Original problem is no sub woofer output. Been through this one and recapped it and the common 2 burned 1K (R16/17)
resistors are replaced but the sub is still not responding. Volume control potentiometer is a common issue on these but
the L-R spkrs sound good.
Went by this webpage on the repair:
https://christopherbradshaw.net/The_Project_Bin/klipsch%20promedia%20subwoofer%20repair%20-%20page%201.html
On the schematic there is a sub-relay (sw101) powered by +V_HF line it
maybe is suppose to be +V_LF ? Without the relay coming on looks like the sub is disconnected.
The zeners (D03/04) that give +/- Vcc to the op amps seemed way off so I replaced them and the voltages seem much closer.
Theres also a sub-mute line on p104 to p101. Power supply shows the LF mute relay and interconnect diagram says it
gets fed from the LF amp. What is triggering the mute? I dont see a mute button anyplace.
A fent említett készülékhez keresek hangerőszabályzó potit. Nem találtam beszerzési forrást hozzá sehol. Közületek meg lehet valakinek ott porosodik a fiók mélyén, vagy még a polcon van egy hibás "alkatrészbányában". Esetleg forrást tudtok adni ehhez?
Szóval a keresett alany, egy 30k-s, 2x4 lábú példány. Csatolok fotót is róla.
Méretei:
- Tengelyvastagság 5mm
- Tengely teljes hossza 25mm
- forgótengely hossza 17mm.
