Was Working Fine ,Then Just Quit Cutting.
I Checked The Off & On Switch & When I Turn The Power On A Green & Yellow Light Comes On. When THe yellow Light Goes Out * & I Pull The Trigger It Shoots Out Spark.Then I Try To Cut & Immediately It Quits Cutting.I Go Back To The Machine & Yellow Lights Back On. Machine Wont Work When Yellow Light Is On.
üdv:
https://elektrotanya.com/showresult?what=THERMAL%20DYNAMICS%2050%20XL%20...
