As you look at the two pots head on, is the right side for DVD and left for CD?
To increase laser strength/brightness, do you turn clockwise or counter clockwise?
I would like to know if the two pots/settings are supposed to be tuned together?
Thank you
Saludos los dos se jiran a la derecha. Pero con tester digital. En la escala de 3.000 hmios. El vídeo entre estremos debería marcar. 1.500 o1.600. y el ponsetriometro de audio 680 1.000.
