Hello,
The TV was moved to a new place and now when powered on, quickly flashes the screen ans shuts off, entering into red LED blinking 11 times cycle. After disconnected and re-connected to the power outlet, the same behavior persists. Tried to swap power supply and X-drive boards with no luck.
It would be great if someone could point me in the right direction.
Thank you in advance for your help!
Hello! All sevice bulletn wrote 11 error code is X board problem. Firs time try disconect X drive from plasma display. If display shortcut or defect the symptom is same. Laslo
