Panasonic SA-AK38 mini Hi-Fi: F61 error
Sir, I have Panasonic SA-AK 38. CD player , Deck 1 and 2 are not all functioning. CD tray and Tape door not at all opening. However Radio was working. But few days ago sound was not coming. I checked and replaced 20 PIN ribbon cable. Radio started working, but after sometime it is showing F61. How do we fix it. Please help.
I am from India, Karnataka state , Bangalore city. If you know any expert in fully repair.
Regards
Kumar
+91 9686099661
SzBálint
SzBálint picture
Hello: az F61 igen gyakran a végfok hibáját jelenti, de több más  hiba is ezt a hibakódot generálja
A kolléga is írt erről, írt ötleteket
segítségként a mérésekhez
https://elektrotanya.com/showresult?what=Panasonic%20SA-AK38&kategoria=&...
tvdvdszerviz
tvdvdszerviz picture
Hi!
Panasonic error code F61:  Symptom: When the power switch is switched on, it automatically switches back off, making it impossible to switch power on:
Faulty amplifier output IC or fan motor.
Possible soldering defects should also be checked, and any stretched V-belts should be replaced.
Regards
Kumar
Kumar picture
Appreciate your reply. Can you pls share how V- Belt images.
regards
Kumar
