Este equipo cuenta con una fuente MDS712 , ya revise y testie el str w 6553, y no mide mal , no esta es corto ,combie eloptoacoplador y el tl431,revise el ic amplificador las bobinas de las salidas y los filtros en main ,medi los demas voltajes en la fuente y estan presentes ,el transformador chopper, lo medi y mide bien,tocara desmontarlo para medirlo fuera de la tarjeta,los diodos y demas coponentes cercanos al str miden bien ,pero no sale el voltaje de los 35v que se necesitan para alimentar al ic amplificador.si conoces alguna solución o recomendación .publicala ,gracias...
Hello!
![](data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RFARXhpZgAATU0AKgAAAAgABwESAAMAAAABAAEAAAExAAIAAAAuAAAIbgEyAAIAAAAUAAAInAE7AAIAAAAFAAAIsIdpAAQAAAABAAAItpydAAEAAAAKAAARLuocAAcAAAgMAAAAYgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE1pY3Jvc29mdCBXaW5kb3dzIFBob3RvIFZpZXdlciA2LjEuNzYwMC4xNjM4NQAyMDIyOjA5OjA3IDA4OjU5OjQ2AERlbGwAAAAFkAMAAgAAABQAABEEkAQAAgAAABQAABEYkpEAAgAAAAM2NwAAkpIAAgAAAAM2NwAA6hwABwAACAwAAAj4AAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAyMjowOTowNyAwODo1OTowOQAyMDIyOjA5OjA3IDA4OjU5OjA5AAAARABlAGwAbAAAAP/hM2dodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDIyLTA5LTA3VDA4OjU5OjA5LjY2NzwveG1wOkNyZWF0ZURhdGU+PHhtcDpDcmVhdG9yVG9vbD5NaWNyb3NvZnQgV2luZG93cyBQaG90byBWaWV3ZXIgNi4xLjc2MDAuMTYzODU8L3htcDpDcmVhdG9yVG9vbD48L3JkZjpEZXNjcmlwdGlvbj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOmRjPSJodHRwOi8vcHVybC5vcmcvZGMvZWxlbWVudHMvMS4xLyI+PGRjOmNyZWF0b3I+PHJkZjpTZXEgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOmxpPkRlbGw8L3JkZjpsaT48L3JkZjpTZXE+DQoJCQk8L2RjOmNyZWF0b3I+PC9yZGY6RGVzY3JpcHRpb24+PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIA+IBygMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP38ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK5b4reO4fhn8OfEniO4iuLq38P6Xc6pLBEQryJBC0rID2ZttAHU0V+IPw8/4Oq/jx8ZvDUeveC/2FfHnizw/cu8dtqGkapf31tKyllZfNi0xkZlZSrY+6ykVsD/g5f/alH3f+Cd/xY/BtX/8AlXQB+01Ffiz/AMRMP7U3/SO/4tf+Vf8A+VdH/ETD+1N/0jv+LX/lX/8AlXQB+01Ffiz/AMRMP7U3/SO/4tf+Vf8A+VdH/ETD+1N/0jv+LX/lX/8AlXQB+01Ffi2f+Dlr9qCKKSWX/gnn8WIY4xvd3l1VVX5epY6ThQACfmrmfhV/wdefG/47eH7jWvAv7EPjDxtotrcNa3V3oOr3+oW8MqosjRPLDpjKkqo6MQ38JoA/cqivxak/4OXP2po3ZW/4J3/Fgt6j+18f+muk/wCImH9qb/pHf8Wv/Kv/APKugD9pqK/Fn/iJh/am/wCkd/xa/wDKv/8AKuj/AIiYf2pv+kd/xa/8q/8A8q6AP2mor8Wf+ImH9qb/AKR3/Fr/AMq//wAq6P8AiJh/am/6R3/Fr/yr/wDyroA/aaivxZ/4iYf2pv8ApHf8Wv8Ayr//ACro/wCImH9qb/pHf8Wv/Kv/APKugD9pqK/Fn/iJh/am/wCkd/xa/wDKv/8AKuj/AIiYf2pv+kd/xa/8q/8A8q6AP2mor8Wf+ImH9qb/AKR3/Fr/AMq//wAq6P8AiJh/am/6R3/Fr/yr/wDyroA/aaivxZ/4iYf2pv8ApHf8Wv8Ayr//ACro/wCImH9qb/pHf8Wv/Kv/APKugD9pqK/Fn/iJh/am/wCkd/xa/wDKv/8AKuj/AIiYf2pv+kd/xa/8q/8A8q6AP2mor8Wf+ImH9qb/AKR3/Fr/AMq//wAq6P8AiJh/am/6R3/Fr/yr/wDyroA/aaivxZ/4iYf2pv8ApHf8Wv8Ayr//ACro/wCImH9qb/pHf8Wv/Kv/APKugD9pqK/Fn/iJh/am/wCkd/xa/wDKv/8AKuj/AIiYf2pv+kd/xa/8q/8A8q6AP2mor8Wf+ImH9qb/AKR3/Fr/AMq//wAq6P8AiJh/am/6R3/Fr/yr/wDyroA/aaivxZ/4iYf2pv8ApHf8Wv8Ayr//ACro/wCImH9qb/pHf8Wv/Kv/APKugD9pqK/Fn/iJh/am/wCkd/xa/wDKv/8AKuj/AIiYf2pv+kd/xa/8q/8A8q6AP2mor8Wf+ImH9qb/AKR3/Fr/AMq//wAq6P8AiJh/am/6R3/Fr/yr/wDyroA/aaivxN8Qf8HO37SHg7w/qGsa5+wF8S9G0jS4JL2/vb241SC2sbeJPMlld30sLGqIrOXZtqqvtX6U/wDBLj9uuH/gpF+w94L+MEPh3/hFW8Ufa4ZdJ+3fbhZyW11PbOBNsTepaEsvyj5WWgD6JooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv8Ak074of8AYpar/wCkUtejV5z+11/yad8UP+xS1X/0iloA+Hf+DTb/AJQr+Bf+w3rX/pfLX6UV+a//AAabf8oV/Av/AGG9a/8AS+Wv0ooAKKKKACiiigDL8af8ibq3/XnN/wCgNX5J/wDBlf8A8osPiB/2VXUf/TRo9frZ40/5E3Vv+vOb/wBAavyT/wCDK/8A5RYfED/squo/+mjR6AP2AooooAKKK85/ae+OOk/sxfs9+OviNrkOqXml+BdBvNfvbexVTc3ENrC0rpEGZV3so25yvJHzDHAB6NRXh/8AwTu/bQ0n/goZ+xj4F+MWh6XeaHY+NLWaRtPupFlks7iC4ltbiPeoUSIJ4Zdr7V3rtbaudod+1R/wUN+Cv7E11p8PxX+JXhXwRc6shlsrS/u9t1corbWdYVDSFFb+MLtoA9uorxH9lz/goL8F/wBtO71GH4U/Erwn42uNJCte2+m3Yae3Vj99om2vt7btvWvOfHP/AAXC/ZL+GfjLVPD2u/HjwHY6xot09le232p5Wt5kba6MY0K7lYbSP4WBFAH1pRXzn+zl/wAFW/2df2ufiOvhP4bfFrwl4u8TSQvcpptncOJ5IkC72Cuq7sZr1j4U/Gzwh8cNLvr7wb4o0PxXY6bezaZdT6XfxXcdrdROUlgdkZikisvzK1AHaUVw3jL46eDfAHxF8NeD9V8UaBp/i7xctw2haLcX0UWoav5EZlmNvCf3ku1RubbXaxKqR7R9Ou6gCSivzn/bp/4K/wDi7wN/wVC+Dv7LnwN0bw/4x8XavqVvffECS+WWb+wNK+Sd0j8p12T/AGVZpWMm7arwfK/m/L778eP+Cvv7M/7Mnjy58L+OPjX4D0PxFYsEu9N+3+fPZttVtsqQh2ibayttf+E0AfTdFeY/s6ftY/DP9r3wnNrfwx8eeFvHelWsohuZ9F1JLn7M5XcElCHdE5HOGC16VD8sf60ASUVzvxG8f6H8JvB+reJvEmqWOh6DodrJe3+oXsqxQWsKAM0ju33VWvls/wDBfv8AY2iZlP7QXgXcrY/187f+yUAfY1FeS/su/ttfCn9tfw9qGqfCjx1oPjrT9JuFtr2bTJi32R2XcocNtP3a3vG/7Qfgn4cfE3wt4M1/xZoGj+LPHHnDQNJu7+OK81owKGlWGJvv7VPagDvKKjhG1MY2/juqSgAooooAKKKKACiiigAooooA+f8A/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831fSX/AAVh/wCUWP7Sn/ZKvFH/AKaLqvm3/g1cP/GkP4T/APX5rv8A6eb6gD9EqKKKACiiigAooooAyf8AhNdJ/wCgtpf/AIFpR/wmuk/9BbS//AtK/IH/AIgo/wBnP/opnxs/8DdL/wDkOj/iCj/Zz/6KZ8bP/A3S/wD5DoA/X7/hNdJ/6C2l/wDgWlH/AAmuk/8AQW0v/wAC0r8gf+IKP9nP/opnxs/8DdL/APkOj/iCj/Zz/wCimfGz/wADdL/+Q6AP1+/4TXSf+gtpf/gWlH/Ca6T/ANBbS/8AwLSvyB/4go/2c/8Aopnxs/8AA3S//kOj/iCj/Zz/AOimfGz/AMDdL/8AkOgD9fv+E10n/oLaX/4FpR/wmuk/9BbS/wDwLSvyB/4go/2c/wDopnxs/wDA3S//AJDo/wCIKP8AZz/6KZ8bP/A3S/8A5DoA/X7/AITbR/8AoLaX/wCBaf40f8JrpP8A0FtL/wDAtK/IH/iCj/Zz/wCimfGz/wADdL/+Q6P+IKP9nP8A6KZ8bP8AwN0v/wCQ6AP1+/4TXSf+gtpf/gWleefteeLtLl/ZP+J6pqmns7eEtVwEuEbd/octfmJ/xBR/s5/9FM+Nn/gbpf8A8h1y3xy/4M6f2e/hX8EfGHiSz+InxiuL7w7od9qUEdze6a0MjwW7yJuC2att3DnDUAfSv/Bpvx/wRX8Df9hvWv8A0vlr9KK/Nf8A4NO8/wDDlzwPu+Y/25rX/pfLX6PT8fdHPGOM/wCQKAMjxh4+0HwPcafHrms6PozavcpY2Av7yO3+3XD52wRbyPMkbH3F+Y1lfGD4+eCf2dPBEniT4geLvDvgrQI5UifUtb1GKwtVd/lVN8rKu7/Zr+bv/grZ/wAFCte/b2/4Li/Di102PV4Phd8GfiPpfhHSWdXjgbUk1GI3k5bG1JZZISq8/wCqtkavuT/g9MDj/gnP8Ns52/8ACyLfd0+X/iV6jgD8N3+dtAH6AN/wWC/ZRQnd+0d8E/8AgHjSw6de01e2/Cb4teF/jl4DsfFHg3xFo/irw3qgZrPUtJvkvLS4AZkbZLGSrbWDKcH5WUjtX4Eo/wDwRFjxz4jVWPzY/wCEw2t1/wA/yr9kP+CYHgv4CeF/2K/C7fs2ppf/AAqXVjPe6dNYPPI1xKzskzytcfv/AD1dCjeb86+Xtb7tAHvXjX/kTNW/685//QGr8lP+DK//AJRYfED/ALKrqP8A6aNHr9afGH/Ikar6/Y5v/QGr8lv+DK//AJRYfED/ALKrqP8A6aNHoA/YCiiigCM4L45/pX5T/wDBXT/gvT+yzrP7Kn7QXwZsfiV9v+Id54X1nwxBaW2h38kEmoSWssQhFysPk/LKwVm37VZWz0r9Up9u8/h/9bHvXwd/wWO/4J6/Aub9gz9oj4iSfCH4Zv4/g8E61rI8RN4ctf7T+1x2cjpN52zzN/yfe3dqAPkP/g3t/wCC2v7M/wCzn/wTm+DfwU8ZfEaPw38Q7O51O0ntbzTb0Wds91q95cQebeeT9mRTHNE27zNq7+cNuFfVPx0/4Igfs9eP/wBtn4gftFfHbV/+E0sfFVvZ2Wm6L4nvxb6HoASGGLbE7SLuZ2iZkVmVF88gKT81eV/8G3n7APwN8f8A/BJf4IfEfxB8Ivhzrnjr7Rq17/wkN9oFpcap5ttrl+sEv2hk8zfGsMar83yqijtX21+39/wTj+Ff/BUL4T2Pgn4o22palpeh6oup2r6ZqT2c9pdLE8W75cq3ySuNrq1AH5M+M/g18E/2Tf8Ag5X/AGXLH9mJdFsbbxNo1wPE2l+GtWNxpmySO+QuXV2Xe0KO7Rb/APlhA+1d25vkr/gnj8e/2Ifgh8Qfj5D+1V4Jbxlr9546uj4fMelXF95Noss6y/Mron3sfe+avpD9q/8AYE8A/wDBC7/gsp+xbr3wWPiOG1+I+vvomr2Wpaj9qUpLdW1lNscKG3NBqLfLyu6JGVQa/TD9g7/gmZ+yL8NfHnxX1j4Y2PhH4ga5qnii8j8US6hcWuvS6DfLO7yaeoZc26xu5Gxvmwq7mZvmoA8C/wCCSH7Uv/BN34i/tUWNj+zz4R0Pwd8WL6yuo9PjvtEurW7uoVTzLgQSS74t/leYSFZZPLST+DdXBf8ABAhk/Yd/4K6fth/soyTNb6PHqi+MPC1js2RWtrvQ8f7bWl7p/wDveRS/8FGPhB4Y+B3/AAck/sS33gnw7peg6hq9pdWd/BpNj9jjkhU3ShyIgqE7Jpt2F+79/wCXbXL/APBe/wCIM3/BLL/gsd+z7+1rpem6hfaVrmg6h4e1y0sl8uK+e2gkiVZTlQd0V6jLubpZqy/coA6T4N3k3/BSP/g628YeKre4ku/BH7KXh59IsriKTzLb+0dkls0Thv8Alp9pu9Qb5f8Anx+9X6Ef8FTP+CiHhr/gmb+xz4k+JeutFcapHE1n4c0qeURtq+pyK3kwgfe2qw3u2DtjVmr46/4NQvgHqXhD9hbxh8bPFe2TxX8evFN3r13qU0YjmuLW3lkiV5d235ftJvZR/sz14Paxt/wcof8ABYx5GRtQ/ZN/ZouWWIbpGsfF18X45+6VnkTdxnbaxD7vm0AdN/wTL/Yz8a/ss/8ABL39pT9sb4hXE1x+0J8W/AHiDxba313E32zRbL7FPdwqrH5laeREmZVK7VS3X+Gq3/Bu3/wRu/Zv/ad/4JjeE/il8SPhfpfjjxp4zvtTbUb/AFa6nkVVt7+5hQRosqpGu2JdzKu5mY5+Wv2M+Knwy0T4v/CzxB4N8QWMd/4b8UaVdaLqNp9xZrW5heCWLj7u5HZc/wC0a/ITwR/wbzftYfsn2V54Z+Af7aWs+G/h79tmvdO0m+s7qJ7ESSM2wqrvEW+Y72RY977m2KW20AQfsPfs96F/wTW/4Og/GHws+Gto2ifDn4mfDn+2P7DSd5obGVQj/edmbd58MzKu7aq3W1fl21+1kf3BX4D/APBO79mT4j/sr/8ABz1p/h34pfFO4+MXjqX4eXGqax4gl81WjWS32JAd7MwVESPb9z76/LX6dfsu/wDBZD4S/te/t5/E39njwvb+Ko/Gnwua7TUbm/09IbC9ezuktLlbdg5f91O6LulRd2G25XazAGp/wXDx/wAOiv2iNx2/8UPqP/or/HFfiT+wh+11/wAEv/h1+xx8O9G+MXwrk8QfFCz0nb4kvV8P3Fxvut7n/WCVFb5WX7v061/Qh+118L/B/wAaP2YvHnhX4iXjWPgXW9Du7XXrs3f2NbOy8pjLO0x/1XlqN+/7q7eflry/9jH/AIJ8fs3/AAm/Zg8H6N8N/B3gPxR4PjszLpOuy2lnrEurRys0v2g3mz/SN+8/Mrbdvyr8ooA4v/gjb8SP2Sfil8F/EGofsm6Toeh6Euox/wBv2Vlp8tjex3XlbYvtCy/vG/d79nzNH97b826vxW/4OEf2r/F3jL/gtZqfxC8Habc6npP7Jsvh6GS535tbO7ivEut7L/Cz3lwsP979xzxX2h/wS31nwj+xV/wWe/4KJNY/ZdG+HfhPS08VX9vEw+zWfkGS8mZQv3Fjea42oPuK23+Gvze/ZM/b6+BOofsKftmab8XZtcX4v/tK6hc39l9n0k3FjDPEzX1m5mB/df8AEwuGZ/l+7ElAH9Vfwl+JOkfGP4W+G/F2g3cd/ofijTLfV9PuY3DrcW88SyxOCvHzI4PHrXS1+b//AAa5ftcx/tMf8EmfBej3F4LjXPhfNN4U1BVgdRFFEzS2g3N8rf6K8K/L/dr9HIf9WP5f3fagCSiiigAooooAKKKKACiiigD5/wD+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfV9Jf8ABWH/AJRY/tKf9kq8Uf8Apouq+bf+DVw/8aQ/hP8A9fmu/wDp5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/wAmnfFD/sUtV/8ASKWgD4d/4NNv+UK/gX/sN61/6Xy1+kD/ALwsF3fh/jX5v/8ABpt/yhX8C/8AYb1r/wBL5a/R5/M8wt0+nJI+X/Z+v+egB+P/APwcoeBNF8B+PP2NY9F0fS9JTUPjPb3tzHa2iW63UzzWzPLJsGGZmYlm/i3Gvt7/AIKy/wDBPb4W/wDBR34BaD4P+LHiHUPC+haX4ostQs7211C3s5Jbxt9tHbq0ylGab7QYVXG7c67fmr89P+CmX/BIv/goR+3L+0da6y3xg+DmoeC/Afip/Enw+t57cadJohDrJC7oljKzsioit5886syn+9X1T+17/wAEmPif/wAFLP8Agl94I+F/xv8AihpMPxo8MX8PiB/FegaWV0+TUokuYk3W6mLcvlXG1nRIsMm9UX/V0Ae0Tf8ABGf9lEaEtmf2dfg3HH5Pkbv+EVs/N2ttG7zfK3s/ox+bJr4t/wCDRB28Ofsq/G7wfa6pcapoPg/4n3tjpTzS72EX2eBd4T7qq+3edv8AEzVxutfsE/8ABXa88GXHhF/2nvhbeaBNavpv2mXyo7yWBgybjcDSftKysrH94su//a3V97f8Egv+CYnh7/glL+yXa/D3SNWk8Q6tqF6+t+ItXli8j+0r50WLKRbm8mJEiRFX73ybm+ZmoA+nfF7eZ4I1Rvl+aylPH3fuGvyW/wCDK/8A5RYfED/squo/+mjR6/Wrxh/yJWqf9ec3/oDV+Sv/AAZX/wDKLD4gf9lV1H/00aPQB+wFFFFABXF/HD4QaH+0H8JPFXgPxVb/AG7w14w0m50TVLZZ3haa3uI/Kdd6MGUlXblWVuRXaUUAeQ/sY/sh+Ef2Df2XPB/wl8Crqf8Awi/gu2eG1bULn7Vd3Mks8lxLNLJtVd0k8sjnaqou/CoihVHwH+0n/wAEJfjdpf7cXxC+NX7Nv7TuqfCnUPihJFea9pF7p73UE0qjaWLBmSYK2503xbovNZVbD1+rVFAH5P8A7OH/AAQh+M/iH9uD4d/Gj9qL9oeL4y3Hwona98P6NDpPlQRXShXhfeSipsmRZflj3M9umWqv8VP+CBXxu+C37VHxD+In7KP7SVx8I9M+KWovq+u6Df6Y13DHdPK8rlHbejLvdmXdGrKrbdzLX60UUAflZ+x1/wAEJPjN4c/4KJeEP2jf2iv2gofi14q8AafLp2j2lnpHk7kaK4ji3yttCpGbu5fYsXzOysX+9X0b/wAFov8AgljZ/wDBWv8AZQsfh+3iOHwjrOia1Brul6qbL7XHHKkUsLRNHvTKPHO/8XysENfY1FAHzL4//wCCfzJ/wTBuP2bfAfiq48Hwx+DYvB9lrsVtvnjQRJE8zpv+cyqJd67l3ea3zL96rn/BMX/gnZ4R/wCCYv7JPh/4W+FmTUJLPN5rWtC2+zz69qEg/e3brubbn5URNzbI0Rdzbd1fR1FAGXqlv/aOnzW7eZbrMmGdD8yZ/ut/Cw557Haa/Irw5/wQp/bM/ZfuNS0n4J/tuapY+C5ruW6tbLxFYS3M9krNxHukaeM7VxueNY9zZbYu7bX7E0UAfnN/wSp/4Ip+KP2KP2sfGnx6+MXxguvjJ8WvGmkLo02oS2LW8drDug3vveRmkbZaW6K21NscbKq7a+uvhr+xN8Jvg/8AHjxJ8TvDXgHwzonxA8XLKut69aWAivtQWWVJZt7j+/LFE7f3mTdXr9FAHn/7RvwQ0f8AaW+BfjL4e+I0dtB8caNeaHqHk585YZ4mjZ09GXeSvB+bZX5RfBb/AIIN/ts/seeCofAvwc/bOstB+H+kyzS6dp91obf6L5srSuFjZZlX947P8rLuZ2O1c1+ztFAH5T/s2/8ABu5r3wi/Y0/aS8I+JPjJca18WP2l1Da34wtdI8uK1IledovKd287z5JLjzWVYn2zMq7WVJK+vv2Pf+CXXwl/ZK/Zf8D/AA5Twb4Q8Tt4S0yKzudY1Dw7bm61W4Hzy3D7kdl8yR5X2Fm2+ZtzxX01RQB8Z/8ABL3/AIJPWf8AwTJ+Ivx0vtH8XXWteHfi14kTXNN0Iaelpa+HE/et5aKrMrtunKbvl/d28Xy19kx/6sf1p9FABRRRQAUUUUAFFFFABRRRQB8//wDBWH/lFj+0p/2SrxR/6aLqvm3/AINXD/xpD+E//X5rv/p5vq+kv+CsP/KLH9pT/slXij/00XVfNv8AwauH/jSH8J/+vzXf/TzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8AJp3xQ/7FLVf/AEilr0avOf2uv+TTvih/2KWq/wDpFLQB+DP/AAQ8/wCC92i/sGf8E8vDHw1vPgb8ZfHE2l6jqFw2q+HtOSbT5/PuZZAiszc4ztP+0DX19H/wdieHSvy/su/tIHv/AMgWJv8A2evRv+DTb/lCv4F/7Detf+l8tfpRQB+Sf/EWJ4c/6Nb/AGkP/BHF/wDF0f8AEWJ4c/6Nb/aQ/wDBHF/8XX62UUAfkn/xFieHP+jW/wBpD/wRxf8AxdH/ABFieHP+jW/2kP8AwRxf/F1+tlFAH5B+I/8Ag6v8O6joGoRj9mL9ouNpbeWPc+jIqL8p6/Px6t/sivhv/g3l/wCC2Gj/APBNb9jTxR4Fvvg78WPiHJqnjW714an4WsEurWFJbCxg8l/n+WVfs28/7LrX9JnjT/kTdW/685v/AEBq/JP/AIMr/wDlFh8QP+yq6j/6aNHoA0Yv+DsLw4iBV/Zc/aQA9BokXH/j9P8A+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/JP/AIixPDn/AEa3+0h/4I4v/i6P+IsTw5/0a3+0h/4I4v8A4uv1sooA/ED9t/8A4OYPD3x+/Yx+L3gdf2dfj5oMnjLwVrGgpqV/o8S2mmtdWE8H2iY78rHHv3N/sq9fV/8Awavf8oRPhR8u3/Tdd4/7jN7X0h/wVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv8Ak074of8AYpar/wCkUtejV5z+11/yad8UP+xS1X/0iloA+Hf+DTb/AJQr+Bf+w3rX/pfLX6UV+a//AAabf8oV/Av/AGG9a/8AS+Wv0ooAKKyfEfiGx8JaNf6rqVxDZ2Gm28l1dXErbVhhjTc7seyqvNeZfsdftx/DH9vb4VXPjb4V+KrfxT4ctNUuNGluEhkgaO6h2s6FHVW/1bI6/L8yOrfxUAex0VVb93/tbf5/0Y7q8R+E/wDwUQ+EPxv/AGsPG/wR8K+MbPVviR8O7VbzXdLjgnC2qb40fbKyCOVkeaFH2M21pVVvmDKAD2Txp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj1+s3iv/kRtU+Zj/oUwyW+b7h6+9fkz/wZX/8AKLD4gf8AZVdR/wDTRo9AH7AUUUUAFcP8fvjFoP7Pfwc8VeO/FE09t4e8FaRda5qckURkkS3t4Xlcqo+Zm2qdu35sj612Uvytu/y1fCv/AAWL/bi+C+n/ALA37RPw9uPi98KoPHlx4G1rS4/DUvi2wXVjdS2TiOL7M8ol8xt/C7ehFAH0h+wn+2D4Y/b1/ZN8F/FrwbFqNv4d8YW0slvDfwiO5t3guJbaaJwp27kmhlTK/KduV4r0bxL450bwaI21jWNL0tZD+6+2XiW/mfTc3zV+Y/8AwbU/trfBnwf/AMEk/gf8O9V+LXw10vx602sW3/CM3fieyg1cyTa5fyxxfZGlWXe6OjKNvKurLw1dD+1f/wAG5XhP9v8A/b68afFz42fETxZ4l8LavaW1p4a8JWBazXQUigiRw1xuf920iSvsjRMs+4u33aAP0W8N+OdG8XiV9J1fTdUWEjf9iuEn8sn+9sJqhc/GTwhpk8lvdeKvDdtcQkiSKXVIY3U+438V+HEP7Dng7/gjh/wcVfsz+Efgfq/iSLSfiVo1w3iPRb/U/tEkkEgvYi8uArNF+6Eqq67VktWYMD934y/Y0+Hf7Dfj34m/HrVP2vPHPifwz4gHj28j0OPT/wC0Zpbm382dpnf7LbTM3zsMs/zUAf1PeH/iH4f8XXckOk61o+q3Ea72SzvY53UdM4VvlrXsL6HUYfMgkjlj3Mm5TkZVirD8CDX5K/8ABEP9nz/gndYftQ3nir9l/wCIGr+KPiJpemTQGy1bUdRs7j7LLsWaWO2uobdrhV/ifa6ozL91tprC/wCDdfxlrv7L37e37W37KfijVrq8k8K+JJfFXh3+0LqWe4uLaWZlmnLuxZvNilsJWZvm3ysW3NQB+w1xewxXEUbPGskzbYg3/LTjLY/CrEf3Fx0r8cbnx14g/b2/4OudN03S9W1SDwL+yj4auHuFQuLWe/lt2ilXenypI8uoJE2/70djIu2v0U/4KKftw+Gf+Cdn7IHi74qeKG+0R6DbbNOslYpLq98+5ba1U4O1pH4Ztvyrub+GgDwX9vj/AILJyfs2/wDBQj4M/s2/D3wanxE+IHxC1S0k16JLry18O6Y8o8x+PvT/AGZbibazKsccas25XWvtDV/iX4b8KXZs9U8Q6Lp90q58q61CKKT1+6xDV+Mv/BLr9nTx98NP2Df2l/2/viRcG4+O3xP8C674q8OXMkO1dI0+KwmuYJEAPy+e0URRN3ywQ2/3d2K4H/giX/wb5fA//go/+wZ4f+OPxg1P4heJvG/jq/1J7+T+3vKij8i/mttysEaR5HWHczSO33uAvDUAfvVoHiTTvFdkLrTL+x1C3Py+fbTLLH+DLwea1K/Df/gmd+zfYf8ABI//AIOPPGHwC8E69rk3w1+JHgE6vpun6reiSSO4VUuEZ9mxZWia3vURtu5YpWVmZgzt+40H+qWgCC9u4tOt5Jp5I4YYxl5HYKqr6kmuaT44+Cf+hw8L/wDg2t//AIuvAv8AgtxIYf8Agkr+0RIrbGHgfUuc4/5ZdP8AgXFfg5+xh8FP+CVt7+yh4Bvfjd8TPGGk/FO80tJ/Elnp8OrzwWtwzv8AJm3s5Ylbao+VX3e1AH9O/h/xbpXi+1afSdQsdSt432PLaXCyohxnkqaty6hBbXcMTyxia4z5SE/NJgZOK+J/+CIH7Pv7Kvwc+AOual+yj4jbxX4X8TX6S6pfS6nLd3SXCRDZFNFKqPbsqkNseJG/eV+Rv/Bw1/wUQ1zw1/wXX8IeIfDUuvXGi/sr/wBktcJp7PFBHcSzx3V3udfuLPHNDavu+V/K2fxUAf0qIdyqadWX4P8AE9j438Kabrelzx3Wm6xaxXtnPGdyTwyoHR1P91lZTWpQAUUUUAFFFFABRRRQAUUUUAfP/wDwVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vq+kv+CsP/KLH9pT/ALJV4o/9NF1Xzb/wauH/AI0h/Cf/AK/Nd/8ATzfUAfolRRRQAUUUUAFFFFAH5I/8QvPib/o9f9pD/wAGUn/yRR/xC8+Jv+j1/wBpD/wZSf8AyRX63UUAfkj/AMQvPib/AKPX/aQ/8GUn/