KT1025ABLUETOOTH AUDIO CHIP DATASHEET V1.0
DATASHEET - OTHER
265.6 KB
DATASHEET
Looking for similar kt manual?
KT1025ABLUETOOTH AUDIO CHIP DATASHEET V1.0 service manual (1st page)
Preview of KT1025ABLUETOOTH AUDIO CHIP DATASHEET V1.0 [1st page]
KT1025ABLUETOOTH AUDIO CHIP DATASHEET V1.0 service manual (2nd page)
Preview of KT1025ABLUETOOTH AUDIO CHIP DATASHEET V1.0 [2nd page]
    AUDIO CHIP DATASHEET V-1.-0 V1.0 KT 1025 ABLUETOOTH
APC SMART-UPS 1000 táp, működik labortápról?
Hoztak egy ilyent akkuk nélkül kellene mennie labortápról, mert csak bekapcsol, és kb 5 sec múlva ki....
Elektromos bicikli töltők
Sziasztok,üdv itt lesz egy pár kínai töltő elektromos járműhöz biciklihez
Intech LH-5 Heater
Company no longer in business here in the US.
This is a product that heats up and dries wet ski boots,
the board powers 2 big heat guns I guess with programmed cycle
times. No SM or schematic of course.
Main bridge was shorted, seems directly fed from 115V line power.
Replaced the bridge with a thru hole type and hooked up with a variac to power.
 At one point the panel lit up with power, then there was a snap
and thought I saw sparks from the 2 large heat guns in the chassis,
then dead. Fuse blown - bridge shorted again.
Seems like they are using a IC on the boards
to handle the switching side of the SMPS, its a Viper35SP
made by St electronics:
http://www.st.com/content/ccc/resource/technical/document/datasheet/4b/ee/d2/34/15/48/4e/66/CD00144872.pdf/files/CD00144872.pdf/jcr:content/translations/en.CD00144872.pdf
Looks like its obsolete / NLA from what I can see so far. Some on Ebay for purchase.
I think the IC runs straight from the line power, rated at 800V.
Should I try the support components around the IC or try replacing the IC?
I am thinking the heat buildup perhaps caused the smd caps to dry out?
GJ8018 Kínai hőlégfúvó 24Voltos tápegység ic keresése./Megoldva átalakítással.
Tisztelt kollégák!
Segítséget kérnék a fenti hőlégfúvó táp ic ügyében.
Valaki tud -e segíteni milyen típusú lehet a rajzon látható táp ic?(IC1).
A szerviz menüben fenn van a készülék rajza, egy kedves tanya társunk jóvoltából de az a trafós tápos változat.
Az enyémben ic állítja elő a 24 Voltos tápot ami a motor és lcd tápot állítja elő. Természetesen a tokról lecsiszolták a feliratot.
Idáig a kereséseim nem hoztak eredményt, nem sikerült ilyen lábkiosztású táp ic -t találnom.
Ebben kérem segítségeteket. Hátha valakinek beugrik valami.
Mellékelem a kapcsolási rajzot.
Ha valaki tud segíteni, hogy ez a rajz is felkerüljön a tanyára, lehet másnak is segítséget jelenthet. Sajnos én nem tudom ezt megtenni.
Köszönöm !
Üdvözlettel, Galibali.
