Philips AG1016 turntable will not stop, keeps repeating
After the creation and mounting of a new belt the device works fine with the exception that it will not stop otherwise than by pulling the plug. At the end of the track the arm is lifted and turns beyond the store position and next starts the disk again as if the button were on AUT and not on STOP. It very rarely occurs though that it stops. Any hint pointing to the spring or other lever to check is welcome.
Shizo
Shizo picture
Hi!
New belt ?  In Philips AG1016 no have belt it use rubber wheel ! Looks like not enought strenght to move arm to store position, rubber must have elasticity.