wAkUf8AELz4m/6PX/aQ/wDBlJ/8kV+t1FAH5I/8QvPib/o9f9pD/wAGUn/yRR/xC8+Jv+j1/wBpD/wZSf8AyRX63UUAfkj/AMQvPib/AKPX/aQ/8GUn/wAkUf8AELz4m/6PX/aQ/wDBlJ/8kV+t1FAH5Ev/AMGufiQXqzf8NqftFExxuvOoS+b+B+0fdqx/xC8+Jv8Ao9f9pD/wZSf/ACRX63UUAfkj/wAQvPib/o9f9pD/AMGUn/yRXI/H/wD4NqvEXgD4E+NNcb9sr9oTUl0fQb6/e0vNQkeC68q3eTynH2j7jbdrV+zlec/tdf8AJp3xQ/7FLVf/AEiloA+Hf+DTnd/w5b8D56/27rX/AKXy1+lFfmv/AMGm3/KFfwL/ANhvWv8A0vlr9KKAPzE/4OhPjt8TfDv7H3h34O/Cbwx4k17xV8f9Wfw5PcaVD5i21jGqGa3dh937R5qJ8/yeV9p3Mvy155/wZcf8os/H/p/wtXUP/TRo9frV40/5E3Vv+vOb/wBAavyR/wCDLV9n/BLPx4dqsF+KmoH73f8AsjR6APpP/gvX/wAFUx/wTT/ZP8nwu633xi+I0j6P4K01F82aORgFlvjEM71g3rtXad0rxLjbuZfzG/4Nh/2efGX7LP8AwXe+MHgn4iTyXHjix+FU1/rTyXLXEy3N7d6DfOkrt8zTL9o2ucn51f5m+9Vr49+A/wBsi9/4LWa5+0F4p/ZV8XfFnTfAN/PYeAtIa9EGl2FvBKY7S6iZBJu+XdPj+GWcP/BR/wAEpv2oPjR4+/4Oe/iN4j8SfBK80DxZ448PLpfjHw6+o+XJ4K08RaVi/Z5QDKu63tDsx832z5fm20Af0FeNP+RN1b/rzm/9AavyT/4Mr/8AlFh8QP8Asquo/wDpo0ev1p8XRrH4I1RVG1Vsphj/AIA1fkt/wZX/APKLD4gf9lV1H/00aPQB+wFFFFAELjMnXbx+P+eK/Kv/AIK9f8EG/wBlvT/2Wv2hvjVa/DVrP4iW/hnWvFEF7b61qEMC6itrLOswtkm8n5pQGK7NrMzZ61+rVcL+0F8ENG/aR+DHi74f+JVuX8O+ONHutD1MW0nlS/Z7iF4ZNr/wvtf5WxxigD8ff+Df3/ghz+zP+0x/wTi+DPxm8cfDj/hIPH+oXGoXs97cazfx21w9nrV5Db77RJlgePy4YtyMm19g3Z3tu/S3/gox+w5qH7eXwH0/wXpvxV8f/CRrPU4dR/tTwlefZ7i7WJHUQy7QGaP5lfarL88aV0f7A37Hfhz/AIJ+fskeC/hH4TvtS1LQfB9vMkd1qJX7TcST3Et1NK/C7d080jbf4d23tXwv+15/wTf/AG+/Dv7W3jj4h/s3ftO6Pp/hnxzdC8/4Rvxa7yx6LtVdsFvFNa3sGzc0nKLD94btx+agD4t+PP7DN5/wRT/4LVfsb+LG+JXir4yX3xE8QTaHcT+K2Ml3ZwSvFpz7XLuWRYtUdl3N96Kv0e/Zm/4Ny/2Yfgf8S/Hni7WPCdr8WtU8cavc3wHjG1tdSttHV53d7e3h2eXuVi252Vn+XHy/dr5//Z//AOCLP7Wn7QH7dHwq+LX7ZXxk8CePNJ+C95/aWg6VodkPMuJxiSPIis7WJFWeK2lZysrP5Wz5fvVU+J3/AARg/bW/ZU/ap+J3jD9kT9oLw34d8H/FvXbnxLq2leKoxLJZXk7mR8JJY3cTtvd1WZFjk2Kitu27qAOU/bI/ZP8Ah3+w1/wce/sZar8KfCXh3wVB4utbuw1DR9CtYrK3jO25ga72Im3c0V2yf7S2y/d+9Vf/AILH/Eu3/wCCSP8AwXw+Df7UDR3EPhH4ieF73RfE8dlbBm1Ce1haBvNx/dSbTG/vf6NXpn7GX/BHn9rfxl/wUr8A/tC/tafGPwT4yvvhZYTWmi2OhRASTeZFcqoZIrS1gijV7h33hWkfy9jfKq19K/8ABdf/AIJU6l/wVp/ZF0vwb4f1zTPDvi7w3rkGuaRfaisjWrbklgmglZEd/LaObd8q/eiTd8tAHzh/wae/BfVtT/Zu+Kn7RHiq3jbxZ8f/ABnd6g12hb99a2s8u9tp+5/p017kL8z7I933a8f+Nmpt/wAHHv8AwWZs/hvps095+y7+zNdfa/EE9vI4tfEd95mxkYfxLPJE1vEw+7BFdSo372v0o8SfsK614B/4JRP+zv8ACfxYvhXxBp/giPwtpfiRt8TRzeWsc12TF8yyS7pX3J8yvLuG1ttT/wDBJj/gmn4d/wCCWf7IWj/DfR7ldU1mZ21LxFrAQI+qag6qruF/hiRVWKNW3MqIm5mbLUAe0/Fv4MaD8cfgL4o+Hmq2+3w34u0G78OXkVp+622lzbtbyrF/dHlsdu30r8hfhp/wR9/4KQ/sCaLN8Pf2dP2kvhvD8KdOuJrnRrXWtPtzd26ySs7KyT6ZcKjszszbJdrMWb5c7a/ai+/0iGWLdJHuUqGj+8N3o3Zv8RX442f/AATT/wCCo37Muqah4c+Ev7WnhfxN4KW4efTrvxqBqGrbWb7kjXmnXbr1/gl2f7vQAHzr+xV8D/2ivA//AAdP/C2H9obxvoHxG+I2n+GdQ1XUtS0eULa2Vg+jajbQRKnk26oyySr8iRY/fb/m3Fq/ZD4B/wDBVD4K/tJ/tfeNvgT4P8UXGq/Eb4erdf2vZHTbhIY/stwltcbbhk8t9krojbW+9ur5Y/4JQ/8ABH744/An9t7xh+0l+018T/DfxF+KXiLQf+EetIdEhb7Pbw/uR5m829uiMsdvGipFEEw8rNuZt1fT/wAAf+CUXwX/AGY/2x/iB8ePB+h6ja/EL4k/azrFy+oyy2rfarhLq52RMdiebMiO3vnbt6UAenftbfAPRf2sP2ZfHXw38Qahe6bofjjRLrSLy9tHVJrSKWIqZULAp8uQfm+WvnH9mT/ggZ+yr+zx8EdH8Jn4R+C/H9xYo7XHiDxXolrqeqapI5bfK8zxbtvzfKibUC7dvPzV9KftQfAqz/aj/Zw8efDXUNQvtP03x5oF7oNze2n/AB8wx3MDxO6Z+Vvvr8v3W5Ffkh8I/wDgmD/wVN/Y78Baf8NvhT+0p8KR8PfC6vBoY1Czt5544PMZwn+kaXcSqq5+WLzXVF2qpVVVQAX/APgjFb+G/wBgn/grr+314G0W8/sn4U+ELWLxWbZcC20tIt1wyIq/cWKO4li2/e2xKrfMtfnX+z1+1z8AfjV+xd+2/qnxs8dr4f8AjV+0Jqjap4d0Z9L1K8SGW1mfUbYLc29u6Ikt5Ktuwd1+S2TKqvzV+oH7Lv8AwQL+NHgf9kD9qtviB8UvDerftCftPWD2d/q9uJZNLsYi8ryxPL5UT7rhZ5UfZFsiXZtV1Xa305+yH/wQY/Zz+AH7Mfg3wX4q+EPwq+IXiXw/psdrqviLU/ClrJdaxdZ3yTM8qM+1mZtqszbVVV3cUAc7/wAG0X7W1r+1F/wSZ+HNpJfW9x4g+Gts3hHVIEk3Pbpakrabh/tWn2c1+gUY2oor4T/4JDf8Eotc/wCCW/jv49W6+LtM1b4e/ETxRFrnhPQLGya3GgxL5rMGDMV3srww4X+CzRty7tq/dVuytApVtydjnduFAElFFFABRRRQAUUUUAFFFFAHz/8A8FYf+UWP7Sn/AGSrxR/6aLqvm3/g1cP/ABpD+E//AF+a7/6eb6vpL/grD/yix/aU/wCyVeKP/TRdV82/8Grh/wCNIfwn/wCvzXf/AE831AH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/wCxS1X/ANIpa9Grzn9rr/k074of9ilqv/pFLQB8O/8ABpt/yhX8C/8AYb1r/wBL5a/Siv5yv+CJH/Byj8C/+Cbf/BPnw38KfHPhb4s6t4i0a/1C7nuNC0mwmsdtxcvKm15b2J2+VhnKL839771fW/8AxGpfss/9CF8fv/BJpH/yzoA+yv8Agqz+wN8TP29vh34b0f4a/tCeNvgJeaNfyXN/NoCP5euQvEYxFM0M0E/7vLMqiXym3tvidvLaP5z/AOCNn/BBn4h/8En/AIyXGpH9pXXvFngW+trhrrwVbaI1jpd7fSiJPtjo9zMqyKsS/vURJG2opdo9yPwP/Eal+yz/ANCF8fv/AASaR/8ALOj/AIjUv2Wf+hC+P3/gk0j/AOWdAH69R/6v+7XyZ8H/APglj4d+DH/BVT4oftT2fijWbrW/iX4Zt/D02gyQRLa2O1rXzp1l+825NPtNqN9xvPYs3mosXxx/xGpfss/9CF8fv/BJpH/yzo/4jUv2Wf8AoQvj9/4JNI/+WdAH6yeKznwPqnX/AI8pvX+43rX5M/8ABlf/AMosPiB/2VXUf/TRo9UvEP8AweZ/sv6tod7BH4D+PSyXFu8KNJoulbV3Ljqup7uuM4r4i/4N9/8Ag4E+Df8AwSh/Y38UfD34heG/iXrWsax41uvEcE/h7T7K5to7eWwsbdEPnXkLLJvtn+6rLtZfmoA/pqor8f4/+D0z9lm3jVV8A/H7avA/4kmkdP8AwZ07/iNS/ZZ/6EL4/f8Agk0j/wCWdAH6/UV+QP8AxGpfss/9CF8fv/BJpH/yzo/4jUv2Wf8AoQvj9/4JNI/+WdAH6/UV+QP/ABGpfss/9CF8fv8AwSaR/wDLOj/iNS/ZZ/6EL4/f+CTSP/lnQB+v1FfkD/xGpfss/wDQhfH7/wAEmkf/ACzo/wCI1L9ln/oQvj9/4JNI/wDlnQB+v1FfkD/xGpfss/8AQhfH7/wSaR/8s6P+I1L9ln/oQvj9/wCCTSP/AJZ0Afr9RX5A/wDEal+yz/0IXx+/8Emkf/LOj/iNS/ZZ/wChC+P3/gk0j/5Z0Afr9RX5A/8AEal+yz/0IXx+/wDBJpH/AMs6P+I1L9ln/oQvj9/4JNI/+WdAH6/UV+QP/Eal+yz/ANCF8fv/AASaR/8ALOj/AIjUv2Wf+hC+P3/gk0j/AOWdAH6/UV+QP/Eal+yz/wBCF8fv/BJpH/yzo/4jUv2Wf+hC+P3/AIJNI/8AlnQB+v1FfkD/AMRqX7LP/QhfH7/wSaR/8s6P+I1L9ln/AKEL4/f+CTSP/lnQB+v1FfkD/wARqX7LP/QhfH7/AMEmkf8Ayzo/4jUv2Wf+hC+P3/gk0j/5Z0Afr9RX5A/8RqX7LP8A0IXx+/8ABJpH/wAs6P8AiNS/ZZ/6EL4/f+CTSP8A5Z0Afr9RX5A/8RqX7LP/AEIXx+/8Emkf/LOj/iNS/ZZ/6EL4/f8Agk0j/wCWdAH6/UV+QP8AxGpfss/9CF8fv/BJpH/yzo/4jUv2Wf8AoQvj9/4JNI/+WdAH6/UV+QP/ABGpfss/9CF8fv8AwSaR/wDLOj/iNS/ZZ/6EL4/f+CTSP/lnQB9/f8FYf+UWP7Sn/ZKvFH/pouq+bf8Ag1cP/GkP4T/9fmu/+nm+r5F/bT/4O1v2b/2lv2N/i58PND8G/G2z1rx94K1jw5YS6ho2mraw3N3YT28TylL92WPfKu7arN7V9df8Gr//AChC+Ev/AF+670/7DF7QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/wAmnfFD/sUtV/8ASKWvRq85/a6/5NO+KH/Ypar/AOkUtAHwf/waleHNP1T/AIIweBZLiw0+eY61rAZ5LdJGb/T5e9fpD/whek/9ArS//ARK/Oz/AINNv+UK/gX/ALDetf8ApfLX6UUAZX/CF6T/ANArS/8AwESj/hC9J/6BWl/+AiVq0UAZX/CF6T/0CtL/APARKP8AhC9J/wCgVpf/AICJWrRQBy3jDwXpMfhTVGXStPVvscuClui/wNX5Pf8ABmPoljrX/BL3x091Y2d1JH8UtQRWkt0bb/xKNIr9dvGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPQB+tQ8FaTgf8SrS/8AwESl/wCEL0n/AKBWl/8AgIlatFAGV/whek/9ArS//ARKP+EL0n/oFaX/AOAiVq1yHxf+KGifA/4e+IPGXiq+j0vwx4W0y41fVL1wzLa28CNLK+1QWbaiM3y/N8owOtAG1/whek/9ArS//ARKP+EL0n/oFaX/AOAiVwn7H/7V3g39t39m7wr8UvAN5dX/AIT8W2zz2UlzAYJ0MUrwSxujdJElikRuWXchwzD5q9QoAyv+EL0n/oFaX/4CJR/whek/9ArS/wDwEStWigDK/wCEL0n/AKBWl/8AgIlH/CF6T/0CtL/8BErVooAyv+EL0n/oFaX/AOAiUf8ACF6T/wBArS//AAEStWigDK/4QvSf+gVpf/gIlH/CF6T/ANArS/8AwESvjr9v3/gsLov7HH7ZPwZ+BOh+EtQ+I3xA+LmtWdveafY3ghbw3pktwkDXkq7H8wspldY/k+WCV3kRQu77WhyUG7lu/wApWgDO/wCEL0n/AKBWl/8AgIlH/CF6T/0CtL/8BErVooAyv+EL0n/oFaX/AOAiUf8ACF6T/wBArS//AAEStWigDK/4QvSf+gVpf/gIlH/CF6T/ANArS/8AwEStWigDK/4QvSf+gVpf/gIlH/CF6T/0CtL/APARK1aKAMr/AIQvSf8AoFaX/wCAiUf8IXpP/QK0v/wEStWigDK/4QvSf+gVpf8A4CJR/wAIXpP/AECtL/8AARK1aKAMr/hC9J/6BWl/+AiUf8IXpP8A0CtL/wDARK1aKAMr/hC9J/6BWl/+AiUf8IXpP/QK0v8A8BErVooA+a/+CrXhXS7b/gmD+0hJHptjG8fwu8TOGjgRWX/iUXnNeAf8Grx3f8EQPhN/1+a722/8xi9r6T/4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9QB+iVFFFABRRRQAUUUUAFFfkn/AMOuP+Cl/wD0fP4f/wDCdT/5Go/4dcf8FL/+j5/D/wD4Tqf/ACNQB+tlFfkn/wAOuP8Agpf/ANHz+H//AAnU/wDkaj/h1x/wUv8A+j5/D/8A4Tqf/I1AH62UV+Sf/Drj/gpf/wBHz+H/APwnU/8Akaj/AIdcf8FL/wDo+fw//wCE6n/yNQB+tlFfkn/w64/4KX/9Hz+H/wDwnU/+RqP+HXH/AAUv/wCj5/D/AP4Tqf8AyNQB+tlFfkVL/wAEvv8AgpfHqkcjftxaE0axvucaGPl6f8svs21qs/8ADrv/AIKXHn/hujQf/CeT/wCRqAP1srzn9rr/AJNO+KH/AGKWq/8ApFLX5s/8OuP+Cl//AEfP4f8A/CdT/wCRq4/49f8ABNP/AIKL+H/gf421DXv21tD1bRLTQb6bU7EaGq/bLZbd2liH+j8bl3L/AA0Ae6f8Gm3/AChX8C/9hvWv/S+Wv0or81/+DTn/AJQt+B/+w5rXbb/y/wAtfpRQBHI21/evM/gd+1t8N/2k/EXjDS/AfjDQvFV74C1BdJ12GwuFl/s27bd+7c+7K6/70bV8w/8ABf8A/bV8dfsffsUfY/hboXiDWviR8WNUTwV4dk0qBp5NNuLiGWR50VRuaZYIZvKVf4jvPypXwf8A8GYvw11b4NfFL9sPwdr0UcGueE9U8PaNqMUTiRI7m2l1uKVQy8EB0b5u9AH6lftkf8FX/wBnz9gHWdN034tfE/R/CerapEk0Gmra3Oo37QsWVJnt7WKWaKJirL5sqKjMNobdWD+yb/wWv/Zd/bZ8dw+F/hv8YND1rxFdP5dppt5a3ekXV4+N2yGO8hhaYhef3e7vXNftY/8ABMf9lW1/aO8VftQfHLSfD+pTtpUFhqM3jO6hl8O2KIiQI628q+X5rKiJ8+775281+V3/AAU2n/ZL8aft8/sbWP7Itl8Pbjxs3xCtJdVbwDYRR2qQre2TQ/aPKXb5it5rr8rbVSUv8u2gD+hPxp/yJmrfw/6HN/6A1fkp/wAGV/8Ayiw+IH/ZVdR/9NGj1+tPi8/8UTqv/XnN/tfwNX5Lf8GV/wDyiw+IH/ZVdR/9NGj0AfsBRRRQA3P/AH1Xyh/wWO+JHh2H/gmH+0ZpMmuaL/af/Cu9biFk94nns7WEu0bN26vqeVNzlu/b9PwPSvyJ/wCCun/Bu/8As36X+zz+0N8eYNP8aQ+PLfw/rXjKJz4illtl1BLeWcHZIGYx+bhtu/8A2VwuFoA9j/4NjPiHoFh/wRO+Bmkza5o8OpNJrkYs2vUS5JbXtRZUCb9245U/Q1wf7dv/AAQk+JX/AAVb/b+8Ua58avipqGj/ALP2h29tH4I8P+GblVvhN9ni+0PKksTwRN5/nfvG8x2+VRtWvnz/AIIFf8EBv2eP2pf+Cf8A8Gfjx4w0/wAWXfji7v76/lNvrL29m0llrN5Bb/ulXd9y3i+63Jr9R/8AgpT+x58Qv2zvgDH4T+Gnxu8WfAnW4dRgvJta0NXaa7hTJ+zvJFLFOi9/3U6f7W5TtoA/Kz4L/sp3/wDwQX/4Ll/Aj4R/C/4h+NvFHwz+OVlK+u+H9VdJW87bPB9odIkSFvLZEfeq+YqJIrZX5m+Nf2Qv2P8A9lz9uP4xftBeJv2ov2gdW+GPiez8dXcWnRnXLGCbUomllLOwuIZXl2t8nyccV9AeOf2QPiT/AMEff+C5P7IPjD4tfGLxB+0VL4+1aXw5Z6trb3DXmnxSt9g2E3FxMzRxSaokyfOF3K3y19rfsgf8Grvwh+F3xr+JXjT4xf2f8ZG8Wazd3mh6fdWk1pb6Pay3Dyq0vlyr507KwVvl2r/CtAFP/giN/wAEvf2Pf2eP2jtR8dfs9/tD698VPEmm6XJZXekR+LLKa3iin24muLa0jieVV2/J5u6NWbdt3orJD/wbv/G/xl4A/a+/a2/Zq+IXiTXPEWr/AA/8YTa9odxrWpyXlxNYy3UsTsqN8qI3+iTfJt+a8OVVuK8h/aK/Y5+G/wDwTS/4OPv2Rrn4Q+G7XwTo/jyxu7LUtH024ZYnlZLy3afY0hYK0dwn+x/o/wB1m3Vpf8FI/iPp/wDwSZ/4OSPhn8ftUmh0T4efGfwhdaX4mu9p2zTQQ+Q+/H8Ksmkv+FAHo3iz45eMP2xP+Dpvwx4E8NeLdetfh7+zj4Vl1DX7G3ldLG8vZbWRJS6r8rszahbQt5n3fJlVfmr9FP2y/wBrDwv+xB+zD4v+KfjG4ePQ/Benvdvbo48/UJmGyC1i343SzSskScj5m5b71fm//wAGpXw41z4peDvj1+1H4qjuI/EHx48azeR5kwmj+ywSyyyNHj5gv2m7li+b/n0HyqOW89/4KO+MNQ/4L0f8FbfDX7J/gvVJ1+CfwXu21n4lalbNug1C5iZYpYFZf+WiM7WsbbvlluJ32t5O6gDO/wCCVvwv8eap8Iv2kP8Agpl8WLGPUviRrXhXX9d+H+n3ill0uwtbOd/NQNu2RssKWsAZQ3kRO2XWeuD/AOCa/wDwQrt/+C437Lej/tGftEfHP4reJPFfjK9v4bWK0uLfGn29rdy2/lBriOVdrPE7qiJHGqtt28bq/bf43fs26H8V/wBkrxZ8HLVJfDvhnxR4PvPBsC6fFt/suznsns0ESMNv7uN/lDfKMLntX47/ALJvgf8A4Kkf8EnPhJF8Efhv8EvhP8TPA/hi7uJdI1u7uYpVuEnmknkMTLqNpJtaSRztniWQbsDK7WIB3X/BJrwn43/4Jb/8FtPGH7INz8QPE3jr4S6t4KTXfCMWtXhnk09kEcqFE+5Bt23iN5S7W2wNtWv2kQYWvwF/4J3+Nf2hvif/AMHN2i6x+094S0HwP8Rbz4eXbRaNpLxPa2eniB1i2bLi4xubzWPmSs/P8K7Vr9gvg7/wUP8Agv8AtC/tJ+NvhF4N8eaPrfxJ+Hu9df0WKCZGtTG/lSqJXRY5xFK+2TymbYzbWw25aAOT/wCC1GrXXh//AIJR/tBXljdXFneReB9S8qWBzHLH+625DL83/wCuvwY/Yo/4JZf8E+/jF+yf4G8VfFP9qzUPBfxA1zTRc63ocXiPS4V0ubew8rZJbPInyhfvN/F/wGv6Kf24P2bZ/wBsL9jv4kfDK31T+w7nx94eu9HgvZYjKtm8sTIrsmc43Nzg/dr49/Yw/wCDYr9mX9nT9nzSPDXjzwPovxU8ZbXk1fxLqS3ETXkzZ/1MSyssMKIdir/Ft3N8zUAejf8ABEr9h/4H/safs16rH8BPihrnxY8GeKtWe+/tO48QxalZ286IsTRQpbokETbl+dtnmN8quzKqKv5e/wDBfj/grj4n+Cf/AAXO+HCeE/EuvW3hn9nz+zLnXbGynmSC6mupI576KRAdrrJZzW9u3y/KXZfvCvob/ghJolj+wt/wVU/bk+CemXn2P4ZeFbmDxRYW0jssGkxbmcKu7+7BcRxM38S26V+dvw0+Jnwi/bN/ZK/b9+KHxO+JXhnw38TPivqi6n4K0TUruKLVNljcPqaQwqzbnWf/AEe0Xavy+R1b+EA/qg0HWbbxBolnqFnNHPZX0SXFvKn3ZInG5GH1Uir1fDf/AAbyftVx/tX/APBJH4S6hNcrcaz4R04+FNUTzzNLFJYM1vCzlvm3S2yQS/8AbXGW+9X3En3P8KAHUUUUAFFFFABRRRQAUUUUAfP/APwVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vq+kv+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8mnfFD/sUtV/9Ipa9Grzn9rr/k074of9ilqv/pFLQB8O/wDBpt/yhX8C/wDYb1r/ANL5a/SivzX/AODTb/lCv4F/7Detf+l8tfpRQA2Tqtfjb/wbKL/xsW/4KPfxN/wse14P/YU8RV99f8FOv2QfiV+2f8C7Twt8Mfjh4o+BOtR6pHeXWsaHBJJPf26I2bcvFLBLD821t0cq/d2tu318U/8ABOL/AIN1Pix+wF+2HD8TF/ay8Va1Z6pqX9peMNJtdHltf+E2f9+3+nPLdyrO3m3DsZJY3kVZZWR0d1dQD9DPirp3wb/bSs/GXwd8UXPgf4gnSVtR4m8KzXkF5caa0m2e2e5t1bzIGbYrxOyr93ctfjT/AMHD/wCwX8Kv+CRsPwP/AGhvgBoP/Cs/Gmh+N7ezex0q9mSz1SNYJ7reyM527fJMLbNqvHdOr/Ltr7B/4KBf8G7cP7Uf7VWqfHT4U/G74gfAX4qeIFhTU9R0iSWS3vFjjSJnTypoJ4HeKOHKrJszB9z+KuJ+A/8AwbIa1qnx08N+Nv2kv2mvih+0DF4LvotQ0XSNTnuFihlRw/72W4ubqTy2bZuii8rdt5dh8tAH6r+LP+RI1X/rzm6f7jV+S/8AwZX/APKLD4gf9lV1H/00aPX60eLv+RJ1X72fsc2c5/uNX5L/APBlf/yiw+IH/ZVdR/8ATRo9AH7AUUUUAFea/tZ/AW1/aq/Zr+IXwzvL+TS7fx74evfD8t1F80lulzA8W8Dvjcf1r0qigD50/wCCW37Ezf8ABOv9hX4f/BxvEDeJpvB0F15+pi1+yx3Mt1ez3kuyP5tqLJO6L833VU/xV8RftV63/wAFPP2V/wBsn4hat8HPDngn45fCXxZeLdeHtP1uW3j/AOEdhwG+zrF9rtJwys7p9+VGVFb5fur+tFFAH4ieB/2Nf23/APgqP/wUe+A3xE/am+F/gT4aeBPgNqsmsRDR79P+JhKrxTqEiW7undnntrTlmSPYr/e+7Wr4h+Ef/BSz/gm1+1f8WpPgr4f8L/tAfDX4k+JLrxNpi+JNQDpobTzyStEkUt9avbv+8KNtZ4mWJWXax21+01FAH4tfsp/snftvfty/8FfPhH8f/wBpr4c+C/hj4c+D+l3FvbW2kX0TRXxeK6VDFEt5dytO0lwhdnZE8uBMfN976B/4OTP+CXfjT/gpr+x/4ZsfhpptjqnxA8C+IU1DT7e6nS2e6tJo2guIUmmZUQ7mgmbc3zC22j5q/SSigD4t8K/sh/ET9iX/AIIwW3wh+CI0v/hbHhnwP/Z2l3CyJBC2sSqzXd0ryvsDefNcSp5nyLIybvlzVH/ghd/wSxX/AIJhfsfpo3iGSx1D4p+Mrgax4y1OF2k3XDZ8q3V2++sCnbv/AI5Glb+KvuCigDK1NJms5I7cfZ5niZYZRtaNGxgcH+7nPTov/Aa/HbT/AI5f8FjP2btT1DwtcfC74TfHCG0uCbbxVd/YoReRdRtW3vrDav8AD+9gV/l/i+837PUUAfkj/wAEhP2EP2pPGf8AwVE+If7Wv7U/hvw/4H8Qa54dHhzSNAsL5LiOM4s0WWBYrm4WGBY7Z12SSMzSTu+3nc31R+y1/wAEY/hP+yL+338Tf2iPC994um8Y/FI3jX1pe36TafYPeXS3d00ICLLmSdEbDyNt3Mq8fd+xqKAPK/2uPhFq3x9/ZX+I/gnQ/EF14V1jxh4c1DRrHV4mKvpk89vJGk2VO5drMCdrK3y8bWr8jfgL8U/+CvH7Hnwl0z4Z2fwL+H/xOsvCbTWtr4j8QasmoX2oQeazRbpl1eBmVVYKm+NZFjVFb5lav3GooA/En9lD/glf+1hH+yz+298TPH2g6Fpf7Qn7SmlzabpHh221G1VrWBvP85FuEleGJZY5hFEry7l8hGd1b5h9H/sKf8G3f7PXwt/ZH8CaH8V/hP4N8ZfEaz01D4k1V3llN1eSM7uqupTckfmbFbau5YkNfpPRQB+b/wDwQU/4JofEr/gmB4o/aG8H+I7PQ4PhnrXi+PUvAUtpefaby6tf36s0/wAqsu2FbRfn/wCWiy7flwzfo9B/qlp1FABRRRQAUUUUAFFFFABRRRQB8/8A/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+r6S/4Kw/8AKLH9pT/slXij/wBNF1Xzb/wauH/jSH8J/wDr813/ANPN9QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP+xS1X/0ilr0avOf2uv+TTvih/2KWq/+kUtAH4m/8ECP+C+H7Nf7A/8AwTX8KfDT4k+KNe0vxXpupajdXFvb6DdXcWye7eRMPGrKflYV9nR/8HZf7Fuxd3jrxRux83/FKX//AMRXH/8ABrZ+z14B+If/AAR18Eapr3gfwfrepSazrAe7vtGt7id9t7Io3O6Mx+VVX/dFfoh/wyJ8JB8v/Crfh2f+5csv/iKAPiD/AIiy/wBiv/oe/FH/AISl/wD/ABFH/EWX+xX/AND34o/8JS//APiK+3/+GR/hL/0S/wCHf/hOWX/xFH/DI/wl/wCiX/Dv/wAJyy/+IoA+IP8AiLL/AGK/+h78Uf8AhKX/AP8AEUf8RZf7Ff8A0Pfij/wlL/8A+Ir7f/4ZH+Ev/RL/AId/+E5Zf/EUf8Mj/CX/AKJf8O//AAnLL/4igD4R8Sf8HWv7GWp6BfQweN/Ekk09s6Rg+Fb1dzFW2jOz5fmx1r4B/wCDbL/gtl+z7/wTV/Ya8VeBfit4k1jSvEGq+O7zXrWK10W5vI2tXsNOgR2eJG2/vLaTiv3W8ZfsifCdPCmpyL8Mfh2rLaS7GHh6y+T5OD9zjkdq/LT/AIM+fgd4H+Kv/BNPxxqHibwb4V8RXsfxO1C1SXUtHgu3SL+ytJbyhvRtqbmJoA+gv+Isn9iyPj/hOvFH/hJX/wD8RR/xFl/sV/8AQ9+KP/CUv/8A4ivt6P8AZG+EuPm+F3w7Zu5/4Ryy+b/xyl/4ZH+Ev/RL/h3/AOE5Zf8AxFAHxB/xFl/sV/8AQ9+KP/CUv/8A4ij/AIiy/wBiv/oe/FH/AISl/wD/ABFfb/8AwyP8Jf8Aol/w7/8ACcsv/iKP+GR/hL/0S/4d/wDhOWX/AMRQB8Qf8RZf7Ff/AEPfij/wlL//AOIo/wCIsv8AYr/6HvxR/wCEpf8A/wARX2//AMMj/CX/AKJf8O//AAnLL/4ij/hkf4S/9Ev+Hf8A4Tll/wDEUAfEH/EWX+xX/wBD34o/8JS//wDiKP8AiLL/AGK/+h78Uf8AhKX/AP8AEV9v/wDDI/wl/wCiX/Dv/wAJyy/+Io/4ZH+Ev/RL/h3/AOE5Zf8AxFAHxB/xFl/sV/8AQ9+KP/CUv/8A4ij/AIiy/wBiv/oe/FH/AISl/wD/ABFfb/8AwyP8Jf8Aol/w7/8ACcsv/iKP+GR/hL/0S/4d/wDhOWX/AMRQB8Qf8RZf7Ff/AEPfij/wlL//AOIo/wCIsv8AYr/6HvxR/wCEpf8A/wARX2//AMMj/CX/AKJf8O//AAnLL/4ij/hkf4S/9Ev+Hf8A4Tll/wDEUAfEH/EWX+xX/wBD34o/8JS//wDiKP8AiLL/AGK/+h78Uf8AhKX/AP8AEV9v/wDDI/wl/wCiX/Dv/wAJyy/+Io/4ZH+Ev/RL/h3/AOE5Zf8AxFAHxB/xFl/sV/8AQ9+KP/CUv/8A4ij/AIiy/wBiv/oe/FH/AISl/wD/ABFfb/8AwyP8Jf8Aol/w7/8ACcsv/iKP+GR/hL/0S/4d/wDhOWX/AMRQB8Qf8RZf7Ff/AEPfij/wlL//AOIo/wCIsv8AYr/6HvxR/wCEpf8A/wARX2//AMMj/CX/AKJf8O//AAnLL/4ij/hkf4S/9Ev+Hf8A4Tll/wDEUAfEH/EWX+xX/wBD34o/8JS//wDiKP8AiLL/AGK/+h78Uf8AhKX/AP8AEV9v/wDDI/wl/wCiX/Dv/wAJyy/+Io/4ZH+Ev/RL/h3/AOE5Zf8AxFAHxB/xFl/sV/8AQ9+KP/CUv/8A4ij/AIiy/wBiv/oe/FH/AISl/wD/ABFfb/8AwyP8Jf8Aol/w7/8ACcsv/iKP+GR/hL/0S/4d/wDhOWX/AMRQB8Qf8RZf7Ff/AEPfij/wlL//AOIo/wCIsv8AYr/6HvxR/wCEpf8A/wARX2//AMMj/CX/AKJf8O//AAnLL/4ij/hkf4S/9Ev+Hf8A4Tll/wDEUAfEH/EWX+xX/wBD34o/8JS//wDiKP8AiLL/AGK/+h78Uf8AhKX/AP8AEV9v/wDDI/wl/wCiX/Dv/wAJyy/+Io/4ZH+Ev/RL/h3/AOE5Zf8AxFAHxB/xFl/sV/8AQ9+KP/CUv/8A4ij/AIiy/wBiv/oe/FH/AISl/wD/ABFfb/8AwyP8Jf8Aol/w7/8ACcsv/iKP+GR/hL/0S/4d/wDhOWX/AMRQB8Qf8RZf7Ff/AEPfij/wlL//AOIo/wCIsv8AYr/6HvxR/wCEpf8A/wARX2//AMMj/CX/AKJf8O//AAnLL/4ij/hkf4S/9Ev+Hf8A4Tll/wDEUAfmL+3n/wAHM37JP7QX7Dfxn8CeGfGXiS68SeNvAut6DpcD+GbyFZrq60+e3hRnZNqr5ki87q90/wCDWD5v+CIfwnbaq/6ZrvA/7C95Xp//AAU8/Zc+Gnh7/gmn+0PqGn/D3wNp+oWPwz8S3FvcW3h+1jmt5F0m5IdGVNyuv1ry/wD4NXt3/DkH4Ts3zM15rjdd3/MXvKAP0RooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/yad8UP8AsUtV/wDSKWgD4d/4NNv+UK/gX/sN61/6Xy1+lFfmv/wabf8AKFfwL/2G9a/9L5a/SigAormfiV8RNF+FHg/UvEfiXVrHQtA0W2lvr7UL24EFrZwxJud5Xb5VXbnluOnfbVX4E/Grwr+0R8I9D8beCdd0/wATeFPENsLrTtUsnLQXSbirEZ+YMGVlZW+ZWVlPzA0AdhRXzD+2L/wWD/Zt/YG8aQ+Hvit8VtD8M+IZkSU6XDa3eqX0CMNytLDZwyyQqy42tKFDdq7r9kj9u74Q/t4eDG1z4S+PtD8bafbhPtS2jslxYlhlVmt5VWWJv9l1VqAPUPGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPX61+Nf+RM1b/rzn/8AQGr8lP8Agyv/AOUWHxA/7KrqP/po0egD9gKKKKACioZ4lkPzLu7V/PD+xp+yT8Rf+Cwf/BSj9sTT9c/aP+MvgGz+Gfje4gsINB1ud4mhl1HUYYoVTzVRI4ktEVdq/doA/okor8C/2lPgh8av+Dfb9s79nnxbof7RnxG+KXw9+J3iNPDPijSPFVxLdRiPzoN5WPznVnaCaVkdVWSJoG+dll211H7QsPx7/wCC4X/BXT41fArwv8d9Z+EvwT+CP2eC6TQYZfNvrjEcc6P5LxNPI8v2vb5snlqsC7Ymbc1AH7mUV+Ov7FvwF/ac/wCCR/8AwVR8D/B6bxj8QPjx+zz8WNPuXTVNVhuJ18K3MEMr/NKzOtuy7FUqrqsiz7tm9VrwP/ghH/wWw8Z2n/BU34nfBr4weNte8TaH8SvFGoL4Xu9XvGmj0PVlup9lpFvbEMFzH8iou5UkiiVEXzXagD+gaivyn/4Kz/tY/Ej4Nf8ABbj9kHwb4X8ZaxovhTxJbXsmq6VbSBbXUt7SRP5qfdk+RBt3q21l3L81fCv/AARL/wCCffxO/wCCxv7PfjX4neKP2rvjx4T1ax8WXGi+VYaxcSw3TfZre6aVt065+a4bKLt45oA/pCor8Tf2FPij+0D/AMEsf+C0PgD9kb4q/GzVvjP8P/iR4am1TRrzVYmkuLN9t48LCWWR50XzNPli8rzZI9si/Kv8P7WW3+oU53d92fve9AE1FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP/8AwVh/5RY/tKf9kq8Uf+mi6r5t/wCDVw/8aQ/hP/1+a7/6eb6vpL/grD/yix/aU/7JV4o/9NF1Xzb/AMGrh/40h/Cf/r813/0831AH6JUUUUAFFFFABRRRQB+Nv/DKv/BZj/o5b4J/+CnT/wD5RUf8Mq/8FmP+jlvgn/4KdP8A/lFX7JUUAfjb/wAMq/8ABZj/AKOW+Cf/AIKdP/8AlFR/wyr/AMFmP+jlvgn/AOCnT/8A5RV+yVFAH42/8Mq/8FmP+jlvgn/4KdP/APlFR/wyr/wWY/6OW+Cf/gp0/wD+UVfslRQB+Nv/AAyr/wAFmP8Ao5b4J/8Agp0//wCUVH/DKv8AwWY/6OW+Cf8A4KdP/wDlFX7JUUAfjb/wyv8A8FmPuf8ADSfwT3f3v7M075f/ACh0f8Mp/wDBZr/o5b4J/wDgq07/AOUdfslRQB+Nv/DKv/BZj/o5b4J/+CnT/wD5RVyvxz/Zf/4K76f8D/GU/ij9oz4PX3h630O9k1W3t9NsElntFt3aaNGXRVbe0e5V2sv+8tft5XnP7XX/ACad8UP+xS1X/wBIpaAPh7/g082/8OW/A+Nu3+3Na6f9f8tfpPX5r/8ABpt/yhX8C/8AYb1r/wBL5a/SigD8bP8Ag8Q/bO1j4TfskeD/AIMeH47z7V8XLq4vNYuIldgum6Z5U7RcH/lpLJEzfe/dwPmvov8A4Nio5E/4IXfA9YxGzN/boy/3f+Q/qfb+L/x3d617R/wWN0a1uP8AgmB+0NfyWdvNd2fw18QJBO6BpIUksJVl2f8AAQK8V/4Nkb1NP/4ISfBW6uJI4YbePxBNLIR8sarr2ptuI/3cn8qAOH/4J4/8G6Pg/wCFfif4hePv2mo/Cf7QXxU8d6xc3cmoavpxutPs7eR9w2W9wGXz5G+Zn2/uwyxIfkZn+e/h38KvDP8AwT1/4OyvCPw7+DEdj4X8E/FTwVcT+JvDumsFsbOZdO1G5VEhU7Ym36fbzKpGF899oVX21xv7K9p+2B/wce3/AMRPiJpP7SesfAH4M6P4pl0XRtJ8PwzwXIVYI38p0tbiFpdsM1u7+bcsrSyvtVVRVH6Df8Ezf+CEPw0/4Jq/EvXfiJb+JPF3xK+JviO1+yXPiLxJKlxcW8LsN4hRR8pl2oGeRnb5Pvbd1AH214vG3wVqo/6c5uP+ANxX5L/8GV//ACiw+IH/AGVXUf8A00aPX60+LWz4I1VvlybKY8dPuNX5Lf8ABlf/AMosPiB/2VXUf/TRo9AH7AUUUUANk6rX81//AATl/bD+O37JX/BTL9tqb4J/AO++OT654/vF1iO3vmtv7FEWraoYGO1G3eZum/u/6qv6S5HVZvmZdv3jkfl/I1+ZP/BD/wD4J/fFD9k/9uv9s7xp488PjRfD3xO8Z/avDkj3McranbfbNQuvPGz+DZexD/f3L/DQB8qfFa4/a7/4Lo/tX/ATRfHf7MOtfBHwN8JfGf8AbmvatrUMyxTRo8Dvs+1JEzqywsi+UsgZpeu1Grqf+CDep+I/Dn7cv/BT+78KaTYeIPiDZ+M5X0bTtSuzBFfXA1LxAdks+1mVWk8rccfN/wCPD9tVkB+6Mt15Ur61+M/xu+Bf7WH/AASv/wCCufxk+NnwP+DEXxu+G/x0t4ZrrT7TUlgnsbtVRm3rnzFdZhMysEdGS5Vdyv8AdAMvSv8AguL+3R+zl+2f8Ffh5+0h8BvhX4T0n4w+IbbQrJdKllF5KJLqC2eVJU1G7RfKe5ib50+bd1r4o/Zk/wCCZd1+3t+x3+1l4g8GQ3Fr8YvhF8UZvEXhS7s18i7nCee1xZK64ZGdY1dCv/LeCIbua+7fgV8A/wBqj/gqN/wVy+D/AMcPjp8Hbf4KfDv4H2s09jp91eebcahct5rxbEZvN3tK0TtuVEWODb8zfLXuX/Bvr+wV8TP2H1/aPX4l+HY/D58ZfEWa90b/AEpJ/wC0LRN6i4QplVjfzfkDYZvmVlWgD80If+Cldn/wU6/4KN/sC+LrxrdfHOg2Nxovi62T5fL1BJZR5qr/AArKoWVV/h8zb/DX2T/wZTf8o6PiZ/2Uef8A9Nen1w3xn/4IG+OPg3/wcDeA/ix8KfC32r4Q+KdZm8UarcLcJ5Hhm9aKdrlHRm3qkkrh4tq7VaUoNqpXjX/BMb47fth/8ELfh941+ETfsU/Ev4pJqHiSfWv7V0m1v5bTe0Fvbr5U1paXEUqbbZXzuVvm/hoA+u/+CrultqX/AAcm/sNKtxJZuLK9dpl/iRWuWKf8C+5/wOv12T7tfjV+xl+zn+0x/wAFHv8Agsd4F/ak+PHwqk+CPhH4T+HZNP0PQrufdPf3DpdImI3Pmbt95JK8rIn+rgTa2N1fspCNsYoAdRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHz//AMFYf+UWP7Sn/ZKvFH/pouq+bf8Ag1cP/GkP4T/9fmu/+nm+r6S/4Kw/8osf2lP+yVeKP/TRdV82/wDBq4f+NIfwn/6/Nd/9PN9QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/wAmnfFD/sUtV/8ASKWvRq85/a6/5NO+KH/Ypar/AOkUtAHw7/wabf8AKFfwL/2G9a/9L5a/Sivxe/4Ns/8Agpx+z3+zH/wSg8G+EfiF8YPAng/xNZ6rqs0+mapqqQTxJJeyMjMjdNysrf7rV96/8PwP2RI/lb9on4V7u/8AxPI6AOP/AOCxn/BMz4lf8FLvBGieGfBvx+8SfBzw7BHeW/iHSrCwe5tfE0M6Iuy4EVxA7osYlTynZ0fzPuLt3V5n/wAEqP8AgiH8SP8AgnR4Z8W+FdY/aY8VePPAOv8Ah240XS/C6aU1ppugzzvK7XduktxceU26aRv3Xlb2ZmfftWvfv+H4n7If/RxXwp/8HkVH/D8T9kP/AKOK+FP/AIPIqAPzt+Ef/BrX+0B+z14M/wCEf+H/AO3h8QvA/h/7Q91/Z/h+w1LS7cTOFBl8m31NVLsqrmvrL/gmh/wSr/aA/Yl+Pt14p+IX7X/xC+N3h2402Wzbw1rS3U0DTMV8uZXu7u48ryvm4iVHbdyxX5G9g/4fifsh/wDRxXwp/wDB5FR/w/E/ZD/6OK+FP/g8ioA+lPGH/Ilartxj7HNjH+41fkr/AMGV/wDyiw+IH/ZVdR/9NGj19heK/wDgtl+yVqXhnUo4f2hfha5ktZY1264m7cyFfu/xckfnX5r/APBqJ/wUO+Bv7Jn/AAT18Z+G/iZ8VPBngXxBffEa91K30/V9QS2lmtX03TIklG7/AJZmSN1+qNQB+81FfKa/8Fwv2Q0Uf8ZFfCzp31yOnf8AD8T9kP8A6OK+FP8A4PIqAPqqivlX/h+J+yH/ANHFfCn/AMHkVH/D8T9kP/o4r4U/+DyKgD6qor5V/wCH4n7If/RxXwp/8HkVH/D8T9kP/o4r4U/+DyKgD6qor5V/4fifsh/9HFfCn/weRUf8PxP2Q/8Ao4r4U/8Ag8ioA+qqK+Vf+H4n7If/AEcV8Kf/AAeRUf8AD8T9kP8A6OK+FP8A4PIqAPqqivlX/h+J+yH/ANHFfCn/AMHkVH/D8T9kP/o4r4U/+DyKgD6qor5V/wCH4n7If/RxXwp/8HkVH/D8T9kP/o4r4U/+DyKgD6qor5V/4fifsh/9HFfCn/weRUf8PxP2Q/8Ao4r4U/8Ag8ioA+qqK+Vf+H4n7If/AEcV8Kf/AAeRUf8AD8T9kP8A6OK+FP8A4PIqAPqqivlX/h+J+yH/ANHFfCn/AMHkVH/D8T9kP/o4r4U/+DyKgD6qor5V/wCH4n7If/RxXwp/8HkVH/D8T9kP/o4r4U/+DyKgD6qor5V/4fifsh/9HFfCn/weRUf8PxP2Q/8Ao4r4U/8Ag8ioA+qqK+Vf+H4n7If/AEcV8Kf/AAeRUf8AD8T9kP8A6OK+FP8A4PIqAPqqivlX/h+J+yH/ANHFfCn/AMHkVH/D8T9kP/o4r4U/+DyKgD6qor5V/wCH4n7If/RxXwp/8HkVH/D8T9kP/o4r4U/+DyKgDqv+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfVD/wAFIf8AgsD+y78T/wDgnh8efDvh748fDTWNc8Q/DvxBpum2FvrMTT3tzPptzFDFGvVnd2Vf+BVN/wAGsPzf8ERPhOev+m678397/icXvNAH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/ACad8UP+xS1X/wBIpa9Grzn9rr/k074of9ilqv8A6RS0Afkn/wAG4v8AwSY/Zx/ax/4JUeD/ABn8RvhH4X8W+KNQ1TVYZ9RvUlaWZI710QHa6j5VRV/4DX3Z/wAOAv2Nj979n3wHn/rlN/8AF147/wAGm3/KFfwL/wBhvWv/AEvlr9KKAPjn/hwB+xr/ANG++Bf+/U3/AMXR/wAOAP2Nf+jffAv/AH6m/wDi6+xqKAPjn/hwB+xr/wBG++Bf+/U3/wAXR/w4A/Y1/wCjffAv/fqb/wCLr7GooA+JfFf/AAQO/Y9sNA1Ce3+APgdJI7aV1xHLuyqN0y/qR+VfnD/was/8ExfgL+2n/wAE9vGHif4qfDHw7428Qab8RL3S7W91BZfMjtk03TJUiXay/Lvlkb/gVfvJ40/5E3Vv+vOb/wBAavyT/wCDK/8A5RYfED/squo/+mjR6APriP8A4N//ANjUR/8AJvvgX/v3O3/s9O/4cAfsa/8ARvvgX/v1N/8AF19jUUAfHP8Aw4A/Y1/6N98C/wDfqb/4uj/hwB+xr/0b74F/79Tf/F19jUUAfHP/AA4A/Y1/6N98C/8Afqb/AOLo/wCHAH7Gv/RvvgX/AL9Tf/F19jUUAfHP/DgD9jX/AKN98C/9+pv/AIuj/hwB+xr/ANG++Bf+/U3/AMXX2NRQB8c/8OAP2Nf+jffAv/fqb/4uj/hwB+xr/wBG++Bf+/U3/wAXX2NRQB8c/wDDgD9jX/o33wL/AN+pv/i6P+HAH7Gv/RvvgX/v1N/8XX2NRQB8c/8ADgD9jX/o33wL/wB+pv8A4uj/AIcAfsa/9G++Bf8Av1N/8XX2NRQB8c/8OAP2Nf8Ao33wL/36m/8Ai6P+HAH7Gv8A0b74F/79Tf8AxdfY1FAHxz/w4A/Y1/6N98C/9+pv/i6P+HAH7Gv/AEb74F/79Tf/ABdfY1FAHxz/AMOAP2Nf+jffAv8A36m/+Lo/4cAfsa/9G++Bf+/U3/xdfY1FAHxz/wAOAP2Nf+jffAv/AH6m/wDi6P8AhwB+xr/0b74F/wC/U3/xdfY1FAHxz/w4A/Y1/wCjffAv/fqb/wCLo/4cAfsa/wDRvvgX/v1N/wDF19jUUAfHP/DgD9jX/o33wL/36m/+Lo/4cAfsa/8ARvvgX/v1N/8AF19jUUAfHP8Aw4A/Y1/6N98C/wDfqb/4uj/hwB+xr/0b74F/79Tf/F19jUUAfHP/AA4A/Y1/6N98C/8Afqb/AOLo/wCHAH7Gv/RvvgX/AL9Tf/F19jUUAfmb/wAFG/8AgiL+yj8Jv+Cfnx38UeHfgj4N0fxF4b+HfiDVdLvYVl32d1BplzLDKgZ9u9XRW6fwV0H/AAat/wDKD74T/wDX5rv/AKd7yvpL/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831AH6JUUUUAFFFFABRRRQAUV+K/wDw0T/wWm/6IT8Kf/Bhon/y3o/4aJ/4LTf9EJ+FP/gw0T/5b0AftRRX4r/8NE/8Fpv+iE/Cn/wYaJ/8t6P+Gif+C03/AEQn4U/+DDRP/lvQB+1FFfiv/wANE/8ABab/AKIT8Kf/AAYaJ/8ALej/AIaJ/wCC03/RCfhT/wCDDRP/AJb0AftRRX4r/wDDRP8AwWm/6IT8Kf8AwYaJ/wDLej/hon/gtN/0Qn4U/wDgw0T/AOW9AH7UUV+K/wDw0H/wWk3bv+FF/Cvd/d/tHROf/KvR/wANE/8ABab/AKIT8Kf/AAYaJ/8ALegD9qK85/a6/wCTTvih/wBilqv/AKRS1+Tv/DRP/Bab/ohPwp/8GGif/LeuX+OH7QH/AAWDn+Cni6HxV8Evhha+G59EvU1eeK+0YyQ2ht3WZwF1Rm3LHub5VagD6o/4NNv+UK/gX/sN61/6Xy1+lFfmv/wadrs/4It+B1X+HXNa/wDS+Wv0ooAKK/PX/g5A/wCCjV9/wTt/4J9alceF9Yn0n4jfEK6Tw/4ani/11juIe7u0+6ytFbo6o6tuWW4iauw/4N3PjR4q/aB/4I4/BbxV4017VfE/iK8t9Utp9S1Cbz7q4ittXvbWDzJOrssMMSbm+ZtuW3Nk0AfbVFfmD/wdI/8ABTPUv2EP2IbXwr4L8Qah4d+JXxUu/sWnXunXQgvNN0+Bke8uEf7yMyskCsvzfv2ZWVkr6u/4JFfEHXPiz/wTH+BfiLxNq19r2vat4N0+a91G9l825vJfKCtJI5+ZnbHLN8x/i+bNAHvnjT/kTdW/685v/QGr8k/+DK//AJRYfED/ALKrqP8A6aNHr9bPGn/Im6t/15zf+gNX5J/8GV//ACiw+IH/AGVXUf8A00aPQB+wFFFFAFeQsZSpUbfccdv8TX87/wAEPhj+1j/wWD/4KM/tWaJ4X/a4+J3ws034S+M7mytbK01rUIrP7LJf3sFvFFDaXEEcflx2ifw/M3J+ZmNf0TSdVr+Z/wDYJ/4KT/ED/gnd/wAFK/21Z/AP7PPjL49TeLPiDex3q+H7i4ibQxBquqbC/lWV18svnNt3bP8AUN8zdFAPePGj/tff8EDP2sfgXc+O/wBozWfj38M/jF4ki8Pa1B4ivLu9/s8ebArmIXU0skcnlSs6PEypuiKyqV27u7/ay+Mn7V3/AAVp/wCCpPxS/Zz+BvxXh+Cfwz+DCW665renz3Ftqd5LiLf++gHn+Z5zPGsSSwxtHFKzM27bXlf7SH7Rfxo/4L8/tTfs1eDrD9mP4j/CvQfh/wCK7bxH4p1TxFFcfYbWJZIDMEle3gRVWKKbbu+eVmVQq7a9B/4IUeNtY+Hv7Zv/AAVA8WaB4UvvG3jXR/GEt5puhW0yR3WqTLqXiBzbq8hXbvfyuvXbxub5aAO2/Yv8W/ta/wDBL/8A4Kl/D/8AZz+L3j7xF+0N8Kvi7Y3sujeKtQgmmvNLuoop55S1xK0s3ymHa8UkrIsU6OjKyMlcD/wQ8/4LxeOPir/wUk+I3wN+NniqTWrPxZ4h1D/hB72e3iC6beQXEu7T9yL/AKqSJQybm+V4kUf62um+G/8AwcxfGu2/au+Evw9+MH7I/if4V2fxS8R22gaddarJf2l1IJ5orcy28V1aRify5LiFm2/wtt/ir8+fgD/wTu1T9qb9ln9qr4ufDyK4sfjN8BPik/ifQLuwY/bbi3geeeeCLb83mJsFxEVUszwbB96gD9Zv+CpP7c3xQ/Z9/wCCy/7J3w78KeJr7SfBfjS3vZPEGmeSjQapuZkzKSrMwjVdyhflVun3mr89v+CUf7M37ZX/AAWh+FHi34n2v7bfxY8C/wBmeJpdGnsf7c1Ty5Jfs8E5eKG3uYook/0hV2LGqrt4qz4q/wCCjujf8FPf+CkX7Afju1kt4/Flnp1xpfivSxOPO03U0llWU7V+7HKE81P4tkq5+avrD/gyn/5R1/E7/spVx/6a9PoAk/YI/bK/an/Ye/4K7+Ff2R/2lPHmi/FfS/Hvh+41fw5r9tbZuoFVLqSBnmKRO2/7Dco6yrK294tr7RX7Gw/6v/6+6vx+/wCCtWnTt/wcpfsMzaeAt5JbTrKVxuaFJp2fP/AGlr9gIR5carjG3igCSiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPn//AIKw/wDKLH9pT/slXij/ANNF1Xzb/wAGrh/40h/Cf/r813/0831fSX/BWH/lFj+0p/2SrxR/6aLqvm3/AINXD/xpD+E//X5rv/p5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/yad8UP8AsUtV/wDSKWgD4d/4NNv+UK/gX/sN61/6Xy1+lFfmv/wabf8AKFfwL/2G9a/9L5a/SigD85P+DiL/AIJsfDr9rz9lHxZ8WPGB16TXvgj4B8S3+gW1td+RYyXMtosqS3C7dz+VJbIyhWTlvn3rtUb/APwa9bf+HF3wN2/d/wCJ9jj/AKmDU6yf+Dh/49/GLwH+ypqXw7+FvwD8afGCz+L2h6p4c1jU9ChuLx/DontWiR/s9vHLK33t/wAyqnybd2568i/4Nfviv8dvBP7P9n8A/iV+zv8AEL4b+Gvhnpt3d2XjDxBZXGm/2rcXWqXV01v9nuoomb/j4PzQM+37P8+3zUoA6P8A4OYf+CaPw1+PH7L3jj9oDxImu3njb4W+CJrLRLWO+8vTRuuldZ5YsbnkRpHx8+z5vnR/l2/Un/BERt3/AASM/Z3ONq/8IPp+B7eUK+Y/+Dkj44/HCz/Z11D4O/DH9nnxx8VNB+KmgT2eqeI9At7jUP7DlSVWVPs1rFLIrYQNul2I27ah3K9bH/Buj8ffjb4o/ZksfhZ8Uv2efGfwh0f4T6FYaPpev67BNpra8Yxtk/0a4iimVtoDb03x/wAJZWHzAH6MeNP+RN1b/rzm/wDQGr8k/wDgyv8A+UWHxA/7KrqP/po0ev1n8VqyeB9UDszP9ilyTjc3yH0r8mP+DK//AJRYfED/ALKrqP8A6aNHoA/YCiiigCB12yMzNj69NvGf5V+VH/BBX9kv4lfs/wD/AAUT/bs17xp4P17w1o3jDxwkui3t5AqwaspvdTuhLE3/AC1VYr22O6P5F34PzLX6vUUAV9vycbV9Pl3fSvww+NOrfHn/AIIX/wDBXT47/FPwX+z/AOJPjV8Jv2gdmsq3h9bhfst2ZfPfzp4ra4+zyCeW7+SSP96s6ujZRlr916KAPws+DWsfHz/guR/wV3+BfxU8bfs6+Ifgr8K/gEJNUlbxB9okW8uwxlRre4uLa3WaVp4rXCxJ+6WBnZ+Ur6H/AODbj9k34ifsySftPL4+8H614SXxB8SJpbAahB5Y1OKPzt0sIHyvC25NrruVlY7WPWv1MooA/nz+J3/BDzxt+yV/wcR/DvxP8NfA+val8HPGetS+JYtQ0+zP9neFm8qZruzml/1duqNlovN2q0c6Im90bHI/8EVf2/8A4pf8EXvgf46+FHjH9lD45+KNYv8AxjPqks2l6NMlvbt9ntrUwg+U6y/Nblg6MysrDG4V/R1RQB+JH7I4+O3/AAWH/wCC1vw1/aM8afBLxd8FfhV8EtDubaxtPECS7tSuXS5CeU0sMDvK73KO2xGjjWz2l9zqzftjZq0dqit97FTUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP/wDwVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vq+kv+CsP/KLH9pT/ALJV4o/9NF1Xzb/wauH/AI0h/Cf/AK/Nd/8ATzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8mnfFD/ALFLVf8A0ilr0avOf2uv+TTvih/2KWq/+kUtAH5g/wDBsz+3p8DPgB/wSQ8FeHfHXxo+EngvxBb6vq0s2ma94u0/T72NHvXZS0MsyyLlcEbl+YFWr9Ao/wDgq/8AssKgH/DSn7P/AP4cLSP/AJIr8if+CBH/AAQO/Zr/AG+P+Ca/hT4l/Enwvr2qeK9S1LUbW4uLfXrq0i2QXbxphI2VR8qivs6P/g00/Yt2Lu8C+KN2Pm/4qu//APi6APqr/h7H+yz/ANHK/s//APhw9I/+SKP+Hsf7LP8A0cr+z/8A+HD0j/5Ir5W/4hNP2K/+hE8Uf+FXf/8AxdH/ABCafsV/9CJ4o/8ACrv/AP4ugD6p/wCHsf7LP/Ryv7P/AP4cPSP/AJIo/wCHsf7LP/Ryv7P/AP4cPSP/AJIr5W/4hNP2K/8AoRPFH/hV3/8A8XR/xCafsV/9CJ4o/wDCrv8A/wCLoA+jvF//AAVR/ZgvvDOpxx/tIfAdnks5EXyfiDpLOMow+6J/m5wABn5jX5lf8GlP7a3wb/Zt/wCCc3jPQfiH8Wvhl4D1i5+JV9ewad4g8UWGm3NxbtpelRJKsc0is0bSI671+XdGf9qvpjxJ/wAGpX7GWmaBfTQeCPEkc0Fs7xk+Kr1trBW2nG/5vmx1r4B/4Nsv+CJv7Pv/AAUq/Ya8VeOvit4b1jVfEGleO7zQbWW11q5s41tUsNOnRGSJ13fvLmTmgD9tI/8Agq/+yyiY/wCGlPgCv/dQ9I/+SKd/w9j/AGWf+jlf2f8A/wAOHpH/AMkV8rf8Qm37FknP/CC+KP8Awrb/AP8Ai68q/aa/4IHf8E3P2Of7E/4WRpfijw5/wkfn/wBnf8TvWrz7R5Hl+b/qFk27fOj+9jO7jODjowmDr4qqqGGg5ze0Yptuyu7JXbsk36EylGK5pOyPv7/h7H+yz/0cr+z/AP8Ahw9I/wDkij/h7H+yz/0cr+z/AP8Ahw9I/wDkivyr/wCHdP8AwSN/6CXij/wK8Sf/ABmj/h3T/wAEjf8AoJeKP/ArxJ/8Zr2v9UM+/wCgKt/4Kn/8iY/WqP8AOvvR+qn/AA9j/ZZ/6OV/Z/8A/Dh6R/8AJFH/AA9j/ZZ/6OV/Z/8A/Dh6R/8AJFflX/w7p/4JG/8AQS8Uf+BXiT/4zR/w7p/4JG/9BLxR/wCBXiT/AOM0f6oZ9/0BVv8AwVP/AORD61R/nX3o/VT/AIex/ss/9HK/s/8A/hw9I/8Akij/AIex/ss/9HK/s/8A/hw9I/8Akivyr/4d0/8ABI3/AKCXij/wK8Sf/GaP+HdP/BI3/oJeKP8AwK8Sf/GaP9UM+/6Aq3/gqf8A8iH1qj/OvvR+qn/D2P8AZZ/6OV/Z/wD/AA4ekf8AyRR/w9j/AGWf+jlf2f8A/wAOHpH/AMkV+Vf/AA7p/wCCRv8A0EvFH/gV4k/+M0f8O6f+CRv/AEEvFH/gV4k/+M0f6oZ9/wBAVb/wVP8A+RD61R/nX3o/VT/h7H+yz/0cr+z/AP8Ahw9I/wDkij/h7H+yz/0cr+z/AP8Ahw9I/wDkivyr/wCHdP8AwSN/6CXij/wK8Sf/ABmj/h3T/wAEjf8AoJeKP/ArxJ/8Zo/1Qz7/AKAq3/gqf/yIfWqP86+9H6qf8PY/2Wf+jlf2f/8Aw4ekf/JFH/D2P9ln/o5X9n//AMOHpH/yRX5V/wDDun/gkb/0EvFH/gV4k/8AjNH/AA7p/wCCRv8A0EvFH/gV4k/+M0f6oZ9/0BVv/