Yamaha YDP-141 digital piano some keys are not working
I have the Yamaha YDP -141 and the Keys below are not working.
A-1, A#-1,B-1, C4,F#4,C5,F#5,C6,F#6 and C7
Any thoughts?
TonyStark
TonyStark picture
Hello!
See the manual:
https://elektrotanya.com/yamaha_ydp-141_141c_digital_piano_sm.pdf/downlo...
They are connected to the same line of the contact matrix under the keyboard for the silent keys. For example, for the C4,F#4,C5,F#5,C6,F#6 and C7 in the opening, the common line is n16 But as the questioner writes, there are additional silent notes. After this scene, the problem will be with the cable running from the CN2 connector of the middle panel (GHL-88M) to the IC150 CPU. The end from the CPU runs into the CN13 connector. This CPU scans the keyboard. Maybe something was poured into it or this ribbon cable was damaged, for example by a fixing screw.
The idea comes from my amateur radio friend, Laci, and I'm translating it for you.
Regards:Tony
Alex Caldas
Alex Caldas picture
Many Keys are C and F# even some that we don't use a lot C0 and C7.
This can't be a coincidence.
The carbons are ok apparently.
SzBálint
SzBálint picture
üdv: a flat kábelek hibás csatlakozása is okozhat hibát
Gyakori hiba, különösen külső téren használt  vagy öregebb készülékeknél, a flat kábel és csatlakozó  felület oxidációja, amit csak nagyítóval lehet látni, ezt a páralecsapódás okozza
Nem árt isopropyl alkohollal megtisztítani a billentyűk pogácsáit és alatta az érintkező részt is. ez a későbbi hibák megelőzését is segíti
Jon Snell
Jon Snell picture
The usual cause is the contact strip under the keys. The carbon track wears out.
A replacement is available through Yamaha Music.
