My old TV has just broke a day ago, and when i try turning it on, relay is clicking and tv is not starting. I have heard that it probably has magnificying transformer broken.
      2013, October 18 - 13:26
    #1
Hi!
I think, the power supply capacitors are loss the capacity. Check the line out transistor not sorted (take out from PCB), if it is ok, change the electrolyc capacitors in power supply.
Üdv: Jácint
W.T.F. the magnificying transformer?
Oh sorry Im not really good at english, translator give me this word, but its inverter transformer.
Inverter transformers are in LCDs.The correct name: Line Output Transformer(LOT),High Voltage(HV) Transformer,e.t.c. A80E chassis, not common one here in Europe.