BU//kQ+tUf5196P1U/4ex/ss/8ARyv7P/8A4cPSP/kij/h7H+yz/wBHK/s//wDhw9I/+SK/Kv8A4d0/8Ejf+gl4o/8AArxJ/wDGaP8Ah3T/AMEjf+gl4o/8CvEn/wAZo/1Qz7/oCrf+Cp//ACIfWqP86+9H6qf8PY/2Wf8Ao5X9n/8A8OHpH/yRR/w9j/ZZ/wCjlf2f/wDw4ekf/JFflX/w7p/4JG/9BLxR/wCBXiT/AOM0f8O6f+CRv/QS8Uf+BXiT/wCM0f6oZ9/0BVv/AAVP/wCRD61R/nX3o/VT/h7H+yz/ANHK/s//APhw9I/+SKP+Hsf7LP8A0cr+z/8A+HD0j/5Ir8q/+HdP/BI3/oJeKP8AwK8Sf/GaP+HdP/BI3/oJeKP/AAK8Sf8Axmj/AFQz7/oCrf8Agqf/AMiH1qj/ADr70fqp/wAPY/2Wf+jlf2f/APw4ekf/ACRR/wAPY/2Wf+jlf2f/APw4ekf/ACRX5V/8O6f+CRv/AEEvFH/gV4k/+M0f8O6f+CRv/QS8Uf8AgV4k/wDjNH+qGff9AVb/AMFT/wDkQ+tUf5196P1U/wCHsf7LP/Ryv7P/AP4cPSP/AJIo/wCHsf7LP/Ryv7P/AP4cPSP/AJIr8q/+HdP/AASN/wCgl4o/8CvEn/xmj/h3T/wSN/6CXij/AMCvEn/xmj/VDPv+gKt/4Kn/APIh9ao/zr70fqp/w9j/AGWf+jlf2f8A/wAOHpH/AMkUf8PY/wBln/o5X9n/AP8ADh6R/wDJFflX/wAO6f8Agkb/ANBLxR/4FeJP/jNH/Dun/gkb/wBBLxR/4FeJP/jNH+qGff8AQFW/8FT/APkQ+tUf5196P1U/4ex/ss/9HK/s/wD/AIcPSP8A5Io/4ex/ss/9HK/s/wD/AIcPSP8A5Ir5W/4hNP2K/wDoRPFH/hV3/wD8XR/xCafsV/8AQieKP/Crv/8A4uvnToPqn/h7H+yz/wBHK/s//wDhw9I/+SKP+Hsf7LP/AEcr+z//AOHD0j/5Ir5W/wCITT9iv/oRPFH/AIVd/wD/ABdH/EJp+xX/ANCJ4o/8Ku//APi6AOz/AOCmX/BTH9nHx9/wTo+P2h6D+0B8Eda1rWvhv4h07T9PsPHGmXF1f3Mum3McUMSJMzO7yMqqi/M26sP/AINYdv8Aw5E+E+1ty/bdd5/vf8Ti9rw39vP/AINmf2Sf2ff2G/jN478M+DfElr4k8E+Bdb17S538TXkyw3Vrp89xC7Iz7WXzIl4217n/AMGr/wAv/BEP4Tj5W/0zXeR/2F7ygD9EaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArzn9rr/k074of9ilqv/pFLXo1ec/tdf8AJp3xQ/7FLVf/AEiloA+Hf+DTb/lCv4F/7Detf+l8tfpRX5r/APBpt/yhX8C/9hvWv/S+Wv0ooAKK5H4t/Fjw/wDBHwBrni/xZrFn4f8ADPhuye/1LUbxtkFnDGNzMzYP/wAV90KuWqh+zj+0V4N/ay+CXh74ifD/AFy38ReD/FFu1xpt/AjxrIqyNG6sjhXSRJEdHRgGRkZW5WgDvaK+Sf2zf+C2f7Mv7BfxXHgT4ofEq30XxZ5CTz6ba6Te6lNaxSKrI032eGRUZlYEI3zMrK23bXs/7Mn7V/w+/bO+D9h48+GHibT/ABf4V1AusF7bB12yp96J4nCyJIv9xlVloA7vxp/yJurf9ec3/oDV+Sf/AAZX/wDKLD4gf9lV1H/00aPX60+L1x4K1Yf9Oc3fd/A1fkt/wZX/APKLD4gf9lV1H/00aPQB+wFflT/wc2f80S/7jv8A7ja/Vavyp/4ObP8AmiX/AHHf/cbX6J4Uf8lVhf8At/8A9NzODM/92l8vzR0H7Nf/AAQK+Dvxj/Zz8AeL9U8SfEuDUvFXhvTtYu4rXULJYI5ri1jmdYw1ozBAzkAFicYyT1rtv+IcL4H/APQ1fFb/AMGdh/8AIVfVH7Cz/wDGEHwbHT/ihtE5PT/jwgr4a/b2/bA/bm+Iv7b2pfB/9mL4R2fhrwz4RiiudR+IXjLT3/snWPNtVl2W8sq+U0au5iPlebJ5sZ3eUivujM+P+IqeMq04YuaSlJJXWyb8h08DQcE3FbHe/wDEOF8D/wDoavit/wCDOw/+QqP+IcL4H/8AQ1fFb/wZ2H/yFXzX8Nf+Cp37ZH7Bv/BQ/wCEvwk/a80X4a6x4W+OV6mkaNrnh0+UbW5aaKAYZPvKstxErpLEv+vVlkVVav2NsgRaxhtrHbg4XaPy7fSuH/iIfEn/AEGT+9f5F/UMP/Ij4G/4hwvgf/0NXxW/8Gdh/wDIVH/EOF8D/wDoavit/wCDOw/+Qq++J1+dd27DHt/L/PpX5Y/tXftaf8FAPj7+3R40+HX7Onwx0v4feAvh6n2Z/F/jnTJVs/FEjbf3lq8sWx4925VSBZPlAeV13Kqn/EQ+JP8AoMn96/yD6hh/5Eerf8Q4XwP/AOhq+K3/AIM7D/5Co/4hwvgf/wBDV8Vv/BnYf/IVfP8A+x9/wVR/a2+CP/BWfwX+yr+07o/w512++ImnPqllrHhstE+nQrbXkqMu35ZFaS0dGV1Rl3blbbt3e5/8EPf+Covjj9vnVPjp4H+K+n+HdI+JHwX8YzaRLZ6RbyxQR2bSTRRKXdv3kkctrcozKqZREym4tR/xEPiT/oMn96/yD6hh/wCRF3/iHC+B/wD0NXxW/wDBnYf/ACFR/wAQ4XwP/wChq+K3/gzsP/kKofjf/wAFQvHFr/wXc+Ff7LvgPTtG1Dwv/YNzrnj+6lgZrqzV7WeWGNX3/utuy2b7vztdItfcXjzxvpPwv8Fap4j8RalaaPoPh+xm1DVNQuZfJt7O3iQvLK7Z+VFVWbd/Cqmj/iIfEn/QZP71/kH1DD/yI/Mn9o7/AIJRfsgfsla/4N0r4g/Fb4keHdS+IWrxaF4etZLy2ml1K7ldI0RRHYNtXdImZH2ou7lhXrC/8G4vwQZc/wDCVfFX/wAGVh/8hV8f/wDBN7wlq3/BeH/gq/r37W3jrT7sfBX4N3g0n4Y6Pdxhobq6ibzI5Nn/AD0iLJdO23/W3Fum/wDcbR9if8HA3/BV+/8A+CUP7IFjrPhIaXP8SvGmpJpfhy3vovPt7dE/e3V08e5d0ccaqi/N/rLiP5du6j/iIfEn/QZP71/kH1DD/wAiG/8AEOF8D/8Aoavit/4M7D/5Co/4hwvgf/0NXxW/8Gdh/wDIVfUn7Bnx11L9p79if4T/ABG1mG0tdY8deEtM129htc+RHNc2scrhN3O3cxr1yj/iIfEn/QZP71/kH1DD/wAiPz//AOIcL4H/APQ1fFb/AMGdh/8AIVH/ABDhfA//AKGr4rf+DOw/+Qq+if8Agpd8edc/Zc/YI+LnxE8L/Zv+Ej8G+GbzVNN8+PzYlmjiLKWT86/Mf9lf40/8FXv2xv2fPCvxP8HeJvgCvhnxpZfb9PF9ZpBcLFuZfnTyW2/MrfxNR/xEPiT/AKDJ/ev8g+oYf+RH1f8A8Q4XwP8A+hq+K3/gzsP/AJCo/wCIcL4H/wDQ1fFb/wAGdh/8hV6x/wAEz9M/aq0jwR4ij/ak1b4a6n4ge/j/ALFHhW3dTHa7Pn85tqR/eB2bU/vZb+Ffkr/grJ/wXu1z9gr/AIKt/Bf4M6TaeHZvBepfYbnx1dXq7p4Ib66e3HlurfumgiUXH3fn3qtH/EQ+JP8AoMn96/yD6hh/5Eeu/wDEOF8D/wDoavit/wCDOw/+QqP+IcL4H/8AQ1fFb/wZ2H/yFX35b/6obfu9uMVJR/xEPiT/AKDJ/ev8g+oYf+RH5/8A/EOF8D/+hq+K3/gzsP8A5Co/4hwvgf8A9DV8Vv8AwZ2H/wAhV+gFFH/EQ+JP+gyf3r/IPqGH/kR+f/8AxDhfA/8A6Gr4rf8AgzsP/kKvzz/4KzfsUeFf2D/2jNF8IeENQ8QalpupeG4NYll1ieGadZnurqEqDFFGuzbAhAKk5Lc9AP6DK/FP/g49/wCT3/Cv/YjWn/pfqFfovhbxdnOY57HDY3ESnDlk7Pa6WhwZlhaVOjzQjZ3R+1lFFFfg57QUUUUAfP8A/wAFYf8AlFj+0p/2SrxR/wCmi6r5t/4NXD/xpD+E/wD1+a7/AOnm+r6S/wCCsP8Ayix/aU/7JV4o/wDTRdV82/8ABq4f+NIfwn/6/Nd/9PN9QB+iVFFFABRRRQAUUUUAfjb/AMRFn7YH/SNj42f+Aut//Kmj/iIs/bA/6RsfGz/wF1v/AOVNfslRQB+Nv/ERZ+2B/wBI2PjZ/wCAut//ACpo/wCIiz9sD/pGx8bP/AXW/wD5U1+yVFAH42/8RFn7YH/SNj42f+Aut/8Aypo/4iLP2wP+kbHxs/8AAXW//lTX7JUUAfjb/wARFn7YH/SNj42f+Aut/wDypo/4iLP2wP8ApGx8bP8AwF1v/wCVNfslRQB+Nn/ERT+2ADvb/gm38aFjX73+i6zu/wDTTS/8RFf7YH/SNn41H/t11v8A+VNfslRQB+Nv/ERZ+2B/0jY+Nn/gLrf/AMqa5f45/wDBfz9q3xt8EvGWj6l/wTw+MWh6frGhX1pdahcQav5WnxSW8iPO+7S1XYi/N8zL92v26rzn9rr/AJNO+KH/AGKWq/8ApFLQB8O/8Gniqn/BFzwOqtuX+3Na6j/p/lr9KK/Nf/g02/5Qr+Bf+w3rX/pfLX6UUAfjX/weCfFn4lTfs1eD/hT4J8K+JNV8NeLBf+J/F+padayXEMGn6T5EvlTbUZUiV5lnZ2ZNrWsXJ6V7l/wbqeM4/hx/wb0/DPxJNtmh8P6X4o1N0b+JYtb1aQ7v9khf0r6O/wCCx/8Ayih/aQ/7Jvr3/pBLXy9/wQB8H3PxB/4Nr/Avh+xXzL3XNA8W6fboOrPLq+rIo/HdQB89f8G3f/BP3wP+238B/iN+0x+0B4P8J/FTxj8XfFF4ttJ4m0yHVYLG3ib97KkUyMsUrT+au9fm8uCIKy5Za1f+CR3gO9/4Jt/8HBn7Q37M3hlpovhH4v0NPGujafLc+Z/Z77beVBD8/wAiot3cWzbl811t7dmJVNzeif8ABop8ZdH8Z/8ABMKfwOLiFPE3w58VajZ6rp7ELNbpcP58MjJ3RmeVB/tRP6VyH7JPxIg/ad/4OyvjV4j8JiHUvDnw78ADw9e6rbv59s1wn2GKVFkxtST7S0yBN3zfZZm/vUAfr14uk8zwTqrf9Oc3/oDV+Sv/AAZX/wDKLD4gf9lV1H/00aPX60+MCreCNWZejWUxH/fDV+S3/Blf/wAosPiB/wBlV1H/ANNGj0AfsBX5U/8ABzZ/zRL/ALjv/uNr9Vq/Kn/g5s/5ol/3Hf8A3G1+ieFH/JVYX/t//wBNzODM/wDdpfL80foB+wl/yZB8G/8AsRtE/wDSCCua/wCCgvxc+MnwQ/Z3u/EXwQ+Gen/Fnxxb3ttGNCu9U+wr9mZsTSrnHmsq4+TcnXf823Y25+wzu/4Ym+Dfp/wg2i9v+nC3xx3718Lftkf8HDHiT/gnT+1N408K/F79nH4gQ/DrR5420HxloDm5ttYhkUbXPnLFB95tuFn3Ky7dvFfGZx/v9f8Axy/9KZ10fgXoj4M/a4/aS+Pnxy/4K3/sd+IP2wPg2vwb8G6B4whi0BLBHnjublrq2kLPL57q379LPcPl2x722tX9G9v/AKkf47q/nj/bQ/4KJn/g4l/aI/Zv8G/BH4R/Ey30jwX48S/1zXdXsImtbGFmt97OYXliSNIkd23uu7aqhfmr70/4KMf8Exf2iP2l/wDgrZ8C/jB8P/iVH4a+GPgUaX/bWmSazdQOPsuoy3Vzi0T91N58TQxfMy7tm1/lVa840P0sr5g/4KaftBftAfs7/DXRNQ+APwZ0/wCMuuahqBg1GzudUFn/AGfbiJm8zYSvm7m+X7/y/wB019IjcjYKk84+8Sw5469e5/Cvyj/aH/4OXNX/AGB/2i/HHgv49fs2/Ejwx4f0jVZrHwz4j0aVLyDxFbI7eVcK9wIImWWPa/7uV9u5lZdytQB8k/Cf4y/Gr40/8HQf7Pvir9pb4awfBnxBc6Hc6doek2i/aILqFLLVPJZ5mmdWka5llHy/d2wrs/5aV79Pqcf/AATW/wCDrDUvtUz6X4G/ag8HvfzPJ+6s4b1IndnZ/u7/ALTpzs235l+3L/C1eU+Af2xrj/gu1/wXO/Zr+JXwz+GfxA0X4e/CG1ml1fWdZtolgiaPz5W3vEXiRWfyYl/ebmaT7i9a9q/4O+P2KfEHxx/ZZ+HHxO8F6LrGs+JPhnrzWVwmmQSz3UdjfIi+btQMzbbmG3Xd/wBNetAFX/g20sT+2p+3H+1n+2BqEf2pPF3iaTwp4allj2SWtgrLcMjL/Cy2yaUnr8jVb/4OCf2n/Fn7aH7Rngv9gj4HahnxR44uIrz4h6jEW8rQ9OULOlvOV+6nlD7RKp+8gt0+bzdte/fsW/D7xF/wR2/4IH6VNY+C9Z8TePvCfhCXxNe+HY4v9Mm1i8Jne2fYF3CF5ViZV3Osdvhd7ba4z/g3c/4JweKPg14G8T/tHfGu3vJ/j38dbmTULyTUoDFqGiafK/mi3cN80UssmJXTau1Ugi2rs20AfeP7In7LfhP9iz9nLwl8L/BNgth4c8IWQs4AQBLctlmlnlK9ZZZWeV27s7GvyU/4Oz/+CbPiD4q/D7xF+0xefESSHwv8K/C+maVpvhH7F5jPeXetRW803mbx5UbRXMWSqs7NAF+7X7cwNujr8ev+Ds3/AIKSeD/hb+yV4m/ZtvNC8YzeMviZpmnapp2qx6cq6PClrq1tcsjTO6s8m22cYiR9rSR7mXnAB97f8Edv+UUX7N//AGTjQv8A0gir6Sr83f8Ag3B/4KO+Fv2zP2IvC/w/8P8Ah3xnp198E/C+jeHNY1HUbFF0y/uIrVYmFtMjOrf6otsba21w2Kj/AGAv+Can7Qv7Pn/BYb48fGbx98Q7bxB8LvHn9pjQNKj1m6nlRbm/iubZGtnTyoltoEeD738a7aAPpn/grJ8LPEHxy/4Ju/HDwf4T0241rxN4i8HahZabp9tIqzXc7QPtjTcwyzYI2/xdK/J79h3/AINwP2rPE37LfhW48TftgfFf4GXs9qVi8D2Jv76HQ7fzG2RM0WpwRqzLtdolj/d7trHKtX7Pftaa3428KfsyfEDVPhnpUGtfEKw8P3tx4bspTmO7v0gdrdP7p3SbF2narYwzba/J34U/8Hf/AIb+E3w80nRP2g/gp8UvDvxYsoQutW+j6ZFbWszKX2ypFeXEU6KyrkoysFYt8zUAem/8G+37Q3xc8EftMftHfsr/ABo8ba18RtU+C2pxXWi+ItXumurqe0lldTvlkZ5Nr5t5kSSRmTzWQNtVa/M741fsyT/8FdPD/wDwUH/aytbePUo/BerW6+EboTv5E1jZSr9pdedrMmlW1u3zf89+Nvymvoj9jL4o/Fb4reGP+Cin7ZHhv4f+M9Hh+InhttM8BobD/S7zzFkiS6tx/G1rEtvK5TcrM21d7CpP2D/+DXv40+K/2M/Dl837VPxE+C9v8RdN/tTW/Adt4evo4IWuIlR4rlF1OBZJHgWJZFkgVtq7GHyUAfrf/wAEg/2rf+G1f+Ca/wAH/iFJdfbNS1LQILHV5GVo2bUbTNrdtg/3p4ZW/wB1u9fTMf3Bxivyb/4Ndfhh8Sv2WPAvx8+B/jzSPFVlpvwx8dGDRNQ1Kyaxs9QjlEiu9oG+ZkZbdLjK7o2W5X5m3Zr9Y4TujXd1oAfRRRQAV+Kf/Bx7/wAnv+Ff+xGtP/S/UK/ayvxT/wCDj3/k9/wr/wBiNaf+l+oV+q+Df/JSR/wT/I83Nv8Ad36o/ayiiivyo9IKKKKAPn//AIKw/wDKLH9pT/slXij/ANNF1Xzb/wAGrh/40h/Cf/r813/0831fSX/BWH/lFj+0p/2SrxR/6aLqvm3/AINXD/xpD+E//X5rv/p5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/yad8UP8AsUtV/wDSKWgD4d/4NNv+UK/gX/sN61/6Xy1+lFfmT/waleJNP0v/AIIweBYri/0+CYa1rBZJLhI2X/T5e1fpD/wmmk/9BXS//AtKAPj7/gsH/wAErfFn/BULwl4e0Tw98fvGvwcsNPjvLfVdO0y1N5pniK1nRVdLm3S4t2l+6F/eO6bXddnz7q4T/gjt/wAETPGf/BKbxJqH2z9pDxl8SPCM2nPY6d4RfSjp2i6ZK85madYpbu42uZGc/uPKyzszFs199/8ACa6T/wBBbS//AALSj/hNdJ/6C2l/+BaUAfmf+2z/AMGy/gv4+ftI6x8VPhT8UvG3wG8TeLJHfxFD4bQy2uq+bKstwyIksLRNPty252i3qreXX01/wS+/4JN/C3/glR8IL3wz8PLW81DVNcdLrWfEepeXJqOsun+qDuiKqRR5by4kXau5nO53Zm+lv+E10n/oLaX/AOBaUf8ACa6T/wBBbS//AALSgBPF0Sx+CdVjRdqrZzKAO3yNX5Lf8GV//KLD4gf9lV1H/wBNGj1+q/jDxppMnhTVFXVdPZvscuAlwjfwNX5Pf8GY+t2Oi/8ABL3x0l1fWdrJJ8UtQdVkuEXd/wASjSKAP2Kr8qf+Dmz/AJol/wBx3/3G1+oA8a6Tgf8AE10v/wAC0r8tf+DljW7TWP8AhSv2W6tbry/7c3eTMsm3P9nYzjpnB/Kv0Two/wCSqwv/AG//AOm5nBmf+7S+X5o/Qr9hL/kyD4N/9iNon/pBBXq1eL/sM+L9Mtv2J/g7HJqWmxyR+CNFVla6RWUiwgBBHY16l/wmuk/9BbS//AtK+Mzj/f6/+OX/AKUzro/AvRGtRWT/AMJrpP8A0FtL/wDAtKP+E10n/oLaX/4FpXnGhrUVk/8ACa6T/wBBbS//AALSj/hNdJ/6C2l/+BaUAa1FZP8Awmuk/wDQW0v/AMC0o/4TXSf+gtpf/gWlAGtRWT/wmuk/9BbS/wDwLSj/AITXSf8AoLaX/wCBaUAa1FZP/Ca6T/0FtL/8C0o/4TXSf+gtpf8A4FpQBrUVk/8ACa6T/wBBbS//AALSj/hNdJ/6C2l/+BaUAa1FZP8Awmuk/wDQW0v/AMC0o/4TXSf+gtpf/gWlAGtRWT/wmuk/9BbS/wDwLSj/AITXSf8AoLaX/wCBaUAa1FZP/Ca6T/0FtL/8C0o/4TXSf+gtpf8A4FpQBrUVk/8ACa6T/wBBbS//AALSj/hNdJ/6C2l/+BaUAa1fin/wce/8nv8AhX/sRrT/ANL9Qr9lv+E10n/oLaX/AOBaV+MP/BxXqlvq37bHheS2uLe5jXwRaKWhkEig/b9QOMjvyPzr9V8G/wDkpI/4J/kebm3+7v1R+2lFZP8Awmuk/wDQW0v/AMC0o/4TXSf+gtpf/gWlflR6RrUVk/8ACa6T/wBBbS//AALSj/hNdJ/6C2l/+BaUAeK/8FYf+UWP7Sn/AGSrxR/6aLqvm3/g1cP/ABpD+E//AF+a7/6eb6vfv+CrXirS7r/gmF+0hHHqVjI8nwu8TIFjnRmY/wBkXnFeAf8ABq9x/wAEQPhMP+nzXe+7/mMXtAH6J0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/wCxS1X/ANIpa9Grzn9rr/k074of9ilqv/pFLQB+CH/BEj/g2u+Bf/BST/gnx4b+K/jnxT8WdJ8Razf6haT2+harYQ2O23uXiTaktlK6/Kozl2+b+792vrf/AIgrf2Wf+h9+P3/g70j/AOVlerf8Gm3/AChX8C/9hvWv/S+Wv0ooA/IH/iCt/ZZ/6H34/f8Ag70j/wCVlH/EFb+yz/0Pvx+/8Hekf/Kyv1+ooA/IH/iCt/ZZ/wCh9+P3/g70j/5WUf8AEFb+yz/0Pvx+/wDB3pH/AMrK/X6igD8cvEP/AAZmfsv6Tod7PH48+PTSW9u8yLJrWlbW2rnoumbuuM4r4i/4N9/+Dfv4N/8ABV79jfxR8QviF4k+Jei6xo/jW68OQQeHtQsra2kt4rCxuEdvOs5maTfcv91lXaq/LX9K3jT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHoAI/wDgyz/ZZuI1dfH3x+2tyP8Aid6R0/8ABZXzV/wUS/4IrfC3/gj9/wAIf/wrTXvH+uf8LE+2/wBpf8JNe2dz5P2L7P5Xk/Z7aDbn7XJu3bs7Uxtwc/0K1+VP/BzZ/wA0S/7jv/uNr9E8KP8AkqsL/wBv/wDpuZwZn/u0vl+aPMfgt/waL/s3/tJ/Bzwn8Rtc8bfG611vx9o1n4j1CCw1fS47WG4vIEuJViV9Pd1jDyMFDMzAAZYnk9N/xBW/ss/9D78fv/B3pH/ysr9KP2Ev+TIPg3/2I2if+kEFerV8ZnH+/wBf/HL/ANKZ10fgXoj8gf8AiCt/ZZ/6H34/f+DvSP8A5WUf8QVv7LP/AEPvx+/8Hekf/Kyv1+orzjQ/IH/iCt/ZZ/6H34/f+DvSP/lZR/xBW/ss/wDQ+/H7/wAHekf/ACsr9fqKAPyB/wCIK39ln/offj9/4O9I/wDlZR/xBW/ss/8AQ+/H7/wd6R/8rK/X6igD8gf+IK39ln/offj9/wCDvSP/AJWUf8QVv7LP/Q+/H7/wd6R/8rK/X6igD8gf+IK39ln/AKH34/f+DvSP/lZR/wAQVv7LP/Q+/H7/AMHekf8Aysr9Qfi9+0V4F+A+qeG7Pxl4v8P+F7rxhqcWj6LFqV7Hby6reSsqJBCr/fdmdPlWu5t8mIFl2lucelAH5C/8QVv7LP8A0Pvx+/8AB3pH/wArKP8AiCt/ZZ/6H34/f+DvSP8A5WV+v1FAH5A/8QVv7LP/AEPvx+/8Hekf/Kyj/iCt/ZZ/6H34/f8Ag70j/wCVlfr9RQB+QP8AxBW/ss/9D78fv/B3pH/yso/4grf2Wf8Aoffj9/4O9I/+Vlfr9RQB+QP/ABBW/ss/9D78fv8Awd6R/wDKyj/iCt/ZZ/6H34/f+DvSP/lZX6/UUAfkD/xBW/ss/wDQ+/H7/wAHekf/ACso/wCIK39ln/offj9/4O9I/wDlZX6/UUAfkD/xBW/ss/8AQ+/H7/wd6R/8rK+Q/wBv3/gmB4B/4JN/GPTfhz8OdX8Ya1omtaNF4jnn8R3VtcXS3Es89uyq0EEKCMJaxkAqWyW+YggD+jqvxT/4OPf+T3/Cv/YjWn/pfqFfqvg3/wAlJH/BP8jzc2/3d+qOu/4grf2Wf+h9+P3/AIO9I/8AlZR/xBW/ss/9D78fv/B3pH/ysr9fqK/Kj0j8gf8AiCt/ZZ/6H34/f+DvSP8A5WUf8QVv7LP/AEPvx+/8Hekf/Kyv1+ooA/DP9tP/AINKf2b/ANmn9jf4ufEPQ/GXxtvNa8A+CtY8R2EWoazprWs1zaWE9xEkoSwRmj3xLu2srf7VfXX/AAav/wDKEL4S/wDX7rvT/sMXtfSX/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+oA/RKiiigAooooAKKKKACivyR/4ihvE3/RlH7SH/gtk/8Akej/AIihvE3/AEZR+0h/4LZP/kegD9bqK/JH/iKG8Tf9GUftIf8Agtk/+R6P+IobxN/0ZR+0h/4LZP8A5HoA/W6ivyR/4ihvE3/RlH7SH/gtk/8Akej/AIihvE3/AEZR+0h/4LZP/kegD9bqK/JH/iKG8Tf9GUftIf8Agtk/+R6P+IobxN/0ZR+0h/4LZP8A5HoA/W6ivyJn/wCDojxQ1+kP/DFP7RKpJGS3+hTLL/wEfZ6m/wCIojxMvy/8MT/tIf8Agulb/wBt6AP1wrzn9rr/AJNO+KH/AGKWq/8ApFLX5r/8RQ3ib/oyj9pD/wAFsn/yPXI/H/8A4OVfEXj/AOBPjTQ2/Y2/aE01dY0G+sHu7zT5EgtfNt3j8xz9n+4u7c1AHun/AAabf8oV/Av/AGG9a/8AS+Wv0or81/8Ag053f8OW/A+ev9u61/6Xy1+lFABRVW4Kpu3MuMd/bn8e1fkX+0d/wXM/aQ+P37Y3xC+Cf7GfwL0Hx7dfCjU5NI8R694juRHaNNE0sMsao1xax26+fE6RM87eb5TbV+agD9fqK/GvwB/wXB/a3/Yx/aV8BeD/ANtX4FeF/B/hH4mapFpem+JfDswaOxmY7QXZLu7gf52hLRbonVGeT5tu2v2QhP7v+L8RtoAz/Gn/ACJurf8AXnN/6A1fkn/wZX/8osPiB/2VXUf/AE0aPX62eNP+RN1b/rzm/wDQGr8k/wDgyv8A+UWHxA/7KrqP/po0egD9gK/Kn/g5s/5ol/3Hf/cbX6rV+VP/AAc2f80S/wC47/7ja/RPCj/kqsL/ANv/APpuZwZn/u0vl+aPv39hX/kx74Nf9iRon/pBBXwJ/wAFCf8AgsL+0ZqH7d2ufs3/ALIPwXsPH3jLwJbQXvizV9d/48LdZ7eOWNEzcW8Ma7JU+eaf523Isfybm+/v2Ev+TIPg3/2I2if+kEFcv/wUT/aa8dfshfs1at44+Hvwh8SfGvxJYXFvDB4c0STbcFJGZXuMKkkjIg7RRSv83Kqm6RPjM4/3+v8A45f+lM66PwL0R8A/s0/8FoP2p/gJ+278Nfgv+2V8GPCfgX/hcF8mneGdZ0K/Ro4bhmWNEdVu7qObdO9vH/rEkXzd3zV+u1qcwLznj+9u/XvX84f7Rf7efj7/AIKFf8FhP2MT+0B8D/Fn7NOg+E/F0cukweIILy3bVJmu7WYYe5trfdG09vaRNtX5fMDblzX9H1v/AKlfp6YrzjQbK+3r+Gemc8V+Rv7Yn/BZn9qj4nf8FDPG3wH/AGOvgzoPji5+FsHleKtS8RnZH9oO3/VStd2sECLnaolcvKyvtXbHX68V8pf8FTf23vil+wz8MNB174X/AAA8XfH7UNU1E2V3ZaE77tJh2blleKGGeeXc3yjZF5a/xurbFcA+RP2Df+C0f7SFl/wUb0D9l/8Aaw+D/hrwT458cWE2paFqHh25SSCCCO1uJVM0KXFwsqSGzlCukqsrLtZNrbk9/wD+CM//AAVS17/go9Z/GLR/G3hrRfCfj74QeMrnQ77StNneVUtTLOtsTvJ/eL5E8TOPlkaBmCpnaPy++A/7X3xB/bd/4Og/2evGfxW+E3iL4A69baBc6bbeHNdgvIrq6hSw1ho5V8+3gfbJLK6/d2fIfmZvlr6L+Ck0P/BOz/g678feETNHpvg/9p7wsfENraxIsUC3uyS5aeXd/wBPFlqn3f4rnmgD62+PP/BVfWPBP/BZz4R/sp+GPCVrr1r4o0afXPFusSSssmlwrb3kkSJj5V2/Z1d9/wB5ZURfmavtTWNZtfD+iXmoXlwtrZ2Vu9zcTyt8sMShmZ2z0VVUmvx2/wCDfGAft3f8FUP2tv2vJl8/Sr7V/wDhDvC05Jbfars2tuP8S2drp4/7b12H/Byb+2t4s8YXvgz9i/4Ly/bvip8eJYrbWVXldN0hy6MjsuWTz9jtIxVtttBKdvzq1AHkv7Kel6l/wcIf8FodS+O2tQTSfs4/s236WHgu33bYtW1GJ0njdkOVfzJALmRvl/drZxsp3V92f8Fx/wDgqn/w6Z/Y6XxhpWnaTrXjvxFfpo3hiwvmb7I85RpJZ5kRlkMEUcf3VZdzvEu5d25fav2AP2KPCv8AwT3/AGUPCPwp8JoP7P8ADtoEub14ljm1W9fma7cj+OSTc2P4VZV/hr8n/wDg7n/4J6fEb40+H7z9oKbxdodv8KvhD4W0+zsvD0m/+0JNTv8AWUtbl1XZ5aI0c1ozStJu/cbdn8VAH6+fsU/tA3H7Vn7IPww+Jl1psej3Xj7wvp+vz2MbtJHavc28crRq7KpZQX4bHNerV82/8EdP+UUP7N//AGTfQf8A0gir6SoA8P8A+Civ7RGsfsl/sO/Fb4maDbafea14H8N3er2MF6jSW8lxFEzIJVVlbZu2n5WU1+VvwA/4KSf8Fav2n/g54f8AH/gP9n/4Ja14P8UW/wBs0u