KNIGHT MODELS 93SZ508 93SZ741 SM
6.7 MB
Looking for similar knight manual?
KNIGHT MODELS 93SZ508 93SZ741 SM service manual (1st page)
Preview of KNIGHT MODELS 93SZ508 93SZ741 SM [1st page]
KNIGHT MODELS 93SZ508 93SZ741 SM service manual (2nd page)
Preview of KNIGHT MODELS 93SZ508 93SZ741 SM [2nd page]
    KNIGHT MODELS 93SZ508 93SZ741 93 SZ 508 741
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
iEast AMP160 V20 egyik csatorna nem szól
Sziasztok! Adott egy iEast erősítő, aminek az egyik oldala nem szól… Ezt a jelenséget gondoltam egy kondenzátor okozhatja, ami konkrétan szinte szénné égett… Nem tudom mitől… Ez pótolva lett szépen, de valahogy most sem szól a csatorna. Esetleg valakinek volt hasonló problémája??
BOSE QC35 bluetooth fejhallgató
Üdvözletem!
Kérdezem, tudja-e valaki, hogy ebben a fülesben hány akku van, oldalanként egy-egy, vagy csak egy?
Köszönettel gtamas
Hitachi D-45s Retro deck Megoldódott !
Szép napot az Uraknak! Megint csak segítséget kérnék, szokásomhoz hűen. A fent nevezett készüléket most sikerült "beújítanom". Külsőleg szép állapotú, és szerintem nem sokat használhatták a fejekből és a gombokból ítélve. Már nagyon hiányzott a polcról ? ! A többi kütyüm mellől, de van vele egy kis gondom: A szíjak "eltűntek" belőle. Azt szeretném kérdezni, tudja-e valaki a méretüket? Azt is megköszönném, ha esetleg valaki egy képet, rajzot, vagy akár skiccet is tudna küldeni a helyüket illetően. Bízom a társaságban, hogy valaki esetleg látott már ilyet ! :help:
