Sometimes it is good and there is no problem with the sound, and some days there is no sound output Output voltage rc It is not constant and changes between 0 and 2 volts, and the wire output does not have high voltage levels Add new comment Comments 2024, September 29 - 01:18 #549256 Shizo 15 years 10 months** Hello Resolder output IC-s pins, and voltage stabiliser big transistors TO-220/TO-128 (located in heatsink) 0
Hello