+F3aW/2iHcVz5c2tJIvzKfvqGr9KP+CvfgTXvir/wTG+PXhvw3pd9rWt6r4M1CC0sbWHzJ7l/JJ2on8bEZ2qvzM3yqN1fln/wTg/4JI/t+eIP2MfAsx/ae8TfAjT/sjR6V4IudLla60ezDssQuEUo0Tvu37DuZFdd+1tyqAfph/wAEuvH37WXxF+GfiG8/au8C+BPAviFdRVNGsfDd550sltsG+Sbyri6iHzfc2S7/AL25UG1m8J/4KX/8F3o/2Cf+CnHwT+BsOjaLqWh+MWsn8XancOyy6TBfXbWsBi+ZU+VUeV92fl2Vi/8ABAr9t74zePvjL+0B+zf8evEUnivx78D9WSKw16SNI7nVbJpZYmdwFXcg2QSo7bmZLpA2dvzfk7+2/wDAfVP+Cr/xE/b6/aaslvbrSvg/qmn6f4ZjhuM215ZQXS2csq7sfc0+2a4aL5drXJ+833gD+qaP/V/406vBf+CYv7Ty/tnf8E/vhH8TDcQ3V74o8OW0upPEcquoRL5F6n/ALmKZP+A171QAUUUUAFfin/wce/8AJ7/hX/sRrT/0v1Cv2sr8U/8Ag49/5Pf8K/8AYjWn/pfqFfqvg3/yUkf8E/yPNzb/AHd+qP2sooor8qPSCiiigD5//wCCsP8Ayix/aU/7JV4o/wDTRdV82/8ABq4f+NIfwn/6/Nd/9PN9X0l/wVh/5RY/tKf9kq8Uf+mi6r5t/wCDVw/8aQ/hP/1+a7/6eb6gD9EqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArzn9rr/k074of9ilqv/pFLXo1ec/tdf8mnfFD/ALFLVf8A0iloA+Hf+DTb/lCv4F/7Detf+l8tfpRX5r/8Gm3/AChX8C/9hvWv/S+Wv0ooAgfCsWyq+5/z92vwV/4JY/t1fDb/AIJSf8FZ/wBtvwn8ftauPh5qHxK8drqOj3F9YzSWc0CXmrXKu8sSvsWSK+hdCyhW3fer97XbB/x6V+Z/7dn/AAUu/YU8Y/tjaz8C/wBpHw1or+JvAqwMuq+L/DCXWnK80Hni3iu0WWVP3UqP8ypGzHbvLfLQB8F/8HUf/BWb4Bftv/s0eB/h38K/GkfjfxH4f8Vxa5eXVjaSrZ21v9iuoGTznVVd2eWJvk3L/tV/RNH/AKv5a/m1/wCCul9+yD+2B4q+C/7P37G/hLwfP4y8aeObSXWdV8IeGvJa3tvKlhCNMyKzKv2lpmUZSNbcs+zZX9ItmpFuoZQnH3R91fYe1AFLxp/yJurf9ec3/oDV+Sf/AAZX/wDKLD4gf9lV1H/00aPX62eNP+RN1b/rzm/9AavyT/4Mr/8AlFh8QP8Asquo/wDpo0egD9gK/Kn/AIObP+aJf9x3/wBxtfqtX5U/8HNn/NEv+47/AO42v0Two/5KrC/9v/8ApuZwZn/u0vl+aPvj9hfP/DEvwb9P+EH0T5j6fYLfI/z6V8f/ABf/AODkf4Mfsrftn+Pvg/8AGbRfGfw1k8HzBLPXLiwl1C11xDtZJYkhRpVVlYMvystfZH7CX/JkHwb/AOxG0T/0ggrY+NP7NXw3/aJsY7X4g/D/AMFeO7WDHlQeIdCtdTSPv8q3CMq18ZnH+/1/8cv/AEpnXR+BeiPwy/4LBf8ABS/4P/8ABYr9pf8AZL+HfwB1zWPFniCx+IUFxc3X9gXVuunpJLapu2TojvtUNK235FSB2Zq+1/8Ago3+yp+2B8Uv+Cvn7P8A44+EfirWtL+BOgLp/wDwlVrb+K/sFnbiK/eW+NzZeaGuvPtHjiXYknKfN5Y+Y/c3wb/Y/wDhJ+zffTXHw7+Fvw68CT3LfvZPDnhqz0x5OMfM1vEu78a9MjGxAv8Ad4rzjQqAt8vH3uq7fmzx7+/Nfmvdf8HQXwJ+E37THxI+GPxi0nxp8Jda+H+sS6XFNqGmy6hDqyI7ATItvG0kSOmyVdyfMkitur9Na83+Nn7I3wn/AGkJ7eX4ifDH4fePpLP/AFJ8Q+HbPVGh/wB3z0bbQB+MvxT/AG+/h1/wVi/4OGv2Rbj4H6pqniHR/ANte3GrauukXVr5fyTyuhEyo2zYiruKKn7/AO8+7avZf8HifwU1zRPhP8Gfj54Vm1DStc+HWvzaLcXti22WGG8iEsUpb+BUktnT+6zXW05+Wv1o+C37KXwu/Zu+0/8ACu/hv4D+H/2xt1wvhvw9aaX9o7fP5Ea7q6vxh4K0nx3oc+m61pem61p9xs820v7VLiCTa25d0brtO1hke9AH54f8EstE0/8A4I7f8G+Wh+N/FWm3c1xpnhq5+IOt2dvbNbXd1cXn7+G3YP8AdlWF7e3Yt/zz3cYrzD/g3O/Y58T/ABh8Y+Nv24vjRbpdfEz423Ez+GVdvl0rR2Kq0yI33N6okMX92CJP4ZWr9ZdV0Oy13R5NLvrKzvLG4j2Pb3ECyRSL/dMbfeWrmnWcOlWUNvBHHDBbqscUcaBUjQcBVA6KBQBPDu8td33u9fk5/wAHWH7evwr8D/8ABP8A+IfwD1LxVHF8V/HGn6PqWlaDHazytJbRa3ZzNI8wTyYfkt7ggOwZvL/3a/WavMfjn+x78Jf2ltSs7z4jfC74d/EC+02NobOfxJ4ctNUltUY7ikTzxuyLu+b5aAPlb/ggD+3N8Lf2of8Agn/8NPAvgzxVDq3iv4T+DtD0bxRpj2s1tNps62iREfvUXzI98Uib49ysy43VxH/BPn9l79sD4b/8Fjf2g/G/xW8TaxffAXxK2of8InaXPiZb6zmSW/iexFvYqzNatb2itE5ZIvmb70q/NX3Z8FP2Zvhv+zPol5p/w48A+Cfh/Y6hOLm6tvDei2+lw3UoGwPIkKIrvt+XLc16BHu2Dd97vQB5j+1l8TPEXwd/Zf8AiF4v8G6H/wAJT4o8OeHr7VNJ0oFtupXMVu8kMXyfM251Vdq/M273r88P2T/+Dsn9mf4g/ADw/q3xX8TXngX4iTWxTWtFs9A1O+tbeZXZd8EkUTq0bqokXc29VfaelfqxJ8wZf8n25rxjx5/wTo/Z8+KHiO41rxR8B/g34j1i8/19/qfgrTby6lb/AGneFmb/AIE1AH4vfsaftoz638U/+Cm37ZHg23uP+EZi0Q6X4UvXt3QXtw26K0l2sFZdqw200in5lWdd1Y3/AAS9/wCCBf7SnxW/4JvabfeFv2lB8MvAfxv0ubUdU8IJpLzw3ltdRNb7pm3jd59qE/h4V19K/fDwz+z94F8D/DeTwXofgvwpo/g+SN4n0HT9It7fTWR/vp9nRAm1vlzx2FddY2qWNnDDGojjhQIiAYCqBgLQB+RP/BpZ4z8QeCvgn8dPgP4jvri61L4H+OpbBIPJ/wBHs0nedHRG2fxXVrdO25m27vurX6+2/wDql+bd71kaZ4W03RtV1C8tdPs7W71SVJL2eKBY5bt1UKpkdfmbaqhRu/hAWthOlADqKKKACvxT/wCDj3/k9/wr/wBiNaf+l+oV+1lfin/wce/8nv8AhX/sRrT/ANL9Qr9V8G/+Skj/AIJ/kebm3+7v1R+1lFFFflR6QUUUUAfP/wDwVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vq+kv+CsP/KLH9pT/ALJV4o/9NF1Xzb/wauH/AI0h/Cf/AK/Nd/8ATzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8mnfFD/ALFLVf8A0ilr0avOf2uv+TTvih/2KWq/+kUtAHw7/wAGm3/KFfwL/wBhvWv/AEvlr9KK/nT/AOCHn/BBHRf28/8Agnl4Y+JV58cvjL4Hm1TUdQt20rw9qKQ6fB5FzLGHVWXjONx/2ia+vo/+DTvw6F+X9qL9pAdv+Q1Ev/slAH63V5D+0f8AsL/B39r2ewn+J3w08F+OrrSlaOzudY0mK5ntkbqiSsu9ELc4Vq/PH/iE78Of9HSftIf+DyL/AOIo/wCITvw5/wBHSftIf+DyL/4igD9A/wBnv/gn58Ev2TtXudS+Gvwr8B+CdUul2SXukaPb291JHjHl+cqeYI/bdXs6f6uvyV/4hO/Dn/R0n7SH/g8i/wDiKP8AiE78Of8AR0n7SH/g8i/+IoA/Vjxp/wAibq3/AF5zf+gNX5J/8GV//KLD4gf9lV1H/wBNGj1J4j/4NUPDum6BqEg/ae/aLkaK3lk2vrKMjfKevyc+jf7Jr4b/AODeX/gifo//AAUp/Y08UeOr74xfFj4eSaX41u9BGmeFr9LW1mSKwsZ/Of5Pmlb7TsP+yi0Af0wV+VP/AAc2f80S/wC47/7jaxov+DT3w46Bl/aj/aQI9RrcXP8A45XzF/wUi/4JO6b/AMEvv+EM/s/4pfEj4lf8Jx9u8z/hLL5br+zvsn2fHkbVG3zPtJ3Z6+WnpX6J4Uf8lVhf+3//AE3M4Mz/AN2l8vzR+237CX/JkHwb/wCxG0T/ANIIK9Wr8a/gh/wbKaD8e/gv4Q8dTftH/H7Q5vGmiWWvPpunaxHHZ6e11Ak5ghUplY0L7VB6KorqP+ITvw5/0dJ+0h/4PIv/AIivjM4/3+v/AI5f+lM66PwL0R+tlFfkn/xCd+HP+jpP2kP/AAeRf/EUf8Qnfhz/AKOk/aQ/8HkX/wARXnGh+tlFfkn/AMQnfhz/AKOk/aQ/8HkX/wARR/xCd+HP+jpP2kP/AAeRf/EUAfrZRX5J/wDEJ34c/wCjpP2kP/B5F/8AEUf8Qnfhz/o6T9pD/wAHkX/xFAH62UV+Sf8AxCd+HP8Ao6T9pD/weRf/ABFH/EJ34c/6Ok/aQ/8AB5F/8RQB+tlFfkn/AMQnfhz/AKOk/aQ/8HkX/wARR/xCd+HP+jpP2kP/AAeRf/EUAfrZRX5J/wDEJ34c/wCjpP2kP/B5F/8AEUf8Qnfhz/o6T9pD/wAHkX/xFAH62UV+Sf8AxCd+HP8Ao6T9pD/weRf/ABFH/EJ34c/6Ok/aQ/8AB5F/8RQB+tlFfkn/AMQnfhz/AKOk/aQ/8HkX/wARR/xCd+HP+jpP2kP/AAeRf/EUAfrZRX5J/wDEJ34c/wCjpP2kP/B5F/8AEUf8Qnfhz/o6T9pD/wAHkX/xFAH62UV+Sf8AxCd+HP8Ao6T9pD/weRf/ABFH/EJ34c/6Ok/aQ/8AB5F/8RQB+tlfin/wce/8nv8AhX/sRrT/ANL9Qr0D/iE78Of9HSftIf8Ag8i/+Ir43/4KF/8ABPay/wCCa/xo0vwLY+PvG3xEh1bRIteOpeKLpbm8gaSe4g8hGUACMC3DAf3pH9a/VfBv/kpI/wCCf5Hm5t/u79Uf0aUV+Sf/ABCd+HP+jpP2kP8AweRf/EUf8Qnfhz/o6T9pD/weRf8AxFflR6R+tlFfkn/xCd+HP+jpP2kP/B5F/wDEUf8AEJ34c/6Ok/aQ/wDB5F/8RQB92f8ABWH/AJRY/tKf9kq8Uf8Apouq+bf+DVw/8aQ/hP8A9fmu/wDp5vq+Uv23/wDg2f8AD3wB/Yx+L3jhf2ivj5r0ng3wVrGvJpt/rETWmpNa2E8/2eYbMtHJs2t/ss9fV/8Awavf8oRPhPzu/wBN13n/ALjN7QB+iFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP+xS1X/0ilr0avOf2uv+TTvih/2KWq/+kUtAHw7/AMGm3/KFfwL/ANhvWv8A0vlr9KK/Nf8A4NNv+UK/gX/sN61/6Xy1+lFABRRRQAUUUUAZfjT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHr9bPGn/ACJurf8AXnN/6A1fkn/wZX/8osPiB/2VXUf/AE0aPQB+wFflT/wc2f8ANEv+47/7ja/Vavyp/wCDmz/miX/cd/8AcbX6J4Uf8lVhf+3/AP03M4Mz/wB2l8vzR+gH7CX/ACZB8G/+xG0T/wBIIK9Wryn9hL/kyD4N/wDYjaJ/6QQVzP8AwVB+ImufCb/gnR8d/E/hvULrSPEHh/wHrN/pt7bPtms7iOylaKdG/hZGXd/wGvjM4/3+v/jl/wClM66PwL0R75RXwv8A8G6XxU8RfGv/AII0fBXxB4o1vUvEGuXEGq2r3uoTm4uJobbWb+2hRyT82yCONP8AdVfSvlRf+C+f7Vnx+/as+NHgP4Dfsv8Ah/4iab8HPEs2gX87a0yzxqlxcwRSuXaJcy/ZJmVV3bdu35vvN5xofsnRX52/sO/t1ftufGz9pTRfDvxg/ZS0n4d+A7hJn1DxBH4hRm08pFuRgm9/NZpPlCbV+9u3fJXoH/BM/wD4KwW//BQP46/tBfD268Ip4P8AEnwJ8VzaE8T3rT/2rbC4uoEnPyL5Um+0fenz7eKAPtKivif9pX/grlZfAj/gq78I/wBmGx8IzeIr/wAe6Ld67rOqx6gsR0O3jt7yWILEybZGIs5nfc6bU2N833a+GP2bf+Dhz9s/9uPwvrnij4M/sleHfGPhTSNSk09p4dXffbyqiy+S+6VN8giliPyL1b/gNAH7f0V+aX/BM7/gvpf/ALWH7Wh+APxk+C3ij4G/GOS0uLyysNQndrbVlgi8xwqzpFMjsiTSIqrKjJE7eZX6Qu+0pJvHlfxEt/Djr+g/M0AR6nrNrpHlm7uLe3WWVYkMsnl7nbog9TV6P7vXdX4d6X4y1j/g4Z/4LgaLqGgXl4v7Mv7KOoJqMGp2c7eR4g1WKVXilTp8088S7du7bbWu7KNMu79mvid8SdE+Dvw51rxR4m1az0jQNAsJdQ1C/um/dW8Mabnkb2VfzyBQB1lFfn3/AMEcf+C4Wmf8Fb/HXxqtbHwcvg/w/wDDO6tH0u+k1Hz5NUsZ3ulSWZdieS2LUuyfNtWXbubbub51+Lf/AAcsfE74pfFbx0v7Lf7OuqfGn4Z/C+NTr3infcIlxtb5zbpEjbVZQ2wfPIyq0uzYtAH7HUV80/8ABMD/AIKZ+Bf+Cp37NVr8Q/BS3GnyQytaazot2ytdaLeKFZomI+V12sGV/l3KVO1c7R9KR8DG3FADqKK/P3/goh/wXI0P9hD/AIKO/Bf4C3XhmPW4viY9r/beqtqPkN4fivLprO1cRMm1181Wd8uPkU0AfoFRUcGVQA/zzUlABRRRQAV+Kf8Awce/8nv+Ff8AsRrT/wBL9Qr9rK/FP/g49/5Pf8K/9iNaf+l+oV+q+Df/ACUkf8E/yPNzb/d36o/ayiiivyo9IKKKKAPn/wD4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9X0l/wVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vqAP0SooooAKKKKACiiigD8a/+I1z9nP8A6Jn8bP8AwC0v/wCTKP8AiNc/Zz/6Jn8bP/ALS/8A5Mr9lKKAPxr/AOI1z9nP/omfxs/8AtL/APkyj/iNc/Zz/wCiZ/Gz/wAAtL/+TK/ZSigD8a/+I1z9nP8A6Jn8bP8AwC0v/wCTKP8AiNc/Zz/6Jn8bP/ALS/8A5Mr9lKKAPxr/AOI1z9nP/omfxs/8AtL/APkyj/iNc/Zz/wCiZ/Gz/wAAtL/+TK/ZSigD8a/+I139nX/omfxs/wDAPS//AJNo/wCI1z9nT/omnxs/8A9L/wDk2v2UooA/Gv8A4jXP2c/+iZ/Gz/wC0v8A+TK5b45f8Hi37PfxU+CPjDw3Z/Dv4xW994i0O+02CS5stNWGN57d403Fbxm27jzha/b2vOf2uv8Ak074of8AYpar/wCkUtAHw9/wad7v+HLngfK7W/tzWv8A0vlr9J6/Nf8A4NNv+UK/gX/sN61/6Xy1+lFAGfq19HYQSTTSKkcKmVyf4QqlvTnox/Cvwj/Yh8dftvf8F5bn4h/F7wX+0o3wR+Guh+KJ9C0XRLDTN0kaolvOEZUUbtsE8TNI8rszswCqu2v3U8TXEFnpV5NPC1xDHbu8saruaQKM42/xN0wPev5rv+CEXhD9t7X/AIX/ABG8Rfsh6r4L8N/CC48YXludH8X3cF0tterFaycHynl8xbV7dGk3Kr7f71AH27/wT5/as/aW/Yq/4LJ2/wCyT+0J8VrP4xaP488MTa14Y1hbPZeW8kSXE+S6xq6747S7V4pGf5ootkincr/sRDu8sbuvfjFfz5fse6T8ePgh/wAHNXw1vv2wPsfiT4heNPDOow+FNY02WH+zbGJoLxIvJRET5VVLqHytqyr9q3Pndub+g6Hb5a7W3L2oAzvGn/Im6t/15zf+gNX5J/8ABlf/AMosPiB/2VXUf/TRo9frZ40/5E3Vv+vOb/0Bq/JP/gyv/wCUWHxA/wCyq6j/AOmjR6AP2Ar8qf8Ag5s/5ol/3Hf/AHG1+q1flT/wc2f80S/7jv8A7ja/RPCj/kqsL/2//wCm5nBmf+7S+X5o++P2G0aT9iD4OBfvf8INomOdv/LhB3x9a/LD/gsT8d/+CkH/AArH9oHRf+FK/Chf2eW0bU7efxDbarb3F4uheQ/mzjzb9JWl8ndu/wBD+9u2qy7Wb9V/2Ev+TIPg3/2I2if+kEFcj/wVQ8C6t8S/+Cb/AMetA0DT7zVte1jwBrVnZWNohknupnspVijRV+ZmZ+B/vGvjM4/3+v8A45f+lM66PwL0R+Pv/BB343f8FDNE/ZB+C+h/Cf4N/CvXf2e49Tu4rbxDrWox2109o2r3TXzSbb7z12TNcKrLZu3yLtST+Lhf2RP2XP26tb/4KNftjad+zprmn/B2w1L4hXt5rur+KtO8nT7/AGX+oyWkVvLJZXDS5S5kfMa7WRomf5WSv1S/4Nuvh3q/w3/4IqfA/SvEWlaho+ofZtWufsl9btBP5NxrN/PC+xvmCyQSRuvqrKa4zwp/wcW/Czwj+3J8bPg78blt/gzcfDDV/seh6lqss80fiO2U/NKVSLbCWUxSp8zb45Vb+CvOND52+Bf7Zv7Z/wDwTV/4Kb/B34Q/tcfEHwL8TPBnx2d9O0zVNKgSKPT7vd5SIkq2lq+9p5bZXR0ZGWVGVt26tLUo3/4J+f8AB2db3kn2i28J/tVeE/IMvEdvHfeUPl/66Nc6Yn+1/p1eZ/8ABT39qr4a/wDBVf8A4LF/sKeG/gp4w0nxz/wiPig6rq9xZeY0FrCt5Z3ToSybTIsGn3DcH+7XrH/B338ENUtv2X/hP8dfC80lj4q+DXi6Ly9Qg+WWziu9rLOo+7uW7trXbnu7UAYH/BKSCX9uv/gtz+2V+0jcLP8A2D4LtZPAnh+SRt0O3C23mpt+b5YNPLnH/P4c/NWz/wAGVDbv+CdnxObGN3xJuDx/2C9Pr1z/AINnP2Vm/Zw/4ItaLql3B5Gr/E/+0PGF4P70UqGC1/76toYX/wCB18W/8GqX/BS74DfsW/sNePvDvxW+JnhnwTrGoeOZtRtbTUi/mzW76fYxeau1W+UvEy/8BoA+gP8Agp3of/CH/wDB0X+xf4o02O4k1LXNDn0e6AVfL8lG1BWccfe8u8l3f7KpXon/AAcgf8FDfEHwc+Emg/s4/CDztW+Onx8I0i1tNPlzfafpsr+U8yqv3JJ3DwozbVVVunDboq+Q/wBtH/gqX8Mf2i/+C9fwj+KXgXXY/F3wn/Z58Baj4h8R61p1jN8rxxX7vEjS7FZXkl0+3R1UfvbrZubO2vcP+Df79l3xR+2t+0X40/b3+OFqreIvHlzLZfD7TblNyaRYDdbNcRBx8o8v/R4mULuXzm+bzqAPvL/glJ/wTy8P/wDBMP8AYt8M/DPRlhutWhRtT8S6nGvOtarKF+0TZx91dixRqfmWKKMNubLV+d//AAWA/aL8Y/8ABYL9urR/2GfgXqjQ+FdHvEvvi14hi3GC3W2lR3g3fdZLY7dy/wDLW5eBOBE1fsF8UPDeqeOfhV4i0nRdYm8O6trGl3Frp+rLE0kmkzyxMsNxs3KzNFIyvt3L937y1+Mf7Nv/AAbCftK/sd6v4g1D4Y/tgx+D9Q8VtH/bE1h4elSXUtjO6CRmnbndLIf+B96APn//AIJ4eF4f2P8A4f8A/BXHwr4Hnu9N0/4f2V94f0aY3Ba6t7W3udftYmEv31kWLawYdXVWr9T/APg2w+Dmj/B3/gjZ8HzpUEaXXii3ufEOpShNrXFzcXUvzN/uxpFFn+5Atflv/wAEdv2IfiV8ffj/AP8ABST4X33xIj1bVLjT9W8I67cXNguzxTrst7qKW+pyyffhVZ4Z32r95bpv7lfQ3/BC7/guX8Gf2U/+CfY+D/x+8WT/AA/8efBS51DSJ9O1TTpftN9Ct1PKiRJEjfvYstbtB95Wi53b+ADwr9jDxZqHwj0j/gsNc+C9Q1HwvBoN5qEmkfYLlrdtNxqOtxxGHb8yOsa7Fdfu4HzLXzRqvwA+MXw7+Gf7GepWv7Q3xWguP2ytRuNN1mCDxRexw6eF1W2tYX3b18391eQufMVv3iPtbbivpf8AYf8ADWtfGX/gm9/wU4/aYuNKvNG8L/HRtWu9Bt7mJo3kRZ9QvJXRz8rrHJepF8m795FKu7iub+M3/JBv+CLv/Ywz/wDp80KgD7P/AODf3VfHn7N3/BRP9qz9mPxJ8QPFHxA8KfDmW0v/AA9Prl29y1mkjt8qF2Yp5sdxDuC/KzRMwVS1fm5/wUk+F/iD/gp9+0n+3B+0ZodxrEml/s96rpek6LFBwt1bwXbWLyoV+bbHFa3F0235lEu5tvf7M0L9paP9jz/grR/wU8+Jm6Nbjwj4Jt7qwEr7Y5L14rWK1T/gc7xJ/wACr5//AOCZ/wDwR1/bv+Iv/BN+aP4W/FT4UeBvhH8fLC6u9S8O64XN/qNvcRG1Lyt/Zk7J5sCKyeVPwrqw2MzUAfvh/wAE8P2mY/2x/wBhv4U/ExGj+0eMfDdpf3qRy+YsN3sCXMQb+LZOsqc/N8vODXtlfkT/AMGkfxc13T/2Zfix8C/Fl9Z/258B/GE+nvZquWs4rl52ceZu+dftcN7ztr9c4/8AV/N170APooooAK/FP/g49/5Pf8K/9iNaf+l+oV+1lfin/wAHHv8Aye/4V/7Ea0/9L9Qr9V8G/wDkpI/4J/kebm3+7v1R+1lFFFflR6QUUUUAfP8A/wAFYf8AlFj+0p/2SrxR/wCmi6r5t/4NXD/xpD+E/wD1+a7/AOnm+r6S/wCCsP8Ayix/aU/7JV4o/wDTRdV82/8ABq4f+NIfwn/6/Nd/9PN9QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP+xS1X/0ilr0avOf2uv8Ak074of8AYpar/wCkUtAHw7/wabf8oV/Av/Yb1r/0vlr9KK/Nf/g02/5Qr+Bf+w3rX/pfLX6UUAZPiOx/tXR760+VftEDJ852ryG/+vmv5/8A/glT+118dP8AggF8M/GHwS+JH7JPxa8XrqXii48TWuteHLeS5t7jfb2tsyIyQvE8e203qyybl3bWVfvV/QtRQB+IP7Oeo/Hz/gsH/wAFqfg58d9b+BXiv4M/Cf4L2F7bCfxF53m6kzJcKrL5sMPmSyvNCrLGrRxoj/O22v24tgUgXd97vzu5qaigDL8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9frZ40/wCRN1b/AK85v/QGr8k/+DK//lFh8QP+yq6j/wCmjR6AP2Ar8qf+Dmz/AJol/wBx3/3G1+q1flT/AMHNn/NEv+47/wC42v0Two/5KrC/9v8A/puZwZn/ALtL5fmj9AP2Ev8AkyD4N/8AYjaJ/wCkEFerV5T+wl/yZB8G/wDsRtE/9IIK9Wr4zOP9/r/45f8ApTOuj8C9EFeF/tC/8E5PgL+1R4yXxF8SPhL4E8Za8sSW39oano0NxdSQr0RpCu5lX/x2vdKK840PCvgD/wAE4/gP+yv4ubxB8N/hF4A8G+IJIXt/7Q0zSIoLpYm+8iy43orf7NelfFj4S+Gvjn8PdR8J+L9D0nxJ4d1iLyb3TdStlura6TIba6N95eK6uigDH8N6BYeGPD9jpel2drp+m2ECW1nbQRpHFawINqIiL8oRV+UAdq+aPH3/AARF/ZM+Kfie81vXPgN8PbjVdSuXu7mdbFrdriaRy7u/lOoZmZmP419X0UAeH/C3/gnV8Bvgh8P9e8J+FfhD8PtC8O+KIfsutWMGiQeTrEOOYrrcp86PH8Eu5favV/Bfg3Sfh54T07QdA0vT9E0PSIEtNPsLC2S3tLKGMbUiiiQBURVAAVRgVs0UAFQyjcf8/LU1FAHH+Bvg14T+HHijxFrWg+G9F0bWPF10l5rV9ZWSQT6tcIixpLMy/M7KiKvzf3a8t+NP/BMr9nv9of4hy+KvHPwY+G/ifxJcBBPqOo6FbzT3Hl/KplO397tU4+fdhcCvoKigDjLH4L+ENM+E0fgK38M6Bb+Cf7NOjpoEVnGunrZbPL+zrbqoTytny7cfdrKb9ln4cyaL4H07/hB/Craf8M5Yp/Cdv/Z0Ri8OvGnlo9quP3TKnyjbXpFFAHmniD9ln4beKNS8YXmo+B/Cd5efESzTSvFM0+lwyyeIrWNGjSC7LL++jVHb5W6fhXZ+H/D1j4R0Ky0vTbGz07T9PgS2tbW0txBBbxIuESKNflVV2/Ko+6K2KKAOO8EfBvwh8LvEPiLVvD/hnQ9D1bxZdC+1u70+wSCfVp1QIJpigzK20BctXXx/cFOooAKKKKACvxT/AODj3/k9/wAK/wDYjWn/AKX6hX7WV+Kf/Bx7/wAnv+Ff+xGtP/S/UK/VfBv/AJKSP+Cf5Hm5t/u79UftZRRRX5UekFFFFAHz/wD8FYf+UWP7Sn/ZKvFH/pouq+bf+DVw/wDGkP4T/wDX5rv/AKeb6vpL/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831AH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/7FLVf/SKWvRq85/a6/5NO+KH/Ypar/6RS0Afg1/wQ7/4JwftXftFf8E8/C/in4T/ALW+rfCPwbeajqEVr4ci0l50tZEuJVllDrKud7Kzfd/ir6//AOHNP7fX8P8AwUF11R2A0J//AI9Xon/Bpt/yhX8C/wDYb1r/ANL5a/SigD8kf+HNH7fn/SQbXv8AwRyf/HqP+HNH7fn/AEkG17/wRyf/AB6v1uooA/JH/hzR+35/0kG17/wRyf8Ax6j/AIc0ft+f9JBte/8ABHJ/8er9bqKAPyF8Q/8ABHT9vOw8P381x/wUA1qZIbd3KPob7WVV3HLeadv3RXwx/wAG9f7A/wC0t+1J+xn4o174L/tRap8E/Ctl4zu9OutCttNe5W8u1sLGVrv/AFq7d8UkSf8AbKv6TfGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPQBpL/wRo/b6/h/4KDa7+Ghyf8Ax6vmH/gpD+xp8fv2R/8AhDf+F5ftB6h8dv8AhIPt39ifabFrX+w/J+z/AGjGXbd53mw+mPIHXNf0GV+VP/BzZ/zRL/uO/wDuNr9E8KP+Sqwv/b//AKbmcGZ/7tL5fmjz/wCCP/BJv9tz4j/Bfwh4h8J/ty614R8La9ollqOjaFHozyLotlNAkkFoG80bhFGyx5wM7OldR/w5o/b8/wCkg2vf+COT/wCPV+jH7CX/ACZB8G/+xG0T/wBIIK9Wr4zOP9/r/wCOX/pTOuj8C9Efkj/w5o/b8/6SDa9/4I5P/j1H/Dmj9vz/AKSDa9/4I5P/AI9X63UV5xofkj/w5o/b8/6SDa9/4I5P/j1H/Dmj9vz/AKSDa9/4I5P/AI9X63UUAfkj/wAOaP2/P+kg2vf+COT/AOPUf8OaP2/P+kg2vf8Agjk/+PV+t1FAH5I/8OaP2/P+kg2vf+COT/49R/w5o/b8/wCkg2vf+COT/wCPV+t1FAH5I/8ADmj9vz/pINr3/gjk/wDj1H/Dmj9vz/pINr3/AII5P/j1frdRQB+SP/Dmj9vz/pINr3/gjk/+PUf8OaP2/P8ApINr3/gjk/8Aj1