hello to everyone!
i have this model LG. the problem is : i have sound on tv but white picture
this problem is everywhere tv,scart,hdmi and vga.i have checked all the voltage and its ok, i think maybe has got problem the ic100 (maybe has got resolder? i dont know) i want to help me if anyone has got an idea what is it or has the same problem and solved.
thank you very much for all.
Dear community,
Please help me solving my issue with my LG OLED55CX3LA TV.
I have this TV since 3 years, never had an issue, until last month, when It suddenly start to freeze. It stuck on white/ or in currently displayed picture, got some pitching noise, and 5-6 seconds later the TV shuts off by itself.
The solution so far is to restart it by the power button, or the power socket, within 10 seconds.
The problem occurs very rarely, sometimes early morning, sometimes 2 days without problems. I have played some HDR videos continuously, with no problems.
I have read about these issues on LG OLED, and most of the cases were caused by overheat of the main processor.
Also read about thermal paste. I have opened my TV and yes, thermal paste was hard as rock.
I have cleaned the processor carefully, and used profesional thermo paste, but that does not solve the problem, unfortunately.
Also, I have done hard reset, used latest firmware update, tried without HDMI inputs, but the problems still persist.
As the problem is not coming very often, I am in research of the correct solution.
I was read that the main board can be used from different LG OLED TVs, and even can get a better processor, kinda upgrade.
Give me please your opinion and advice what is the best solution.
Thanks,
Kalin
Keresem a ledek alatti fehér fóliát valamint a ledek feletti fehér/ műanyag/ fényterelőt. Megolvadtak a ledek szétégésekor. Köszönöm!
Sziasztok kedves tanya lakók!! ez a dög került hozzám, olyan hibával csak el kékült a kép és ki kapcsolt :roll: hang van kép nincs csak fehér fény átlós csíkokkal ,videó tápfeszek meg vannak +200V + 12V .3 DB TDA 6111Q videó végfok ic van benne, a kék ágyú videó végfok ícére gyanakszom :hmmm: de addig nem akarom meg rendelni bele ameddig nem biztos mert lehet akár digibox is 100HZ a gép.Esetleg valakinek ötlete?? válaszokat előre is köszönöm!!! ÜDV .Zsolt
