when i turn on the tv from standby i can access from control panel or remote control but after its red umber light blinks three times nothing comes/no video no audio / and to turn off i can access only from remote control  i can't access from control panel.
please tell me what i am going to do
   thank you so much
      2017, November 22 - 01:21
    #1
The 3 times flash LED is a error code. That means the backlight LED bar is open! (this set has two lines) Then the processor switch off the set. (No video and audio working remote controll only. Pleas check all LEDs on baclight bar. one or more LEDs are bad.
hello sir as you told me last time i check the backlight and i get one led is bad however after i change it the problem is still the same so can you tell me what can i check for the next please ?.... thanks in advance
thanks in advance i will try it as soon as and i will tell you .
great respect ...... for you .
Hello!
Take off the LCD display you can see the LED bars only. Swith on the set and check all leds how does it work. When start the set all leds light max britness and some seconds stay back half britness and stay on. If the inverter circuit swith off then are defect somewhere in backlight system.
Laszlo