frdRQB+SP/AA5o/b8/6SDa9/4I5P8A49R/w5o/b8/6SDa9/wCCOT/49X63UUAfkj/w5o/b8/6SDa9/4I5P/j1H/Dmj9vz/AKSDa9/4I5P/AI9X63UUAfkj/wAOaP2/P+kg2vf+COT/AOPUf8OaP2/P+kg2vf8Agjk/+PV+t1FAH5I/8OaP2/P+kg2vf+COT/49R/w5o/b8/wCkg2vf+COT/wCPV+t1FAH5I/8ADmj9vz/pINr3/gjk/wDj1fHP/BQv9mf4vfsq/GjS/D3xq+MV58bvFN5okWo2uu3NobZrSyae4jS0ClmyFkimkzn/AJbHjiv6NK/FP/g49/5Pf8K/9iNaf+l+oV+q+Df/ACUkf8E/yPNzb/d36o77/hzR+35/0kG17/wRyf8Ax6j/AIc0ft+f9JBte/8ABHJ/8er9bqK/Kj0j8kf+HNH7fn/SQbXv/BHJ/wDHqP8AhzR+35/0kG17/wAEcn/x6v1uooA/EP8Abb/4JQfts/Dn9i/4wa/4r/bk1rxd4Y0HwVrGoavoT6RJGutWUVhO9xalvNbb5sasn/Aq+qf+DV3/AJQhfCbt/puu/wDp4va+k/8AgrD/AMosf2lP+yVeKP8A00XVfNv/AAauH/jSH8J/+vzXf/TzfUAfolRRRQAUUUUAFFFFABRX5e/8Rev7HX/QU+In/hMP/wDF0f8AEXr+x1/0FPiJ/wCEw/8A8XQB+oVFfl7/AMRev7HX/QU+In/hMP8A/F0f8Rev7HX/AEFPiJ/4TD//ABdAH6hUV+Xv/EXr+x1/0FPiJ/4TD/8AxdH/ABF6/sdf9BT4if8AhMP/APF0AfqFRX5e/wDEXr+x1/0FPiJ/4TD/APxdH/EXr+x1/wBBT4if+Ew//wAXQB+oVFflw3/B3n+x55+3+0viMOPvf8Iy3y/+P1JH/wAHen7He3/kKfET/wAJl/8A4ugD9Q685/a6/wCTTvih/wBilqv/AKRS18B/8Rev7HX/AEFPiJ/4TD//ABdcX+0L/wAHXf7JfxJ+A3jjw7pepfED+0Ne8Pahp1qJPDbJG009q6Jubf8AL8zUAenf8Gm3/KFfwL/2G9a/9L5a/SivzX/4NOP+ULHgX/sOaz/6Xy1+lFABRXD/ALQng/xN8Q/gn4t0PwZ4o/4QnxZq2lXFnpGvfYxd/wBj3LxMsVz5TkK+x9rY/wBmvzA1D/gj7+3ZoGlzXVx/wUK1q1s7ONpZZX0F1WFEVmZm/ffKqqpoA/Xeivxn/wCDXz9ov9oX9qb4mfG/XPiF8WNc+Jvwp8MXKaBol9qW1l1LUFldmktTndEogMTMpb/l5gr9l0zs560AZnjT/kTdW/685v8A0Bq/JP8A4Mr/APlFh8QP+yq6j/6aNHr9bPGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPQB+wFflT/wc2f80S/7jv8A7ja/Vavyp/4ObP8AmiX/AHHf/cbX6J4Uf8lVhf8At/8A9NzODM/92l8vzR+gH7CX/JkHwb/7EbRP/SCCsf8A4KLfGDXP2d/2FPjJ488Mzx2/iDwf4N1PV9MeWJZIkuoLWSSJmU/e+cL+VXv2Goy/7Enwdz93/hBtDA59bCAHt/n2r8o/+CwP/Bav47f8K6/aA+D7fsa/Eyx8E3Gkar4ek8b3hu/slvaSQvEdQbybR4PK2usny3H+8w+6vxmcf7/X/wAcv/SmddH4F6I+9v8Agg5+0v4w/bE/4JQ/CP4hePtWbXPF2s2+pW9/qRiSGS6W11S9s4ndU+UP5UKbj/E2418c+Ov+Dmb4rah+058VPh/8I/2PPHHxgs/hT4huPD+o6jomoXt5KrxTzwCWRLWwn8hZWtrjZub5thb+8q/Pv/BB/wD4K/8Axy+C37JHwa+C/hP9kP4gfEDwdb6nd2cfjTTp7qKzmiutWupppleS0+yKIHmdP3t0ibovneP5mXzf9hz40ftgfAj/AIKXftraD+y/8ItD8b654i+Ilxd+I28TEQR6TBFf6s1uN8l1axq8q3MjjczbhFwtecaH6Xf8E/v+CwH7RH7Xn7UGl+CfHn7E3xU+Evhu+gmluvFOp/bIbLTWiDMrOt3Z26PuYqqqkjPk7tj7fl90/wCCfP8AwVU8J/8ABQn4p/GrwbpOgaz4b8Q/BPxNLoGqWt+6v9sj+0XMEVymB8u5rSbKdUx/FXxz+y3/AMFoP2oPhB+3l4B+Bv7aXwk8H/DwfGE/ZvCusaDcp+6ut3lokrR3l1FJ5k2yJQrJIjyo21lddvOeE5JP2Af+DsjWtLl8y38H/tV+FftkUYiEUEN8sLMzOc/OxudPuf8AwN/i+8wB91/G/wD4Kl+D/gr/AMFLPhP+zL/Yesat4y+JunTalLdwSL9n0aFYbt4Wf+KRna0n3KPuLsf+Ovmv9u//AIOO7L4K/tWah8E/gL8HfFX7SnxC8P8Amr4ht/Dsk5h0t4jtmt0EFtcSTTRNt83aixxsdhYurKvkf/BLbUf+G5P+DhT9rD9oS886bwz8JbWTwVoKzw7hHIrfZfNhk3HYvlWN0/8A2/fw/drQ/wCDPyO2+JfwJ/aA+LF1ZW6+K/G/xJuFv7gRbpmi+zxXSxb/AO6JbyVqAPdv+Ccf/BfrS/21viF4q+G/jr4T+NPgz8XPB+i3Ouz+G9XYyrdwQffWNpYoZ0nCsp2SRL977zV80/Dj/g6P+Pnx18PSeIvh3+wd8SPG3hT7RLDDqujXuoahbNsb5kaWDTHjVlX7y7m2tx2r7c/aj/4Jc+F/Gn7d6ftUR+IvEFn4k8K/D/VfDj6LAIm0/VPMtblI5Zf4m2pczKyNvDsIG+Tyv3niP/Bof83/AAR0035t3/FW6t/6FFQB6p/wS8/4Ls/D3/gpd8S9b+HsXhHxp8Nvif4bsTqOo+HfEMKKyxK6JK0T7tzbPNTd5kcbfN92vuF5vsi+ZI3lpGhZ9zfKvc/984H51+P3x91b/hUH/B4z8IXsVi2fEX4bSQ6rj7zbbTVtnp826wt/X5a77/g5C/b98SeDPAXhj9ln4Otdal8bvj5JHppt9PP+kabpMztFIc7W2faGV4g/y7IknfK7M0AeV/s/fH3xx/wXH/4LlJ4u8F+KNc0T9mP9l+4/0eawndbHxZf7nAc/wv8AaG3N824JbWy42PPub9Bv+Co//BTDwh/wSp/ZUvPiV4q0+51iaa8j03RdFtZhHPq17KrusW9l/doqpI7vtYqqH5WYqrX/APgmB/wT08L/APBND9jvw18MPD4tZ7m1j+3a/q0Mfltrepyoonum/wBk7QiL/BHHGvzbd1fkF/wdvfBP48fHT4nap4qn0C6034BfA/wxY39nqZn22uoalqOoW1nMO2Z900S7fm2x27NuXzdtAH7mfsu/HfT/ANqP9m/wH8SdJs7zTdN8faDZeILW1utvn20d1Ckyo+0su5d+Dg16FXzf/wAEeDu/4JR/s3/9k40L/wBIIa+kKAPAP+Cmf7bNv/wTn/Yk8d/Ga60KXxNH4NhtmTS4rj7M15NcXUFpEGl2tsTzJlLHa3yrX5teD/8Ag5V/ak8feFdO13w//wAE8fixr2h6xbJfafqenHWLqz1CGRd6TQyppJV0dTuVlONpr6o/4ObtPn1b/giL8c4bW2uLqdYNGuCkMLSsqRa5YSu+B/CqqWZv4VG5uK+A/wDgn7+2R/wVEv8A9iv4Zx/CH9nP4b6l8NNB8OWGlaBe628VrealaWsKwJcbLjVbeR1lVdyyJEqurLsyuGIB+r//AATN/bH+In7bvwEuPFHxK+B/jD4D69banLZDRPECyxy3UKqpFxEJYop9nO354k+ZflLCvOv2if8AgtX4H/Zx/wCCp3w3/Ze1nS7yTVfiBYRSSa+b2GOz0q9undLKzaNsNI0rRMu7K7WlgXa/mt5WH/wRD/4K1+JP+ClfhT4keHfiJ4N0/wAD/Fj4N6vFofinT7GZ2tWdxKiypu3eUwltbtGi3y7fK3b/AJttfhZ+2FoHjD9t/wCLv7U/7dHhG+K6T8Jvidotvol0sf2i2vbSKQ2sE6tj70McOlv/ALtwaAP6x7X5oQV3/Nz82c/rU1ed/spfHvTf2pv2aPAPxJ0keXp/jvQLLXIo/wCKH7RCspib/aRmKn/aU16JQAV+Kf8Awce/8nv+Ff8AsRrT/wBL9Qr9rK/FP/g49/5Pf8K/9iNaf+l+oV+q+Df/ACUkf8E/yPNzb/d36o/ayiiivyo9IKKKKAPn/wD4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9X0l/wVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vqAP0SooooAKKKKACiiigDzX/hkf4S/wDRL/h3/wCE5Zf/ABFH/DI/wl/6Jf8ADv8A8Jyy/wDiK9KooA81/wCGR/hL/wBEv+Hf/hOWX/xFH/DI/wAJf+iX/Dv/AMJyy/8AiK9KooA81/4ZH+Ev/RL/AId/+E5Zf/EUf8Mj/CX/AKJf8O//AAnLL/4ivSqKAPNf+GR/hL/0S/4d/wDhOWX/AMRR/wAMj/CX/ol/w7/8Jyy/+Ir0qigDzI/sefCOWXzF+Fnw53qu1X/4RuyO3/xyn/8ADInwlj4/4Vb8O1/7lyy/+Ir0qigDzX/hkf4S/wDRL/h3/wCE5Zf/ABFee/tWfsn/AAt0/wDZb+JVxb/DTwDbXVv4W1N4ZY9AtEeNxZykFW2cfga+jK85/a6/5NO+KH/Ypar/AOkUtAHw7/wabvv/AOCLHgU/9RvWv/S+Wv0or81/+DTb/lCv4F/7Detf+l8tfpRQAV+bv/BzX+3Refso/wDBP268EeF5LqT4jfHS6bwhodrZZa+a3cJ9ulhRfnf906QfL92S6ir9HX5bp93B5+7X5K+Lv2UPiF/wUE/4OSZfFfxC8Ia1pvwV/Zl0u1Phma/sJF07XdSeGO4jkidk8uWRbi4MrbG+X7HApoA+2f8Agk5+w/Z/8E8f2Bvh78MYY4v7Y0ux+267KhLLNqlwPNuX552LIWiT/pmiV9KqNopkH+qHb8d1SUAZfjT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHr9bPGn/ACJurf8AXnN/6A1fkn/wZX/8osPiB/2VXUf/AE0aPQB+wFflT/wc2f8ANEv+47/7ja/Vavyp/wCDmz/miX/cd/8AcbX6J4Uf8lVhf+3/AP03M4Mz/wB2l8vzR+gH7CX/ACZB8G/+xG0T/wBIIK4P/grrpt1rv/BML9oSx0+zur28u/h7rcUUVvD50sv+gyjair8275j+RrvP2Ev+TIPg3/2I2if+kEFemzxrPuU7SvQgpke/5g18ZnH+/wBf/HL/ANKZ10fgXoj4K/4Nn9B1Dw//AMEQPgbDeW09ncSQazMsc0bI/ly65qMkTgHorI6OrY+ZSvtW94D/AOC5v7Ni/tO/Fj4X+JvFFp8JvE3w51n7FfzeMvI0K01yXlDcWrzOrS/Kigs6qzJsZNyMrV9q6bYw6VYQ21vGkFvbosUcajaqIvAWvlX9sX/giX+zD+3Z8Q5vF/xM+Fmm6x4ruti3Gs2d9d6beXmxEiTzmtZU87bHGiL5u7aqKK840Pzd/wCCx37SXw//AOCgX/BXX9gnw/8ABrxl4b+JUmg+Lvt+qP4d1S31BLOH7fp0775I2bYywWlw7fN91K9F/wCDuf4V+IvBnwg+Cf7RXgea+03xt8HPFkcMep2u3/iXJcbZYZmDjayrdW0K/MGX9/hhtavtf9jX/gif+zP+wH8TG8XfDD4Y2uleKhG0EWq3upXepz2asuH8g3EsiwsykqzRqrsrbfu17n+0d+zf4M/ay+CmufD34geHbHxP4Q8SWwt77TLlTGsiqwZSHXDxNG+x0dGV0ZQy/MtAHwf/AMGs37LK/BT/AIJLaPrWrW0yaz8YL+98TXzyy+ZLLbufs1t0/hkgtxKO/wC+bPzV8wf8GyX7WXw1/wCCdXhL49fs/fGjx54V+G/jTwp8QLq63eItTg0m3vgtvHaP5MtwyR7lazZtu77si1+2/wAO/AmifCvwFo/hnw3pdnomgeH7OLT9N0+0iWK3s7eJAkUSKvAVVVVH0r5w/bM/4Isfsz/t+eNv+El+J3wv0/VfExASTVrG6utLvLlVVVUTS27p5+1Qqr5m7aqhV+7QB8++Lv8AguBo/wC0J/wUXn/Z7+D8PhP4ieAJvh7q2ta74y0bVluo9Puktp2jSNlPlNEmyJGxv3PeJ9xYnZvEv+DXf9u74Hfs/f8ABKvT/D/jz4xfC3wPrkfijU5jpuveLbDTLxYi0bI/lSyo7K3+781foZ+x1/wSi/Z8/wCCf8epH4UfDPRPDFzrVubG/vpbi41K7vLdmDNC811JJJ5TMqfIG27v4a8G1j/g13/Yl1zVrq8m+ENxDJdSmZhB4p1WGFSWLMqIlyqov+yqhV7UAfAH7Wf/AAUT+E3iL/g5C0T4+aD4o0nxd8Nf2f8A4X3NxrmpaVOZ7a8uPsuowQ29tMo2PI91q1pCr7tokfbu3Ltr6E/4N5P2VPFv7Vfxs8cft5fG23W48YfFC5mg8DWMqEjRNM3GNpolbopjRLeH5d3lRO5Lefur7U+F3/BFP9l74K/BPX/hv4f+D/hqDwh4sktn1m3uJbi6n1f7PcLcwpcXErvPLHHMoYIz7Ocba+nPCPhbTfAfhbTdE0extdL0fR7WKysrO2iEUFrBGoRIkQfdVVAUD2oA04N3ljd97vX5nf8AB0z+0T4D8N/8Eofit8ONQ8ZeF9P+IHiSDRrzS/Dk+pQrqeowprlg7vFbbvMdVWKViVVvliev00r5G/bQ/wCCJH7NP7ffxe/4Tr4o/Dxda8VNax2b6ha6readJPFF9zzRbyosu1dq7nDYVVWgCD/gh98ZfCfxY/4JafBC38L+JNE8RXHhbwVo2h6zFp96k7aXew2EG+1uNpbypV3L8jbW5ryX/gkj+3r+0X+1J+3L+0Z4J+Lfg2bQvA3gDVZ7fwzeN4fn00tsvHiji81/lm3QBJd3fdu+6a+lP2G/+CZ/wV/4Jv8AhzW9L+D/AIHt/C0PiKeKbU7iS6uL67vWiVhGrTXDvJ5aFmZUVlRWkdh8ztX0DbRrHAiqu1VGAB/DQB5R+2h+0PoP7JX7Lfjr4keKNL1DWvD3gvSZdR1CysrdZ57uFeGiVGZU543bm27d27C14n8Cf+C6f7J/xr+EPh3xRH8bfh74TXWrVLhtF8R65aabq+mu3DQXFu0vyyK2VO3crY3KzKVavrHxH4fs/FOlXenala299pt9G0NzbXSLLBPG42ujo+VdWBxtZdtfC3jT/g2O/Yo8d+KLzVrn4Nrp819Jvkt9N8RapY2y+yQxXCxov+yiqtAH5j/sN/ti2/wH8Kf8FYPj/wCHdRVdB1bXXi8K6lbL5sN5e6nqWsJYyxPj5tn2uF22t8qyKzLXA/sRfAL/AIKBeG/+CXmrfCX4b/s7eC9b+D3xq0y41Z9W1CayTUdRh1G2RUug7ajHtZYkiaJmi3LsT5ea/eLwD/wSl/Z3+F/7MWqfB3RfhP4Zh+HOuXkN/qejXAlnj1S4idHie4llZpZWVoo8b242hR8vFe8+GvDen+DPDtho+l2dvp+l6XbJaWVvCoSK1hQBURQPlVVVU20Afl9/waaftFah4v8A2EvE3wZ8TRyWPjL4A+J7rQ7qwnl3XVraXEsksayr/Cy3KXsO3oqwLX6tR/cFeZ/CD9lT4d/APxp4y8ReCfB2i+Fta+ImojVPEdxYxeS2r3gyfNdfueYWZ2ZlHzMzMfmYmvSoAPJCquF6D6UASV+Kf/Bx7/ye/wCFf+xGtP8A0v1Cv2sr8U/+Dj3/AJPf8K/9iNaf+l+oV+q+Df8AyUkf8E/yPNzb/d36o/ayiiivyo9IKKKKAPn/AP4Kw/8AKLH9pT/slXij/wBNF1Xzb/wauH/jSH8J/wDr813/ANPN9X0l/wAFYf8AlFj+0p/2SrxR/wCmi6r5t/4NXD/xpD+E/wD1+a7/AOnm+oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/5NO+KH/Ypar/6RS16NXnP7XX/ACad8UP+xS1X/wBIpaAPh3/g02/5Qr+Bf+w3rX/pfLX6UV/Nd/wRj/Zq/wCCi3xI/YJ8N6r+zr8bPh/4I+Ftxf3y2Gmaqlv50Mq3Mq3Dtu06duZAW++3ysOn3a+rx+xX/wAFjv8Ao5n4Tj/gNr/8paAP2ior8W/+GK/+Cx3/AEc18Jf++bX/AOU1H/DFf/BY7/o5r4S/982v/wApqAP2kor8W/8Ahiv/AILHf9HNfCX/AL5tf/lNR/wxX/wWO/6Oa+Ev/fNr/wDKagD9kPGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPXH+IP2MP8AgsImiXxvP2l/hW8CwP5oT7OrMm3cdu3SF+bjH/Aq+M/+CCX7PX7eXxX/AGRPEWrfsu/GTwL8P/h/b+Mrq31HTdZWLzZ9TWws3lnUNp118jQvaIvzr8yfcH3qAP6fK/Kn/g5s/wCaJf8Acd/9xteY/wDDFP8AwWNh+Vf2m/hOyr8udtt8356NR/wxX/wWO/6Oa+Ev/fNr/wDKavouE8//ALFzWlmfs/aez5vdvy35ouO9na177Psc+Ko+2pOne1/8zl/hN/wX1+MXwc+Ffhnwhpfhv4aT6b4V0q10e0lutPvWnkht4UhRpCt2qlyqAkhQM5wB0roP+Ij344f9Cr8Kf/BZf/8AybVj/hiv/gsd/wBHNfCX/vm1/wDlNR/wxX/wWO/6Oa+Ev/fNr/8AKavtqnHnDtSbqTyaDbd2/aPd/wDcM41ga6VlWf3f8Er/APER78cP+hV+FP8A4LL/AP8Ak2j/AIiPfjh/0Kvwp/8ABZf/APybVj/hiv8A4LHf9HNfCX/vm1/+U1H/AAxX/wAFjv8Ao5r4S/8AfNr/APKao/144b/6EsP/AAY//kCvqeI/5/P7v+CV/wDiI9+OH/Qq/Cn/AMFl/wD/ACbR/wARHvxw/wChV+FP/gsv/wD5Nqx/wxX/AMFjv+jmvhL/AN82v/ymo/4Yr/4LHf8ARzXwl/75tf8A5TUf68cN/wDQlh/4Mf8A8gH1PEf8/n93/BK//ER78cP+hV+FP/gsv/8A5No/4iPfjh/0Kvwp/wDBZf8A/wAm1Y/4Yr/4LHf9HNfCX/vm1/8AlNR/wxX/AMFjv+jmvhL/AN82v/ymo/144b/6EsP/AAY//kA+p4j/AJ/P7v8Aglf/AIiPfjh/0Kvwp/8ABZf/APybR/xEe/HD/oVfhT/4LL//AOTasf8ADFf/AAWO/wCjmvhL/wB82v8A8pqP+GK/+Cx3/RzXwl/75tf/AJTUf68cN/8AQlh/4Mf/AMgH1PEf8/n93/BK/wDxEe/HD/oVfhT/AOCy/wD/AJNo/wCIj344f9Cr8Kf/AAWX/wD8m1Y/4Yr/AOCx3/RzXwl/75tf/lNR/wAMV/8ABY7/AKOa+Ev/AHza/wDymo/144b/AOhLD/wY/wD5APqeI/5/P7v+CV/+Ij344f8AQq/Cn/wWX/8A8m0f8RHvxw/6FX4U/wDgsv8A/wCTasf8MV/8Fjv+jmvhL/3za/8Aymo/4Yr/AOCx3/RzXwl/75tf/lNR/rxw3/0JYf8Agx//ACAfU8R/z+f3f8Er/wDER78cP+hV+FP/AILL/wD+TaP+Ij344f8AQq/Cn/wWX/8A8m1Y/wCGK/8Agsd/0c18Jf8Avm1/+U1H/DFf/BY7/o5r4S/982v/AMpqP9eOG/8AoSw/8GP/AOQD6niP+fz+7/glf/iI9+OH/Qq/Cn/wWX//AMm0f8RHvxw/6FX4U/8Agsv/AP5Nqx/wxX/wWO/6Oa+Ev/fNr/8AKaj/AIYr/wCCx3/RzXwl/wC+bX/5TUf68cN/9CWH/gx//IB9TxH/AD+f3f8ABK//ABEe/HD/AKFX4U/+Cy//APk2j/iI9+OH/Qq/Cn/wWX//AMm1Y/4Yr/4LHf8ARzXwl/75tf8A5TUf8MV/8Fjv+jmvhL/3za//ACmo/wBeOG/+hLD/AMGP/wCQD6niP+fz+7/glf8A4iPfjh/0Kvwp/wDBZf8A/wAm0f8AER78cP8AoVfhT/4LL/8A+Tasf8MV/wDBY7/o5r4S/wDfNr/8pqP+GK/+Cx3/AEc18Jf++bX/AOU1H+vHDf8A0JYf+DH/APIB9TxH/P5/d/wSv/xEe/HD/oVfhT/4LL//AOTa+X/21/21/FX7eHxU0/xf4v0/w/pupabpUejxRaPBNDA0KTTTBiJZZG37p3BIYDAXjqT9Uf8ADFf/AAWO/wCjmvhL/wB82v8A8pqP+GK/+Cx3/RzXwl/75tf/AJTV6GWeJuTZdX+s4LKYwnZq6q62e/8Ay7M6mXVakeWdW69P+CftJRX4t/8ADFf/AAWO/wCjmvhL/wB82v8A8pqP+GK/+Cx3/RzXwl/75tf/AJTV+NHrH7SUV+Lf/DFf/BY7/o5r4S/982v/AMpqP+GK/wDgsd/0c18Jf++bX/5TUAfpJ/wVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vq+I/2xv2Rv+Cq/hr9kL4sah8SP2hvhnrngDT/AAdq114n0y0W38/UtMjs5Wu7eLbpKNveDzB99Pvfer7c/wCDWF/M/wCCIvwnbczN9t13cT1b/icXtAH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/wCxS1X/ANIpa9Grzn9rr/k074of9ilqv/pFLQB8O/8ABpt/yhX8C/8AYb1r/wBL5a/SivzX/wCDTb/lCv4F/wCw3rX/AKXy1+lFABRRRQAUUUUAZfjT/kTdW/685v8A0Bq/JP8A4Mr/APlFh8QP+yq6j/6aNHr9bPGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPQB+wFFFFABRVV9pc5CjPG09+34jpX5X/tKf8Hcn7O/7NHx98YfD698G/FjxBqHgnV7jRL290/T7BbWa4gkMUwj827R9qyK6/Mi7ttAH6tUV8G/8E8f+DiL9nP/AIKQeObHwf4Y1XXvCPjnVN/2HQPE1kttNfbNzHyponlgdto3bPM3/wCzVz/gpD/wX+/Z9/4Jl+J/+Eb8XalrnibxwqLM/hrw5ZrdX1mjhWWS4aV44ocqQwVn37W+5QB9zUV8Q/8ABNT/AIL0fAL/AIKj+Ibjw14G1HXPD/jW3ie5/wCEc8S26Wt9dQp9+SEo8sUqqBuZVfeqnJXrXpX7D/8AwVI+Ef8AwUC8Z/EDw98O9Y1C61r4b6tJpusWt9aC3lG2aWJZ4QGPmQM0T7X+m7aeKAPpSivnn4/f8FFPhj+zX+1X8Mvg94o1LU7Lxj8V0nk0NI7B5rVViBwJXH3Nz/Kv+0nO1dtfnvq3/B5x+zXoep3VnZeAfjRqlnazPHFdix09EukVvvqr3e7a3X5/n+bn5qAP2Oor48/4J2f8FuPgB/wU21WTRfhv4lvrbxdb2v26fw5rVg9lqEUWcMyfehm2/wDTKR9q8ttFfX9pJ5lsje1AElFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP/APwVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vq+kv+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfUAfolRRRQAUUUUAFFFFAHyr/w/E/ZD/wCjivhT/wCDyKj/AIfifsh/9HFfCn/weRVh/wDDgD9jX/o33wL/AN+pv/i6P+HAH7Gv/RvvgX/v1N/8XQBuf8PxP2Q/+jivhT/4PIqP+H4n7If/AEcV8Kf/AAeRVh/8OAP2Nf8Ao33wL/36m/8Ai6P+HAH7Gv8A0b74F/79Tf8AxdAG5/w/E/ZD/wCjivhT/wCDyKj/AIfifsh/9HFfCn/weRVh/wDDgD9jX/o33wL/AN+pv/i6P+HAH7Gv/RvvgX/v1N/8XQBuf8PxP2Q/+jivhT/4PIqP+H4n7If/AEcV8Kf/AAeRVh/8OAP2Nf8Ao33wL/36m/8Ai6P+HAH7Gv8A0b74F/79Tf8AxdAGwf8AguR+yIJtv/DQ3wtyy5B/tpNtP/4fifsh/wDRxPwo/wDB5FWCf+Df39jXz9//AAz94J+7j7s4X/0bT1/4N/8A9jXb/wAm++BfxSdv/atAG5/w/E/ZD/6OK+FP/g8irg/2nf8Ags7+yn4q/Zq+Iem6b8ffhhfX+peGtRtbW3i1lC9xM9rKqIv94s3FdB/w4A/Y1/6N98C/9+pv/i64X9pv/ghL+yL4P/Zu+IWraX8CPBdnqGl+G9QvLWaJZt0M0VrKyON0u35W5oA5f/g03/5Qs+Bv4v8Aid61/wCl8tfpRX5r/wDBpt/yhW8Df9hrWf8A0vlr9KKAMnxX4m0/wXoGo6vq15b6fpel273d5czttjt4Y13O7N2VV+avz18Qf8HWP7Fmg6xdWY+ImvX/ANncxi4tvC9/JDNjujeWMr717J/wXj1y68N/8EgP2hLqxkWCaTwfdWZf+9FOUilX/gUbstfmb/wS5/4K2/8ABPf9k39gf4b+B/GWl6W/jXSdLE3iGS58BS6pNJqErtLODcNCzSbXkZF3N8qqqj5QtAH6yfsMf8FLPg7/AMFIfC2ra18H/F8fiiHQZki1S0e2ls7vTWfd5XmwyhXRZFil2P8Acby3H3lavoaD/UL3/Cvin/gkj8VP2QPjTB8QPE/7Klr4S0u61u4tW8XWulaXPpV4sief9n860lVNi/vLja6KEZmf+INX2tDjyxjp25zQBn+NP+RN1b/rzm/9AavyT/4Mr/8AlFh8QP8Asquo/wDpo0ev1s8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9AH7AUUUUANk6rX4qf8G12k2uq/wDBUL/goYt1a2915fjzchlVX8v/AIm2t9q/auTqtfh1/wAG8fxc8LfCb/gp3/wUCk8T+JPD/htb7x462z6nfxWqzMmq60zbfMZd33v4aAOr/wCDjH4U6J8E/wBvn9iH4teGdL0vR/EEfxHt9L1WXTbNYL7WIlvNPlhR5E+Z1RRcJsb/AJ+qzv8AgjBaeG/j/wD8FrP2/Pi34z03QJG+H/iJNJs9Q1OKFhpNut1f23mq8v8Aqv3GnJub+Fdy1f8A+Dj/AOL2i/FX9sr9gjwN4c1jQ9YfVvidFeTSWN4k7Wv+m6XBb/c/hfzpf+/Vc3/wSh8G+CPBn/BWz/gor8DfihceH7jRPiRrH9rTaVqsqQxahYve3k+3a/LbY9Ui+63y/eoA+sr34YfsT/tPf8FMvhX8bfCfxs+FNz8XPCKzWOmaR4U8baNIfFDSwSxILiCJmnmkiWVtvlsrbV2tvX5R+Ff7Ffxq+I3/AATp/bP8YftXaBp0+s/DXwv8Rr3wV4zgtfmmuLO9eWYrIp2x7WEW+P51Xz4olbbvTd9f/th/8E2f2eP2dv8Agt7+xf8ADv8AZ7sLTS7jUPEFr4m8Sra69dauzQWt6k6HfLM/lfurS7+7t/vdq9d/4N3P2dfC/wC15+z7+3B8M/Gdibzw54z8dzadeBAfMjD+ftlTdnbJFJtdW/hba1AF7/grV8SNF+Mf/Bcj9gjxZ4a1K11jw74k0V9T069t33xXVvLLK6Orf3WVhW5/wZd6BY6t/wAE6fiU1zZ2ty3/AAsa4VWkiWRv+QXYcfMK/N/9nf4f/FT9mT/gtf8AAv8AZ7+KF5Hff8KS8SXGk6DK0LRRyafdefdJLEf+eEvm71H8O/b/AA1+iX/Bmn8Q9A8H/wDBPT4jQ6trmj6XcSfES4lSO8uooHkT+zdPXjc27+GgCx+3B8KtF/Zb/wCDpv8AZT8TeDdG0rw/b+P9DuLPVrLSrJbdby6ZNRtnupli272aKeJct/z7V+0UZym4fxc1+Nf7eHxa0z4v/wDB09+yB4Z8O3Wlasvhfw7dX9xd2t0t0oeWLVJHhbb91kitkdfm/wCWtfsohytADqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+f/APgrD/yix/aU/wCyVeKP/TRdV82/8Grh/wCNIfwn/wCvzXf/AE831fSX/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/5NO+KH/Ypar/AOkUtejV5z+11/yad8UP+xS1X/0iloA+Hf8Ag02/5Qr+Bf8AsN61/wCl8tfpRX5r/wDBpt/yhX8C/wDYb1r/ANL5a/SigD5H/wCC6/hO88Y/8Eg/2hrSxj86aHwdd37KfurFbBbmU++2OF2rxv8A4IB/Bj4HfF//AIJG/B/WtP8Ah38P9QupNKkttbmuNBtJLibUIriSC4ecum4szxM2W/gZcfLX6CeL/C1j428M6lo2p2sd7p2sWr2V5bsxVZopEZHVivOGUla/J/x3/wAGa/7MfizxVdalpvin4veGrS6bcNNstVsp7e04A2xNPaPJt7/M7H0x0oA4P/gkj4e8P+Gv+DoT9rKz+GFjp+m/DWy8GmBoNDg8jSIb7zdF3KEj/dLJ5/27b/232/xV+2afdr5c/wCCcH/BKH4P/wDBK3wBqui/C/R9QW68QywyazrOq3ButS1Rot3lB2wFWNN7lUjRVyzHqWavp63iWOBQq7VUfKAu3aPSgCj40/5E3Vv+vOb/ANAavyT/AODK/wD5RYfED/squo/+mjR6/Wzxp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj0AfsBRRRQBC2PP5weOOfz/pX59fHj/g2V/ZN/aO+NXi7x74i8KeII/EHjS9fUdQFhrk9pardSndLKkSYwXfc7bs5Z2NfoXRQB8F/sc/8ABup+y/8AsM/HHTfiF4R8K+INQ8UaKxfS7nWtZlvI9PkZWUyRR/Khfb/E6ttz8vzVpftz/wDBAj9m/wD4KJfG2T4gePPDWrW/i26tobO/1LRdTaxl1NYl8tDOu1leRUVE3/f2IiH5VWvuKigD4c/YU/4IFfs3/wDBPf41/wDCwvAHhnWLrxZa2slrY6hrOpG8k0vzRtkkt0ZFVHdcpv8Am+Xcq4V3z7r+yd+wp8Mf2IpfGrfDbw6ug/8ACwNem8R61suZZUmu5fvbFct5MP8AdSP5Vr26igDwP4tf8E4vhF8dP2sfBPxv8TeE7fUPiP8AD62ey0fVPOkUeS2/ak0Stsm2NLKyFl+XzWr5H8Uf8GmP7HfizxJfamvhvxppX2+4kn+x2PiKWO2ttzFtkaMrbUX7qjP3a/TSigD4x/YM/wCCFH7O/wDwTa+JNz4w+G3hvVv+Esurd7OPVdX1WW9mtIH274oVOI13Fc527v8Aax8tfZkeNvy9KdRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB8//APBWH/lFj+0p/wBkq8Uf+mi6r5t/4NXD/wAaQ/hP/wBfmu/+nm+r6S/4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP8AsUtV/wDSKWvRq85/a6/5NO+KH/Ypar/6RS0Afg1/wQ717/golZ/8E8vDMX7POh/Bm8+Fq6jqBsJdfdF1Bp/tEv2jd+9X/lpu2/L93FfXf/CXf8Fhk4/4Rn9m/wD7+p/8kV6R/wAGm3/KFfwL/wBhvWv/AEvlr9KKAPyR/wCEv/4LDf8AQr/s3/8Af1P/AJIo/wCEv/4LDf8AQr/s3/8Af1P/AJIr9bqKAPyR/wCEv/4LDf8AQr/s3/8Af1P/AJIo/wCEv/4LDf8AQr/s3/8Af1P/AJIr9bqKAPyF8Q+Lf+Cvj6Bf/avDP7Ofk/Z5Fl2SjzFXZ1X/AEj73p/tV8M/8G8ut/t3ab+xj4oX9l3R/hHfeAG8a3Zv28USf6Uup/YLHzVT96v7ryPsn/At1f0meNP+RN1b/rzm/wDQGr8k/wDgyv8A+UWHxA/7KrqP/po0egDRXxh/wWG2r/xTH7OK/wDbVP8A5Ipf+Ev/AOCw3/Qr/s3/APf1P/kivTv+Cwfxz8bfDL9pfQ7Dw34w8VeH7Gbwzb3D2+m6tPaQvIbq7UuVjcAsVVRnGcKB2Fcr/wAMyftof9BL4hf+F7F/8mV4NbPHGtOjToylyuztqfmuN8RJ0sfWwOGwNWs6TtJwXMtdr2TtfW1+zOb/AOEv/wCCw3/Qr/s3/wDf1P8A5Io/4S//AILDf9Cv+zf/AN/U/wDkiuk/4Zk/bQ/6CXxC/wDC9i/+TKP+GZP20P8AoJfEL/wvYv8A5Mqf7crf9A0/uf8AkZ/8RCx3/QqxH/gD/wDkTm/+Ev8A+Cw3/Qr/ALN//f1P/kij/hL/APgsN/0K/wCzf/39T/5IrpP+GZP20P8AoJfEL/wvYv8A5Mo/4Zk/bQ/6CXxC/wDC9i/+TKP7crf9A0/uf+Qf8RCx3/QqxH/gD/8AkTm/+Ev/AOCw3/Qr/s3/APf1P/kij/hL/wDgsN/0K/7N/wD39T/5IrpP+GZP20P+gl8Qv/C9i/8Akyj/AIZk/bQ/6CXxC/8AC9i/+TKP7crf9A0/uf8AkH/EQsd/0KsR/wCAP/5E5v8A4S//AILDf9Cv+zf/AN/U/wDkij/hL/8AgsN/0K/7N/8A39T/AOSK6T/hmT9tD/oJfEL/AML2L/5Mo/4Zk/bQ/wCgl8Qv/C9i/wDkyj+3K3/QNP7n/kH/ABELHf8AQqxH/gD/APkTm/8AhL/+Cw3/AEK/7N//AH9T/wCSKP8AhL/+Cw3/AEK/7N//AH9T/wCSK6T/AIZk/bQ/6CXxC/8AC9i/+TKP+GZP20P+gl8Qv/C9i/8Akyj+3K3/AEDT+5/5B/xELHf9CrEf+AP/AOROb/4S/wD4LDf9Cv8As3/9/U/+SKP+Ev8A+Cw3/Qr/ALN//f1P/kiuk/4Zk/bQ/wCgl8Qv/C9i/wDkyj/hmT9tD/oJfEL/AML2L/5Mo/tyt/0DT+5/5B/xELHf9CrEf+AP/wCROb/4S/8A4LDf9Cv+zf8A9/U/+SKP+Ev/AOCw3/Qr/s3/APf1P/kiuk/4Zk/bQ/6CXxC/8L2L/wCTKP8AhmT9tD/oJfEL/wAL2L/5Mo/tyt/0DT+5/wCQf8RCx3/QqxH/AIA//kTm/wDhL/8AgsN/0K/7N/8A39T/AOSKP+Ev/wCCw3/Qr/s3/wDf1P8A5IrpP+GZP20P+gl8Qv8AwvYv/kyj/hmT9tD/AKCXxC/8L2L/AOTKP7crf9A0/uf+Qf8AEQsd/wBCrEf+AP8A+ROb/wCEv/4LDf8AQr/s3/8Af1P/AJIo/wCEv/4LDf8AQr/s3/8Af1P/AJIrpP8AhmT9tD/oJfEL/wAL2L/5Mo/4Zk/bQ/6CXxC/8L2L/wCTKP7crf8AQNP7n/kH/EQsd/0KsR/4A/8A5E5v/hL/APgsN/0K/wCzf/39T/5Io/4S/wD4LDf9Cv8As3/9/U/+SK6T/hmT9tD/AKCXxC/8L2L/AOTKP+GZP20P+gl8Qv8AwvYv/kyj+3K3/QNP7n/kH/EQsd/0KsR/4A//AJE5v/hL/wDgsN/0K/7N/wD39T/5Io/4S/8A4LDf9Cv+zf8A9/U/+SK6T/hmT9tD/oJfEL/wvYv/AJMo/wCGZP20P+gl8Qv/AAvYv/kyj+3K3/QNP7n/AJB/xELHf9CrEf8AgD/+ROb/AOEv/wCCw3/Qr/s3/wDf1P8A5Io/4S//AILDf9Cv+zf/AN/U/wDkiuk/4Zk/bQ/6CXxC/wDC9i/+TK43436H+1F+zj4Ut9c8Z+KPiFo2l3V2tjFN/wAJmbjdMyO4XbFcuwysbnJGOOuSMxPPqkI808PNJdWv+AY4jxKxNCm61fLK8YrduLSXq2rIvf8ACX/8Fhv+hX/Zv/7+p/8AJFH/AAl//BYb/oV/2b/+/qf/ACRX31/wTX8Xat47/Yq8F6rrmqahrOqXX27zry+uXuLibbf3CLudyWbCqqjJ4AA6CvdK93D1lVpRqr7ST+9XP0bLMdHG4OljIqyqRjJLtzJO34n5I/8ACX/8Fhv+hX/Zv/7+p/8AJFH/AAl//BYb/oV/2b/+/qf/ACRX63UVsdx+IP7bnib/AIKoXf7GPxeX4jeHfgHb+AW8FawPE0mny/6Uul/YLj7WYcTN+98jzNv+1sr6u/4NYFaP/giL8J1b7323Xd3/AIOb6vpD/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831AH6JUUUUAFFFFABRRRQAUV/PDq3/AAe+eKE1Ocaf+z74fWy8xvJE/iqVpAnbO22AzXTfA/8A4PXI9d+JOmWvxI+B6aP4TvJNl5qGi+IWubqyT/nqtvJComG7gqHT5d33tu2gD9+KK/Dn9tr/AIPJ/DPwa+OOteFfhJ8N4fiJoWh3Ulk/iO+142lrqjphTLbJFG5aIsG2uzruX5tvzV49F/we5+MFdN3wA8M/K2W2+KJxu9v+Pfj/AD8tAH9E9FfkP8W/+Dtn4T+D/wBhrwT8TfDvg/Vde8ceM7m+05vBz6lFAdDuLLyvNe5mVXxE32i3eIrHulV8fKysF+U5P+D33xpCzKv7P3hfC+niifH/AKT0Af0SUV+Of/BPT/g7f+Hv7Ud94o034seDW+FeoaDoOoeIbS6tdX/tCz1aOxga5ltUVkikS5MSu0abXWXYy7lbarfO/i//AIPeNcj8TXy+H/2fdK/sVZmWy+3eKX+0tCPumQJbbFZhztXO3ONzY3MAf0KUV/P38Lv+D2q81Hxtp6+MPgPZ2vh2SZUvp9K8StJeQxMcb40lhVJGXrtZkDdNy9/1u8Jf8Ffv2WPFPhfTNSj/AGjvgjaxalax3aQ33jfTLW6hV0DhJYXnDxSLuwyONylSG5oA+lq85/a6/wCTTvih/wBilqv/AKRS1wv/AA9j/ZZ/6OV/Z/8A/Dh6R/8AJFee/tTf8FRf2aPEf7NHxGsdO/aK+Bt9eX3hnUraC3tfHulyTXEklpKqIgW43M7NwNtAHjP/AAabf8oV/Av/AGG9a/8AS+Wv0or81/8Ag05OP+CLPgb/ALDetf8ApfLX6UUAFFebftVftJ+Hf2P/ANn7xd8TPFzXi+HPBdg+o3v2NBLO6Lt+VEYqu8sQBlq/Mof8Hp37LSfK3gH4+bv+wHpH/wAs6AP1+or5B/4Jff8ABZT4Wf8ABWzRPFeofDfQ/iJo6+D54Yb2PxFo6W+/zVZlMctvLPE/3W+TzPMH3tm3DV9dWxzH/F+OP6UAZ/jT/kTdW/685v8A0Bq/JP8A4Mr/APlFh8QP+yq6j/6aNHr9bPGn/Im6t/15zf8AoDV+Sf8AwZX/APKLD4gf9lV1H/00aPQB23/Bbr/k6zw//wBinbf+ll7X6lV+Wv8AwW6/5Os8P/8AYp23/pZe1+pVfP5T/v2K9Y/qfmPBf/JQ5x/jp/lMK8j/AG3Pjzefss/slfEz4lWenw6tdeAfC2p+II7OWVo47x7W1knSJiPuqzIAzYPXpzx6lcEqd3QZHfbn8fSvxn/4LF/8HKPwLX4T/tBfs5x+F/i43jO60fVvBovpdDtbbTFvJYHg3nzrtJ/KVmPzeR823coZSrN9Afpx+g3/AAR7/bP8Qf8ABQv/AIJvfDP4veKtN03S/EPiuC9j1C30/cLTzrXULqyaRFYllV/s+/YS23ft3NjdXO/tv/8ABb/9m3/gnr8RI/CPxI8efZvFUkQnl0nTbGfUrm0RgrL5wiVlg3KysokK7lYN92vzA/4IO/8ABxb8D/2Uf2LPgz+zz4p8O/FSTxdZ6jd6bPqOmaLb3mmb77V7q5hKIlz9pddl0gZY7dpGYMqI/wAtO/Zj+K/wD+BX/Bxh+17e/tEXXgXSYbiRToFz4vs0e3jdngZiryoyRu0TI3zY3fw0AfqD+wt/wWw/Zz/4KNfEC88LfC3x1/aPiazt/tZ0nUdNuNOup4Rt3vD5yKsqpxuVMsv3jhfmr1f9mP8AbU+Gn7XWoeNLX4feKLbxFdeANcuPD+vxRxSxNZXsEjROuJAu5GZGZWTKt1BbNfjx8QviT8FPj9/wc4fss337NNz4P1GOw0e5bxNqPhK2ij06ZVh1FnR/K+Rp1ttyu+3lZYF3Nt2p6Z+wxAP+Ce3/AAdA/Hj4Uq0Ol+Fv2idE/wCEu0aFnfdd3/8Ax+fJu4VVkfWQFw23bt7UAfpv8VP23Phj8E/2jPA3wp8SeKLbTfHfxEjuJ9C01klZ7iK3hllllkYDZFHthcb5GXcylab+xn+3T8Lf28/Aer+IvhT4qtfFmj6Bqk2j3ksMDw+VcRfwhHVW2Mu10P8AErKe9flx8DI/+Hhf/Bz/APG/4iO0F94V/Zo8KS+GtGuoi221vvKks9rhf9b+/uNYb/Z8pf7tfEf/AAaKftzr+zj+3nrPw11q++zeF/i5pLxRK7Hy4NTsw08L9fkVoPtafd+Z2iXdQB/RF8Wv28PhV8Dv2nvAXwd8SeLbTTviJ8TI5X8PaQYpXa6SLdyzqhji3MrqnmMvmMjKu5lr1yNtwX6ceuPr/eORX8vvw2/bWvv+Cg3/AAdAfDf4pRyXUvhO8+ICaD4YdmZohp9ihiiCbvus6uLhl/ha8b/er9tv+C6P/BTu1/4Ji/sXahr2lyrcfEjxcW0PwXZFDIZr105uCq/eSBcSt/ebyk/5a0AfOn7U/wDwUQ+LP7YH/Baz4f8A7Nv7OXiWbRvCnwvvota+Kuu2sSXEEwtpY5ZrCV2+ZYlVUtzsZfMlunRvlRq+lP20v+C9X7MP7AvxX/4QPx/4+k/4Sy1VBfadpOnz6nLpm4Kw+0GJT5TbSrbGO/awO2vBv+CWX7GFx/wRY/4JIfEz4xeNLS61H4ya94avviB4sN7+8vI5oLOae3053b5y6sX8zc3+vnl7V5n/AMG0n/BN34c/HP8AYV1348fFjwjoPxK8cfHrV9WOo6h4g06K8k+yLdy20yIrBlQy3KXDu6hWbcuW+RaAP1Z/Z6/aH8GftU/CnSfHXw98Sab4q8J68hks9QsX3RybWZXU/wB1ldWRlYKysrA/MK7uP7g4xX40/wDBALwLa/shf8Fa/wBsz9nvwVf3E3wu8L3Frqmlafdzmf7DcMUTYHbczbUl8lmb5mEEe75q/ZaP/V/3qAIZV3T/ADfd6ct8v5etfCv7Rf8Awcafsj/stfFvUfBfiD4l/wBo61pLmG+/sLTLnVre2n3FXheaBGj81Sp3IrfK2d3zV9d/tDfDCf43fArxt4Lt9Z1Dw5ceLtAvtFi1eyb/AEnS3ubd4FuIuR+8j371/wBpa+SP+CZH/BCr4N/sFfsv2/hLVvCng/4heLNWTzfEviXU9GS5fV3bdtjRJt/lwRo2xUTarbd/32agD6c/ZY/a28Aftq/CDTfHXwz8SWPijwvqY/dXcW5WjkU/PFJG4DxyL/dZRWD8bv29vhX+zn+0d8OfhX4w8X22keOPio7w+G9NeGd2vXVgmGkVTHFvdlVPNZdzBlXLV+bP/BBLwPov7Mv/AAWd/bc+E/gGTy/hvpU1lf2GnwPvttPkWVz5KfMceX9oliXc27bEufu1+fH/AAXk+MXjf9oj/grh8XPi74DNvcaD+yTPoOkPqXmK66bNbX6IoZP43/tO4uV2rwqxPnHy7gD+pmDc0QLHcfpipK4b9nX4zaT+0Z8BfBfxA0GVptE8a6JZ67Ys3DGC5gSdA2eQyq+GB+bI5ruaACiiigAr45/4Ldf8mp+H/wDsbLb/ANI72vsavjn/AILdf8mp+H/+xstv/SO9ry86/wBxqeh8fx9/yT2L/wAH6o9C/wCCVv8AyYX4D/7iH/pxuq+hK+e/+CVv/JhfgP8A7iH/AKcbqvoSt8t/3Sl/hj+SPQ4T/wCRJg/+vVP/ANIQUUUV2n0B8/8A/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+r6S/4Kw/8AKLH9pT/slXij/wBNF1Xzb/wauH/jSH8J/wDr813/ANPN9QB+iVFFFABRRRQAUUUUAfy8ar/wZkftUW2ozLb+LPgncW6thJf7av49w9dv2H5a2/hb/wAGY37Q+peN7C38YePvhPoPhvzf+JheaZd3+oXixYJPkwNbRK78Lw0ife/i27a/psooA/nH/a7/AODM74oL8adZu/gr428B3PgK/unm02y8TXt1bajpkTfMIHaK3ljm2fd37l3Koyu6vLI/+DNX9qxmCt4k+CO3dtP/ABPr/wCXtnd9h/T9K/qLooA/AX4p/wDBmxq11+xl4K0Xwl4+8Ir8ZtHvtQvNe1G/guIdK1mO4EXk26OqPLEtv9n+U+X8zXE7bV+7XzY3/Bmd+1dJ8y+JPgntbnnXb/8A+Qa/qNooA/n3/YN/4M3/ABJoHiDxDdftAeL/AAdc2d5oOoadpFh4YlurprW+ngaKC9leWKFf3DOZVRVZWZI9x+8teE+JP+DMr9qCz1++h0zxh8F7/TY52FrcTavfxSTRZ+Uun2Jtr7cbl3Mqndhm61/T9RQB/MX4H/4Mx/2ktT8R2sGv+NPg3o+ltJi6urbUr+7mjTI+aKP7Iiu/UbWdFr9UPC//AAanfsW6T4b0611D4b6vq2oW1ukVxev4n1WBryVVCvLsS42pubJ2r8q54r9JKKAPzr/4hV/2Hv8Aok+qf+Ffq/8A8k1xv7RX/Bsb+xj8P/2f/HmuaV8L9Qt9S0Xw/fX9jK3ivVnWKaK3lkQ7WuNrfMP4s1+o1ec/tdf8mnfFD/sUtV/9IpaAPh7/AINOZPM/4It+Bzjb/wATzWv/AEvlr9J6/Nf/AINNv+UK/gX/ALDetf8ApfLX6UUAfHP/AAX9bH/BHL9oLn/mV3/9HRf5/CvzN/4Jq/8ABSz9sZ/2HfhvpPwj/Yt0zxt4N8L6HDpNn4l1C68j+2/s5ZDcRb/JVlaRXHybvmVvmzX7Pftr+OPAXw5/ZQ+IWufFSxt9U+HOl6DdT+IrKex+3R3lmEbfF5P/AC0LdNv6r96qv7Evxd+Fvxl/Za8HeIPg7Nocfw4n0uL+xoNPtRZwabAoAWDyML5LR7dpUqvzCgD5t/4I7/8ABXqy/wCChB8eeB/E3w/uvhL8XPhndCLxH4Xd9ybGkMSzxEqsn3l2y7l+T5DuYOGr70Q5Wvxl/wCCVuqad8av+DpT9sP4geFbyx1Lwnp/hNNEe9tJRLFJdNJo6Nhl+X/Wafc7v9pa/ZygDL8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9frZ40/wCRN1b/AK85v/QGr8k/+DK//lFh8QP+yq6j/wCmjR6AO2/4Ldf8nWeH/wDsU7b/ANLL2v1Kr8tf+C3X/J1nh/8A7FO2/wDSy9r9Sq+fyn/fsV6x/U/MeC/+Shzj/HT/ACmFfL//AAWO0Sxf/glp+0ddNZ2zXC/DnXG83yl8z/jwn/ir6grnvH/gzTPiP4R1Pw7r2mWWtaDrlpLY6lp97AJbW/t5EZJIZVbKtG6tsZSDuBPFfQH6cfCX/BsFoFjcf8EOfgbcSWdm82dd/fNCjP8A8h/Uf4v0r4f/AOCR37GXwt/4KQf8FZf28tU+OnhSw8fax4T8bva6TaaozrHbwNqGpwSfu0ZUZkjs7RF3fdxX7Yfs9/s9eC/2Uvgt4d+Hvw+0Cx8MeDvClt9j07T7VmaO3TeXcszlmeR5GZ3dyzu7szMWYtXwT+1z/wAG2PhX9on9qzxd8XvB/wAaPit8IfEXjqcXOsw+HLtY4LibYqlhs2SfMy723O3zM1AHyD/wVW/Y3+GX/BMv/gsH+wtqvwH8K2Xw91Txh4vWx1aLSnllW9gbUNPtGXyn3qrSQXt3E2zG4N6qtejf8HTkOs/sg/Hj9mH9rzwbFZr4g8A6+3h2+aSNtuoJhry3t2cDd5TRpqKNj+GdsfxV9Afsaf8ABuH4N/Zl/ax8OfGHxj8Xvil8ZPF3g3e2h/8ACT3ivbWbsrBH5LynYzOy/vFXc33Wr6w/4KGfsHeF/wDgpB+yr4g+E/jK81Sy0fWmhnS905kW6sriCVZYpE3KybtyjOV+ZWdfl3UAfA//AAapfAu60f8A4JufET4zeIZFvPFfx48Q6nq11qflfvrq2tWlt13t/E32s6g//bWvyV/Yw/4JR+Mv2+P+CON540+Evhtte+KXw8+Lt1Ctva3a291daZc6Xp28IWKqzxTpC6qzLtV5W3fwt/Up+zd+zb4f/Zd/Zt8I/C3w6tw3hvwfo8OiWpuJB500SJt8xyAoaRz8zHH3mavMf+CZv/BMvwL/AMEt/gprngfwHdaxqGn67r11rtzNqM3myq8oSKNFH9yOCKJP9ry93egD8h/iN+xxpv8AwSz/AGvP+CZ/gnWJtN0m68PjVNa8Y6j9oHkx37vbz30rz/KvlRf6pZdq7Yolr0z9hPRrz/g4O/4K+63+0p4jtb1/2fPgBeLpHgLS7tP9H1PUEbzYpJIn3BZPmS7lwqtuNlE25Ur7q/4Kq/8ABEf4Z/8ABWXxV4L1b4ga94w0SXwLZ31lapolxDGLgXXlHe4kif54mj3rt+X+8rL8te/fsUfse+Df2Df2afCvwr8B2txb+HfCtt5KTXLBrjUJWLNLcTMoVWklkZ3baqrub5VVcLQBm/8ABQn4Q6p+0H+wN8ZvBGhrHLrHjDwNrGk6dGW+WS4nspUhXP8AvtXxb/waZ/tAaF8V/wDgkL4b8I6feRtrXwx1fU9L1W0X5ZIWur2e/hfb3jaO62q33S0br/BX6dP8v90fL/wGvzD/AGo/+DYv4efGX9onxR8Rvh/8UfiT8FrrxzIZfEGm+GblFsdTdyxlIX5GXzGZmZGZ0LEtt+bbQB5x/wAESvFun/FP/gvZ+3j4i8J3Dap4R+1WtnLelf3bXa3DxMqc/MjSQ3W1v4lRW7173+wz/wAFubr9sP8A4Kv/ABm/Zrm+HTeH7b4Xtqq2+ufbmkm1D7BfxWbNJEUARZGlLr8zfKVr3z/gm1/wTS+HH/BLf4CDwH8OYdSkjurg3uratqkqS32q3G3HmysiovyrhQqLtVQBzy1e6aR4B0TQ/EN9rFjoul2erargX95BaxR3F4F+75rqNz/8CNAHn/7b3xsu/wBmb9jT4qfEaxtrS6v/AAH4R1PXrO3uU/c3E1tZyypE+08qzLt4/vV+Nv7B3/BOv9o7/guv+zxofx0+Mf7XHxC0Lwl4ylvobXwp4ejlt4PKtrye3zsSVLWP54pRu8iVmXaGbdX7Q/tb/s52H7XH7M3jj4Y6te3mn2PjrRrnRbi7swBNbrMhTeobg7d1fmT4M/4NQrj4aeGbXRPDX7Xvx68PaHZ7/sun6bObW2t9zs52RxzKq7mLM21fmZi1AH07+yr/AME9vgr/AMEC/wBjf4oeKPB8WqX0mk6PdeI/EfiDWHE+papHZwyzpCfKRAkSZwsUa87udzEtX4P/ALEn7SvxTj/YR/aM8Mx/snfEz4wXX7Uk13dXnxA0y1vWtIJUMvkyCGKwnW4+zXz3Ezfv1+bKfKybq/bn4M/8EGLP4d/srfGT4V+M/wBoL42fEbS/i/p9vpstxrOrs39ieU5dJbZGL/vGdlD/ADbZVUIVr7E/Zg/Zx8O/sk/s8eD/AIaeEYbhfDvgvTYtM0/z5A88iJ82+V1Chmc5Ztq7dzNQB8Ff8GpX7VWo/Hn/AIJjWfg3WIL6PVvg7rFx4Xne6ZcvbszXMKbPvr5Ucqw/Oq/6rq1fp5b7vs6buuOc18x/sN/8ExvAf/BP74t/GDxV4MuvEMk3xm11Nf1CyvLvzrTTZFaVykC4UKnm3MrZb59pC/dWvpq2OYV7fL/d2/p2oAmooooAK+Of+C3X/Jqfh/8A7Gy2/wDSO9r7Gr45/wCC3X/Jqfh//sbLb/0jva8vOv8AcanofH8ff8k9i/8AB+qPQv8Aglb/AMmF+A/+4h/6cbqvoSvnv/glb/yYX4D/AO4h/wCnG6r6ErfLf90pf4Y/kj0OE/8AkSYP/r1T/wDSEFFFFdp9AfP/APwVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vq+kv+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8mnfFD/sUtV/9Ipa9Grzn9rr/k074of9ilqv/pFLQB8O/wDBpt/yhX8C/wDYb1r/ANL5a/Siv5uv+CKf7VP/AAUP+Ff7APh3Rf2ef2f/AIZ+P/hfDf6hJY6xrMqrczTNcSNcK3/E0t/uyEqv7tflUfe+9X1of29P+CwmPl/ZL+CZ/wC2v/3+oA/Wr4lfD/Q/i74G1zwn4k0yHWNB8S2U+l6lZTr+6vLeeNo5Im/vK0bP/wDrr8rfiL/wZvfsxeOPHN9q2k+J/iz4TsL6TzY9I07UbOSCy3D7kTXFq8qqv3sSO7c/e6Vjf8N6f8Fhv+jSvgj/AN/P/v7R/wAN6f8ABYb/AKNK+CP/AH8/+/tAH35/wTo/4Jc/Cf8A4Jc/C298M/C3Tb1F1iVLnV9W1Kf7VqWqzKFUPJLt2hVH3Y0VI1LO23LM1fSkTb41PSvxv/4b0/4LDf8ARpXwR/7+f/f2j/hvT/gsN/0aV8Ef+/n/AN/aAP1+8af8ibq3/XnN/wCgNX5J/wDBlf8A8osPiB/2VXUf/TRo9Yev/t1/8Fe38P3n2r9lH4MRwyQOspjm+dU243L/AMT0/Nz/AHe1fEv/AAQL/aV/bw+EH7H3ibSv2Xfgh8PfiP4Bm8aXVxqGqa7Kv2iDU2sLFJLdP+Jla/ulgS0cfI3zOfnb7qgH6Wf8Fuv+TrPD/wD2Kdt/6WXtH/D7r4rf9C/8Pf8AwBvP/kqvN/8AhvP/AILCP8y/slfBMDqMy8/+n2j/AIb0/wCCw3/RpXwR/wC/n/39r5+pktf2861Gu48zu0l/wT8xxXAOY/2jiMfgMwdH2zTaUL7ba86va76Lc9I/4fdfFb/oX/h7/wCAN5/8lUf8Puvit/0L/wAPf/AG8/8AkqvN/wDhvT/gsN/0aV8Ef+/n/wB/aP8AhvT/AILDf9GlfBH/AL+f/f2j+ycd/wBBT/8AAf8Agh/qXxD/ANDif/gtf/JnpH/D7r4rf9C/8Pf/AABvP/kqj/h918Vv+hf+Hv8A4A3n/wAlV5v/AMN6f8Fhv+jSvgj/AN/P/v7R/wAN6f8ABYb/AKNK+CP/AH8/+/tH9k47/oKf/gP/AAQ/1L4h/wChxP8A8Fr/AOTPSP8Ah918Vv8AoX/h7/4A3n/yVR/w+6+K3/Qv/D3/AMAbz/5Krzf/AIb0/wCCw3/RpXwR/wC/n/39o/4b0/4LDf8ARpXwR/7+f/f2j+ycd/0FP/wH/gh/qXxD/wBDif8A4LX/AMmekf8AD7r4rf8AQv8Aw9/8Abz/AOSqP+H3XxW/6F/4e/8AgDef/JVeb/8ADen/AAWG/wCjSvgj/wB/P/v7R/w3p/wWG/6NK+CP/fz/AO/tH9k47/oKf/gP/BD/AFL4h/6HE/8AwWv/AJM9I/4fdfFb/oX/AIe/+AN5/wDJVH/D7r4rf9C/8Pf/AABvP/kqvN/+G9P+Cw3/AEaV8Ef+/n/39o/4b0/4LDf9GlfBH/v5/wDf2j+ycd/0FP8A8B/4If6l8Q/9Dif/AILX/wAmekf8Puvit/0L/wAPf/AG8/8Akqj/AIfdfFb/AKF/4e/+AN5/8lV5v/w3p/wWG/6NK+CP/fz/AO/tH/Den/BYb/o0r4I/9/P/AL+0f2Tjv+gp/wDgP/BD/UviH/ocT/8ABa/+TPSP+H3XxW/6F/4e/wDgDef/ACVR/wAPuvit/wBC/wDD3/wBvP8A5Krzf/hvT/gsN/0aV8Ef+/n/AN/aP+G9P+Cw3/RpXwR/7+f/AH9o/snHf9BT/wDAf+CH+pfEP/Q4n/4LX/yZ6R/w+6+K3/Qv/D3/AMAbz/5Ko/4fdfFb/oX/AIe/+AN5