Hello
I would appreciate some advice for the above amp.On switch on with tuner and two speakers in the system it plays excellent for about 10min then cuts and a click is heard in the speakers and the power indicator light is still illuminated.
I then switch the amp off and back on again and it works fine again for about 5mins.
thanking you
Ronelektron
Hi,
You mean this amplifier?
https://www.beoworld.org/prod_details.asp?pid=383
If so, please provide some background of the unit. These are really old amplifiers now, What has been done on it so far? It can be anything from old capacitors, bad solder joints to simple contact errors.
