Hello, I'm looking for the pcb schematic of the CM2036 revA main board for a WEB coffee machine model wakeup, with LCD display on a separate PCB command. The on/off power switch (on the other PCB which is no more supplied) doesn't work anymore, the machine has been left ON for couple hours before it died.
The main capacitor after the power supply is ok, zener diode going to the input regulator is shorted however a schematic would help much. thanks.
2015, March 19 - 16:00
#1
