Standby current problem
Now I am making a DIY board whose power part requires less than 10uA of quiescent current.
So I used HT7333 , however, when the load powered by the HT7333 starts to operate, the HT7333 gets hot. This occurs because more current flows than the HT7333. Which device should be used instead of HT7333 to ensure low quiescent current and less heat?
The requirements are summarized as follows.
The inlet voltage of the power stage is 9 ~ 12V, the outlet voltage is 3.3V, the standby current is less than 10uA, and the operating current is 500 ~ 800mA.
Kari
Kari picture
Your "mision is inpossible"! _maybe...
What kind of _I think SMD_ case do you have?
Dont forget: in worst case have your regulator ~6W to dissipate :-(
-IT IS NOT A NORMAL SMD POWER for small SMD cases-must be really good cooled_as isnt practicable...
manyizoli
manyizoli picture
cosmosnsr
cosmosnsr picture
The quiescent current of 1117 is 5~11mA so that it is not suitable.
cosmosnsr
cosmosnsr picture
I tested HT7133 instead of HT7333, but the result was same.
zsugori
zsugori picture
