. A kérdés hogy mezei (azaz kapható) típus van benne, vagy valami speckó fajta (még nem szedtem szét a masinát).
Szeretném én magam megcsinálni a gépemet (a ti segítségetekkel), mert így legalább meg is ismerem közelebbről. ;)
Köszi
Laci
