Good day. I am trying to repair the power supply for HISENSE RSAG7.820.1569. The TV just went blank but there was still sound. So I torched the screen and saw that the picture was there but no backlight. I replaced the KA7500 which is the driver IC. Now the TV comes on for about 20 seconds then switches off.
Please help
Hello
Try to disable inverter protection: pin13 connect with pin14-, then from this point connect 10kΩ to pin2 (This I try in Fujitsu-Siemens monitor)
I think you checked secondary ELKO-s before when replaced KA7500..
If you hearing CCFL arcing, then must disconnect this bad CCFL lamp.
@Shizo
Thank you for suggestion. I did isolate the protection circuit and the TV came on for much longer. However after a few minutes i smelled something burning and found that the Mylar cap across the HV output was the culprit.
I am waiting for the replacement part and I will report back once I got the TV working again
@Shizo Thank you very much for your help. I tried as you suggested and now the TV was not going off after a short while. However, I started to smell something burning. After a quick investigation I found that a cap, 10p 6kV that is across the HV output was getting hot. I guess it is this cap that was sending an error message back to the PWM chip.
Tomorrow I will replace the cap and I will come back to report my success or failure
