There is noise coming from the transformer of an Aiwa XR-MD85. What could be the problem and how can I get rid of it? lsaac Add new comment Comments 2020, June 14 - 23:57 #441895 david1949 5 years 4 months If the unit works ok, then it is probably the transformer metal body vibrating and causing the annoying noise. An old trick to get rid of it was to get a hammer and dot punch, remove transformer and give the outside of tx a few taps. 0
