Sir/Madam, I am in the process of restoring this radio, The gramophone works, (connected to a separate amp). The radio is the issue. The EBF89 tube socket had two pins damaged, I replaced the socket, Replaced resistors and capacitors as shown in Radio Museums schematic diagram. Radio does not work. All assistance will be highly appreciated. Many thanks, Kind regards, Ben Raghubeer.
