Unfortunately, the remote control doesn't change any settings on the receiver.
When I plug in power, it enters the "port" option with the volume at 67 and does not allow any change.
It only turns off by disconnecting the power.
Thanks if you have any solution to the problem.
Very easy to fix. Send a email to me if you want: @gmail.com (deleted after 1 week)
You are not allowed to press any key let alone resetting the amp.