/wDJVeb/APDen/BYb/o0r4I/9/P/AL+0f8N6f8Fhv+jSvgj/AN/P/v7R/ZOO/wCgp/8AgP8AwQ/1L4h/6HE//Ba/+TPSP+H3XxW/6F/4e/8AgDef/JVH/D7r4rf9C/8AD3/wBvP/AJKrzf8A4b0/4LDf9GlfBH/v5/8Af2j/AIb0/wCCw3/RpXwR/wC/n/39o/snHf8AQU//AAH/AIIf6l8Q/wDQ4n/4LX/yZ6R/w+6+K3/Qv/D3/wAAbz/5Ko/4fdfFb/oX/h7/AOAN5/8AJVeb/wDDen/BYb/o0r4I/wDfz/7+0f8ADen/AAWG/wCjSvgj/wB/P/v7R/ZOO/6Cn/4D/wAEP9S+If8AocT/APBa/wDkz0j/AIfdfFb/AKF/4e/+AN5/8lUf8Puvit/0L/w9/wDAG8/+Sq83/wCG9P8AgsN/0aV8Ef8Av5/9/aP+G9P+Cw3/AEaV8Ef+/n/39o/snHf9BT/8B/4If6l8Q/8AQ4n/AOC1/wDJnpH/AA+6+K3/AEL/AMPf/AG8/wDkqvNf2pv+Cinjb9rn4fWfhvxJpfhaxsbHUU1JH022njmMiRyxgEyTONu2VuMZyBz1Bd/w3p/wWG/6NK+CP/fz/wC/tH/Den/BYb/o0r4I/wDfz/7+1nVyXF1IOE8S2n/d/wCCcuM8P87xVGWHxGbSlCSs06as1/4Gfod/wSt/5ML8B/8AcQ/9ON1X0JX42/8ADen/AAWG/wCjSvgj/wB/P/v7R/w3p/wWG/6NK+CP/fz/AO/te9hqPsqMaV78qS+5WP0jKcD9SwNHB83N7OEY3ta/Kkr2u7Xttd+p+yVFfjb/AMN6f8Fhv+jSvgj/AN/P/v7R/wAN6f8ABYb/AKNK+CP/AH8/+/tbHoH6Jf8ABWH/AJRY/tKf9kq8Uf8Apouq+bf+DVw/8aQ/hP8A9fmu/wDp5vq+N/2z/wBtD/gqd4w/Y7+LGlfEb9mT4P8Ah3wHqHg3V7XxNqlrL+/07S5bKVLq4i/4nMv7yKFpX/1b/d+433W+yP8Ag1cz/wAOQvhOzcn7Zru7/wAG95QB+iVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP8AsUtV/wDSKWvRq85/a6/5NO+KH/Ypar/6RS0AfDv/AAabf8oV/Av/AGG9a/8AS+Wv0or81/8Ag02/5Qr+Bf8AsN61/wCl8tfpRQAUUUUAFFFFAGX40/5E3Vv+vOb/ANAavyT/AODK/wD5RYfED/squo/+mjR6/Wzxp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj0AfsBRRRQAUVWmOSzbc7en+ex5rzX4VftYfDj46fEPxt4T8G+NNB8ReJPh/epp/iLT7S7Mlxo87fcSQdQrMrrvX5dyMv3lagD1OivMfjl+1Z8Of2bLjwvb+PfGWj+FZvGepxaPoaahceQ+pXbsipFEP4vvru7VxP7Z/8AwU3+BX/BPXSLe6+LnxG0fwrNqS5tNPKy3mo3K/3ktrdHnKf7e3Yv96gD6Eor59/Yq/4KZ/A3/gofouo3nwh+IGl+LW0cK9/ZeRNZ31krNtV3tpkSTYWHD7dv+1Xa/An9rD4c/tMXnia18BeMdE8UXXg7UpdI1uKyufOk0u7R2R4pR/eDKf8AZ/ukigD02ivN/iH+054A+F3xb8L+BPEHjHQ9G8XeNkuH0PSLu4EVzqfkJvfZuP8Ad3dfvbWC8q1fJ+u/8HMP7D/hjxBe6bP8crOS40+aS2le08L61dwb0ZlLJLFZtHKnB2vGzIy8hmBzQB98UV5B+zD+3N8H/wBtXQJNQ+FXxI8K+OIbdA9xDpd+r3Vru6ebCSJYvo6rXryfdoAWiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPn/8A4Kw/8osf2lP+yVeKP/TRdV82/wDBq4f+NIfwn/6/Nd/9PN9X0l/wVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vqAP0SooooAKKKKACiiigDk/+F4+CP+hw8L/+DeD/AOLo/wCF4+CP+hw8L/8Ag3g/+Lr86f8AiEK/Y6/6BfxE/wDCnf8A+Io/4hCv2Ov+gX8RP/Cnf/4igD9Fv+F4+CP+hw8L/wDg3g/+Lo/4Xj4I/wChw8L/APg3g/8Ai6/On/iEK/Y6/wCgX8RP/Cnf/wCIo/4hCv2Ov+gX8RP/AAp3/wDiKAP0W/4Xj4I/6HDwv/4N4P8A4uj/AIXj4I/6HDwv/wCDeD/4uvzp/wCIQr9jr/oF/ET/AMKd/wD4ij/iEK/Y6/6BfxE/8Kd//iKAP0W/4Xj4I/6HDwv/AODeD/4uj/hePgj/AKHDwv8A+DeD/wCLr86f+IQr9jr/AKBfxE/8Kd//AIij/iEK/Y6/6BfxE/8ACnf/AOIoA/RP/he/gc3AiHjLwr5mMhP7Wg3f+h0//hePgj/ocPC//g3g/wDi6/OGT/g0I/Y++2LJ9j+JCIq/6v8A4SX9231/dbv/AB6pl/4NCv2O8c6b8RM/9jO//wARQB+jH/C8fBH/AEOHhf8A8G8H/wAXXnf7W3xo8G3n7K/xMhh8WeGZJpvCeqCNF1aHdJ/ocvTa+418W/8AEIV+x1/0C/iJ/wCFO/8A8RXF/tDf8Gon7Jfw2+A3jjxFpem/EAahoPh6/wBRtTJ4kZ41mgtndNy7Pm+ZaAPT/wDg05bd/wAEW/Azf9RvWv8A0vlr9J6/Nf8A4NOP+ULHgX/sOaz/AOl8tfpRQAVWkb5m+XLdv89jzVmvgb/gvp/wVRb/AIJufsvrpvhKRr74y/E7fo3g3TYV864jdtqSXixL8zeV5i7Fx88rIvPYA+p/hR+178OPjj8UPGXgvwf4y0HxF4o+HkqQeIdOsrrzJtKd2kVUk/2t0Tg/3cV6fGixoqr0XgV+DP8AwaRfBfxb+z5+3V+1V4P8eD/is9DsNITWQbhp3+0vLcSvvc/efc/zH+9ur96aAMvxp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj1+tnjT/kTdW/685v/AEBq/JP/AIMr/wDlFh8QP+yq6j/6aNHoA/YCiiigBsnVa/l6/wCCaP7dS/sS/wDByj8UI9TupoPCnxQ+JPiDwbqw80rDG9xq8v2Sd1+6SlwIhu/gSWT1r+oWTqtfyv6b+wNc/t0a3/wUqm8N6Rcal8Qvhf8AERfFfh1bNXe8m8rVdbW7t4URTIzyW5dljX78sEH92gDsv+Djz9tKP9o//gtn8Pfh9p9w03hv4LappukAbt0b6jdXFtPesPm42r5ELLgbWt2GO9fT37AX7LHw3/4Kr/8ABer9tLxz8UvCtn440n4Y63D4e0rT9YX7RZpPFPPYpKYWJjlVY9MkKpJuXa/3K/PfxX+xP4i+Cn7MHwE+N3xL07WI/it8b/jRLqd7NrcLwalJZRSxFXdJtu1p7p7iZmZV3q9ux+Xa1fo//wAEVfhtcz/8FGf+Cmnwjvtf1fwhrXjDxHJPaanpM6xalYwNf6xsvLctv2vtvrZ1+8ys6BvmoA+ok/4IUaL8Ff8AgrN8Nf2ivgbN4d+FfhfS7G70/wAZeEtJs2s7bVFe3uUR7eKJRAu5pIN8TBY1a3R1+cfN+K3/AASt/by8Tf8ABNH/AIKd+KviZf219H8F/GHja/8ABPi+5VPMtoXlnlmt5CuRiSAr5q/xeUtwq/favrD4+fsU/Ez/AIJof8Fdv2QPAfhH9pT4yfEKb4ieKbW+1m01zW5vKh0+2vYPNBh81lljkgN0u1v7jL/FVz/gjF+wzoP/AAUZ/Yx/bm+EWvTW9vNr3xBeXStRMXnf2XqMXnva3ShWG5VkQ7gpG+NnXd81AHsX/BaDUIdY/wCC/P7Dl3azR3Vvc6fNLHNG4KyI08pDKV+98v8Adrzn/g0q/YV+C/7Un7BXxB1r4lfCv4f+PtWsPHk1lbXev6Da6hPbwLp9i/lI8qFlXc7NtU7fmr4w/ZX+PnxI8Yf8FUP2VPhB8WLGaz8Yfs6avc+CHubqbdNNbpPO0cTjC58pCsSNu+aNEbndmv0l/wCDKf8A5R1fEzb/ANFHn/8ATXp9AHC+N/2WvB//AASy/wCDoj9nqP4U6DZ+CPA/xa8OXVrqWnWMrvBNcypfxOio7Nsi8yKxl2ptVWVq/cyH7lfkH/wU91TT/E3/AAc8/sU6Eq/bL/SdFu9QuINm7yUf7cYZf+AvA7f9s6/XxOlADqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+f/APgrD/yix/aU/wCyVeKP/TRdV82/8Grh/wCNIfwn/wCvzXf/AE831fSX/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/5NO+KH/Ypar/AOkUtejV5z+11/yad8UP+xS1X/0iloA+Hf8Ag02/5Qr+Bf8AsN61/wCl8tfpRX5r/wDBpt/yhX8C/wDYb1r/ANL5a/SigCjcMBJtyQeo2nLfl/wL+L5RxX8z837TX7ROof8ABY3Wv2nvit+xj8aviReeG2lsfBXhz+ydR0yz8LQwOyWztKtjcLM0SPK+5flaeVpVx8m3+m6oZF82Tadp2nJH8j+YoA/An/ggP+2z40+JP/BcT9oS81H4J+M9DuPi+6XWu27yM7fD2SASSIt8ZoYGIlZin3UfcvyxuPu/vxAMRKPm6d6+Vf2Tv+CYujfsoftvfHn41WfijVNYvvjhc2k8umTWyLDpXkI5YbvmaVmdiyt8u1Tt2t96vqyH7lAGb40/5E3Vv+vOb/0Bq/JP/gyv/wCUWHxA/wCyq6j/AOmjR6/Wzxp/yJurf9ec3/oDV+Sf/Blf/wAosPiB/wBlV1H/ANNGj0AfsBRRRQBVmZgeAx284DY7fXpXyR/wT+/4JQeGf+Cfv7SP7QHxD0XxTruvX3x18QrrU9ndW8UcOkp5k85hGwfvT9ou7ht+1dsZiXb8rO/2DRQB8n/8FMv+CX3hr/gpifhX/wAJF4k17w3J8LfFUXiaD+z7dJF1BE277dt4+Vn2ptdd23a3yN/D88/8FAP+Dey4/aR/bA1T47fBf49eOv2f/iJ4mtIrTXbnRPPZdSWNEi3K8VzbyxqyxW29N7Rt5AbbubdX6bUUAfmJ/wAE9v8Ag3suv2X/ANsLSfj18YPj147+P/xG8N2lxZ6Fd62l1EunpLG8Q3vNc3EspWOa42puVFadvlLbWr6N/wCCaH/BLvw3/wAE00+KTeH/ABFq3iQ/FDxVN4mla/jjjazV8lLcFPv7dzfN/Fn7or6uooA+Ev2h/wDght8P/jn/AMFPvAP7T1nrN54b8QeFyH1vTbKyRovEk0ULpbXDy7h5UqKyKx2tvWNPu7dzfGXhb/g1k+OP7OP9sab8E/21fHnw88J6hqk15FpGmw3+m7VfaiPO1pfIlxOsSojSeUm7Znav3a/bqigD82f+Ca3/AAQIuP2Pf2qW+OXxa+NXi79oD4qWVnJpujaxrqTf8SeB0eJ8NNcXE0snlu6L+8RVWeVdh+9X6RQ/6teNvt/d9qkooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+f/wDgrD/yix/aU/7JV4o/9NF1Xzb/AMGrh/40h/Cf/r813/0831fSX/BWH/lFj+0p/wBkq8Uf+mi6r5t/4NXD/wAaQ/hP/wBfmu/+nm+oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/wCTTvih/wBilqv/AKRS16NXnP7XX/Jp3xQ/7FLVf/SKWgD8Af8Agip/wWv+Mn7FP7AXhv4f+DP2N/ib8YtD0/UL6eLxNot3ex2t409xK7RqItMuF+Riy/K/3kPutfWA/wCDmn9ow7dv/BN/42FevGo6p/8AKWvbP+DTb/lCv4F/7Detf+l8tfpRQB+Nf/ETT+0Z/wBI3fjd/wCDHVP/AJSUf8RNP7Rn/SN343f+DHVP/lJX7KUUAfjX/wARNP7Rn/SN343f+DHVP/lJR/xE0/tGf9I3fjd/4MdU/wDlJX7KUUAfjDrf/Byt+0Vd6NeRt/wTn+NEKTQOjSS3mpPGny/xZ0VeAMt1718Uf8EDf+CunxY/YB/Y+8TeDPAf7J3xC+Oujaj4yutYuNe0G5u1tbGV7Gyia0cQaddL5qpbJKxZlbbL9xfvN/TD40/5E3Vv+vOb/wBAavyT/wCDK/8A5RYfED/squo/+mjR6AMs/wDBzP8AtHJ8p/4Jv/Gxj3xqGqY/9MtH/ETT+0Z/0jd+N3/gx1T/AOUlfeH/AAUp/wCClP8Aw7y/4Qv/AIov/hL/APhMPt3/ADF/7P8Asn2b7P8A9MJd+77R/s42d88fLf8AxEpf9UX/APLu/wDuKvIxWfYHD1XRrTtJbq0nur9Efp3Dvg3xhnuX081yrB+0o1L8svaUo35ZOL0lNSVpJrVLa60PM/8AiJp/aM/6Ru/G7/wY6p/8pKP+Imn9oz/pG78bv/Bjqn/ykr0z/iJS/wCqL/8Al3f/AHFR/wARKX/VF/8Ay7v/ALirn/1oyz/n7/5LL/I9r/iXnxA/6AP/ACrQ/wDlh5n/AMRNP7Rn/SN343f+DHVP/lJR/wARNP7Rn/SN343f+DHVP/lJXpn/ABEpf9UX/wDLu/8AuKj/AIiUv+qL/wDl3f8A3FR/rRln/P3/AMll/kH/ABLz4gf9AH/lWh/8sPM/+Imn9oz/AKRu/G7/AMGOqf8Ayko/4iaf2jP+kbvxu/8ABjqn/wApK9M/4iUv+qL/APl3f/cVH/ESl/1Rf/y7v/uKj/WjLP8An7/5LL/IP+JefED/AKAP/KtD/wCWHmf/ABE0/tGf9I3fjd/4MdU/+UlH/ETT+0Z/0jd+N3/gx1T/AOUlemf8RKX/AFRf/wAu7/7io/4iUv8Aqi//AJd3/wBxUf60ZZ/z9/8AJZf5B/xLz4gf9AH/AJVof/LDzP8A4iaf2jP+kbvxu/8ABjqn/wApKP8AiJp/aM/6Ru/G7/wY6p/8pK9M/wCIlL/qi/8A5d3/ANxUf8RKX/VF/wDy7v8A7io/1oyz/n7/AOSy/wAg/wCJefED/oA/8q0P/lh5n/xE0/tGf9I3fjd/4MdU/wDlJR/xE0/tGf8ASN343f8Agx1T/wCUlemf8RKX/VF//Lu/+4qP+IlL/qi//l3f/cVH+tGWf8/f/JZf5B/xLz4gf9AH/lWh/wDLDzP/AIiaf2jP+kbvxu/8GOqf/KSj/iJp/aM/6Ru/G7/wY6p/8pK9M/4iUv8Aqi//AJd3/wBxUf8AESl/1Rf/AMu7/wC4qP8AWjLP+fv/AJLL/IP+JefED/oA/wDKtD/5YeZ/8RNP7Rn/AEjd+N3/AIMdU/8AlJR/xE0/tGf9I3fjd/4MdU/+Ulemf8RKX/VF/wDy7v8A7io/4iUv+qL/APl3f/cVH+tGWf8AP3/yWX+Qf8S8+IH/AEAf+VaH/wAsPM/+Imn9oz/pG78bv/Bjqn/yko/4iaf2jP8ApG78bv8AwY6p/wDKSvTP+IlL/qi//l3f/cVH/ESl/wBUX/8ALu/+4qP9aMs/5+/+Sy/yD/iXnxA/6AP/ACrQ/wDlh5n/AMRNP7Rn/SN343f+DHVP/lJR/wARNP7Rn/SN343f+DHVP/lJXpn/ABEpf9UX/wDLu/8AuKj/AIiUv+qL/wDl3f8A3FR/rRln/P3/AMll/kH/ABLz4gf9AH/lWh/8sPM/+Imn9oz/AKRu/G7/AMGOqf8Ayko/4iaf2jP+kbvxu/8ABjqn/wApK9M/4iUv+qL/APl3f/cVH/ESl/1Rf/y7v/uKj/WjLP8An7/5LL/IP+JefED/AKAP/KtD/wCWHmf/ABE0/tGf9I3fjd/4MdU/+UlH/ETT+0Z/0jd+N3/gx1T/AOUlemf8RKX/AFRf/wAu7/7ir1L9i3/gt9/w19+0x4a+Hf8AwrH/AIR3/hIvtX/Ew/4SP7X9n8m1muP9V9lTdu8rb94Y3Z5xg6UeIsuqzVOFS7k0lpLd7dDizLwL44wGEq4/F4Hlp0oynJ+1ou0Ypyk7Ko27JN2SbfRHzD/xE0/tGf8ASN343f8Agx1T/wCUlH/ETT+0Z/0jd+N3/gx1T/5SV+ylFe2fkh+Nf/ETT+0Z/wBI3fjd/wCDHVP/AJSUf8RNP7Rn/SN343f+DHVP/lJX7KUUAfhD+2h/wcHfHv44/sd/FfwfrH7Avxd8G6P4r8G6xo2o67e3+oNbaJb3NlLFLdyB9IjXZEjF/mdF+XrX2Z/wat/8oP8A4S7f+fzXf/TveV9Jf8FYf+UWP7Sn/ZKvFH/pouq+bf8Ag1cP/GkP4T/9fmu/+nm+oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/5NO+KH/Ypar/6RS16NXnP7XX/Jp3xQ/wCxS1X/ANIpaAPh3/g02/5Qr+Bf+w3rX/pfLX6UV+a//Bpt/wAoV/Av/Yb1r/0vlr9KKACiqdw/lvuzt7H5C3+R1r8d/Gf/AAXf/ay/bC+P/jbw/wDsY/s6aB4z8G/DXUJNG1bWfFrtuvbpJWTMbC+tYlXjd5W+WTYVdtm7aoB+ylFfmf8A8Ewv+C23jr9of9rO8/Zv/aK+EUvwh+OFvps2oxJCW/svXIolDMIUlkdxuj3uhSSeNlglbf8Aw1+l0GfKGaAM3xp/yJurf9ec3/oDV+Sf/Blf/wAosPiB/wBlV1H/ANNGj1+tnjT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHoA7j/g5S/5ov/3HP/cdX1d+xx+xx8IfE/7Inwr1LUvhX8N9Q1LUPB+kXN1dXPhmymnuZXsoWeR3aMszsxJLEkkkk18o/wDByl/zRf8A7jn/ALjq+9v2HP8Akyn4P/8AYkaL/wCkENfK4SnCedYlTSekd/RH9HcSZhisL4VZDLC1JQbqV78snG/7ypvZoP8Ahhz4Kf8ARH/hb/4Slh/8arz79o/4HfAH9mH4IeMviNr3wd+HU3h/wPol5ruox2vhKwed4beFpXCK0QVm2pwNy9TX0TcHOWPbpjHXt16NzX5+f8Fiv+Cnf7PcH7C37RPw2X4xeAH8eyeC9b0RNCj1aKS+a9e0liW38tTuWTzGC7a+i+q0P5F9yPwv/WTN/wDoKqf+By/zPTf+CeNh+z3/AMFEf2N/BHxk8P8AwL+H+h6X4yt7h1sbzwvp8k1rNBczWsybliw6rNBJtbA3Ltbaudo9luf2IvgnbI7yfCH4WrGoLFj4WsFVQBySfK4r86v+Dcb/AIKU/AL4S/8ABKT4J/DXxJ8XPAugeOoLjVbVtBvdVjhvY5bjXL+W3Qo38TpLG3/A1r1L/g5e/wCCitx+wv8A8E9tQ0Hw7eSW/wAQ/jG0vhfRRE4W5tbZkH267Qh1dfKhkEayrnZLcwtR9VofyL7kH+smb/8AQVU/8Dl/mfTnwq+AP7NPxz0GTV/Bfgb4J+KdJgupbJ73StD028gE8LtHJEWRGXcrKVPuprl/2lbT9jv9jrQrXUvihonwD8B2d8xW0/tXQ9NhkvCvLeUjReZLx/cVq+Fv+DLJRH/wTn+Jy7V3L8SbhWRl+ZR/ZundR+f/AHzXo/hn/ggXN+07/wAFPvi/8cv2prnS/iboNzerY/D3QBcz/Y7TTlyYjcwYC/ul2qsKuyNI1xK67nSj6rQ/kX3IP9ZM3/6Cqn/gcv8AM+pf2adK/ZB/bE8P3er/AAv0H4C+OrCxdUujo+h6bO1mSPlWVPK3xk/7SrXU/DT9n39m/wCMemXV/wCE/APwT8R2NjfTafcz6ZoOmXcUNzA7RzW7MiNiRGUqy9ipr8rfin+zB4T/AOCTH/Bxz+zbD8DbG48F+FfjTYPYeIvD8Fw7WMgd5Ynx5pdlGfIfy/4ZIgVYb9q9j/wb6Xb/ALEH/BVT9r79k268m00631U+MvCtrCmyGGzaRdoGfuu9neab8v8AD5DD5sUfVaH8i+5B/rJm/wD0FVP/AAOX+Z+jvib4Bfs0+C/Hfh3wvqvgX4Kab4j8XtMmiaTcaFpqXurGGJ55PIiMW+TbEjs237oWuuX9hz4Ksi/8Wf8Ahb/4Slh/8ar8uvhjeXH/AAUf/wCDrjxN4it5vtvgf9k7w4+k2s1vN5lvJqOx4DE/92X7Te33/gv+9/DX6E/8FQ/2+vD3/BNb9jTxV8UdfMNxdabCbTQdOeVozrGpyr/o1qBtb7zAszbW2Rxu38NH1Wh/IvuQf6yZv/0FVP8AwOX+Z8Z/t9ftPfDr4V/8FKPg1+zH8F/2fPgn428beLNTtLrxm154YtceHdJMiyy7AioPP+ypNOxdm2RrH+6k83j6m/aF1H9i39krWtN0v4nWf7OvgXU9STzrWz1rStMtZ5ot23fsZd23dxvPy5r43/4Iafsuap+zJ+zD8VP25PjtHcXXxY+J2l6n4vnlvgFm0vQ0RrpUBb7hn2CUBfuxLbp8u1lrxv8A4Imf8EnvCf8AwWA+EHxC/ad/aihvviH4o+LWrX+n6PE+qTQQaTaRMsRmh2NuSRJRLFErMyxxwJhfmNH1Wh/IvuQf6yZv/wBBVT/wOX+Z+vvhf9kT4B+NPDdjq2kfC/4RappepQrcWt5a+GtPlguY2G5XR1i2spHcVp/8MOfBT/oj/wALf/CUsP8A41X5kf8AButZ+Iv2Nv24f2oP2RbrxBfeKPBHwpv4tY8MTXju0tjFO+5kC/6tN6SwOyKoVpUlcfer9hYI/LiVdzNtGMnrR9VofyL7kH+smb/9BVT/AMDl/meVyfsPfBTf/wAkf+F/4eFLD/41Xzt8UP2h/wDgn78FvGl94b8Vat+zDouv6XL5V7YXNlpPn2r7VOxwqfI3zfxV9ffEHw/N4x8Ia5pNvqVxpNxqFlNbQ30C7p7F5ImRZUH95c7l9SCK/OT9mb/g3K/ZL/ZS+D8Xh/4r2Ph34p+MdRMl1qPiXxPK+nT3YdlVvJiW4PkIvQHezbm/1ho+q0P5F9yD/WTN/wDoKqf+By/zPsL4U/s7/s4fHDwNY+JvB/gH4K+J/DuqL5lpqWmaBpt1bTru2nZIiFW+YMv+yysO1V/GHwI/Zn8BfEDw54W1rwT8D9I8ReLnlh0TSrzRdMhvNWaJd7/Z4mi3y7V5bbX5tf8ABqdbr8Mf2kv22vht4X1GbUPhZ4N8dQJ4afzvNg2/atUthMjk/O0tta2pZstuWBK+MP8Ag4W/bI8Uar/wW8uvHHg231G+0v8AZTGgxvcRSbLS3uYrpbp9zD7jSXN39nZR8z+Vz8qUfVaH8i+5B/rJm/8A0FVP/A5f5n9EcH7EHwTliVl+D/wtIb/qVLD/AONU/wD4Yc+Cn/RH/hb/AOEpYf8Axquy+HPjvTfij8PtD8TaPcRXeleINPg1Kynjbck0M8ayRuD/ABAqwOR1zXQUfVaH8i+5B/rJm/8A0FVP/A5f5nlv/DDnwU/6I/8AC3/wlLD/AONUf8MOfBT/AKI/8Lf/AAlLD/41XqVFH1Wh/IvuQf6yZv8A9BVT/wADl/meW/8ADDnwU/6I/wDC3/wlLD/41X5W/sRaHY+GP+C9d1pum2drp+m6f4w8VW1ra20SwwW0SW+pKkaIoCqqqAAoAAAAFftJX4y/sff8rAurf9jv4t/9E6lXzee0acK+F5IpfvFsvNH7t4O5pjcVk/EccVWlNLBVbc0nK3uT2u2fs1RRRX1h/N4UUUUAfP8A/wAFYf8AlFj+0p/2SrxR/wCmi6r5t/4NXD/xpD+E/wD1+a7/AOnm+r6S/wCCsP8Ayix/aU/7JV4o/wDTRdV82/8ABq4f+NIfwn/6/Nd/9PN9QB+iVFFFABRRRQAUUUUAfjX/AMQUf7Of/RTPjZ/4G6X/APIdH/EFH+zn/wBFM+Nn/gbpf/yHX7KUUAfjX/xBR/s5/wDRTPjZ/wCBul//ACHR/wAQUf7Of/RTPjZ/4G6X/wDIdfspRQB+Nf8AxBR/s5/9FM+Nn/gbpf8A8h0f8QUf7Of/AEUz42f+Bul//IdfspRQB+Nf/EFH+zn/ANFM+Nn/AIG6X/8AIdH/ABBR/s5/9FM+Nn/gbpf/AMh1+ylFAH42r/wZUfs7r8o+J/xsEf8AEv2zTfm/8k6b/wAQUv7Ocn/NTPjYf+3zS/8A5Dr9lKKAPxr/AOIKP9nP/opnxs/8DdL/APkOuW+OX/BnT+z38K/gj4w8SWfxE+MVxfeHdDvtSgjub3TWhkeC3eRNwWzVtu4c4av29rzn9rr/AJNO+KH/AGKWq/8ApFLQB8O/8Gnef+HLngfd8x/tzWv/AEvlr9KK/Nf/AINNv+UK/gX/ALDetf8ApfLX6UUARyRB924KysMNmvkX/gpT+274o/4JsfDLRdU+HH7PPjL4z3XiTUnhmsPC0Rt4NO+UMZ7hoYZpULfdX91sbHLp/F9ZSuzTqPvBvlHy5Ve4P6fqK/Nv4a/8HUX7Kep3PiDTfiFrPin4S+IvDerXGkTaXrfh+/vpZPJO0zK1lFNtXcCjLJsfcrfKV+agD4j/AGBP2uvEH/BRP/g548F/ED4ueC7/AOBPibwr4L1C18N+EtUjnW81Arb3kQhke4ihd28q8vptyxIP9Fxjiv6Co/uCvwj8U/tx/DP/AIKl/wDByl+y7r3wHubzxdpvgfQb5db15NIuNPVUWK/l2t9oiSby4vN43qEZ7hEX5nr93I/9WvpQBm+NP+RN1b/rzm/9AavyT/4Mr/8AlFh8QP8Asquo/wDpo0ev1s8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9AHcf8HKX/ADRf/uOf+46vvb9hz/kyn4P/APYkaL/6QQ18E/8AByl/zRf/ALjn/uOr72/Yc/5Mp+D/AP2JGi/+kENfMYH/AJHWJ9I/kj+guMP+TUZB/wBfMR/6cqHpjR7n9+P0r82/+CuH/BH79mXRP2G/2hviZafBvwbZeOrXwjrevxaxbwPFLHqC2ss4nC79isZVB+7/ABe9fpVXC/H34J6H+0Z8HfF3gTxNDLdeHfGmk3Oi6mlvIYZpLW4heJ1V1+ZTtdsMPX65+nP59Pyx/wCDdH/glN+zv8bf+CWnwW+Kniz4SeFfEnj24uNVupNYvYneWaS31y+igZk3+WzIkSKu5eirX6c/tE/s3+A/jloum3njLwhoPiq48Hyyaroj6naJdf2Xdqnyzxb/ALjLt/hql+xD+yF4R/YJ/ZX8G/CXwK2qf8Iv4PtpIbWTULj7RdXLzTSXE00jgBS0ks0j/Kqou/CqqhVHmH/BUf8AZp/aA/ab+G+g6T8CPjJpPwhvLW7lfW5rvRlvn1SB4TGEVyG2bcn5VT5933l27WAPhj/gyyf7R/wTn+Jjt8zN8Sbhm39M/wBl6cc/99VU+OH/AAUf/bK/4KNft+fGL4I/sdXXgnwP4Q+DVwmja14p1uFHna6SZoJsvLFPs3SpcIipAzbLV337mUD0/wD4Ie/8EVfjx/wSj+JGpW+tfG7QNc+Ferx3F7feFdO0h83WpyJFElx5sq7omRIk+ZWbft27f4q8p8If8G/37XH7OH7Q/wAXPGnwX/ai8L+AYPi54jn1nUkTRmkmuE+03UsKuHSRdyLdzfd/vUAes/sBf8EPvip4S/ba8PftFftVfGhfi/8AEjwvpbW2g2VrA62OjzMkqk+ayxLKqLLNtRYU+Z9/8NeE/wDBdj4lS/8ABLL/AILU/AT9qy3s9Qn0HxN4evvDniC2t0XFw8ETxfOzfLuZLu2bDN/y619Y/sNfsK/tvfBf9pLRfEHxg/as0X4ieALOKcaj4fTw8itflon8ra/lJ5Ply7H37m+5t2/NXoH/AAWs/wCCV0f/AAVs/ZI07wDH4itfCXiDQ9cttc0rVLm2a6gjdUkgkidFZWZXjmbn+8q0AfOH/Bpz8CdQ0v8AYp8bfHTxMqyeMPj34svdZur6aPZJcWsEssa5P903TXj/APAzXguq6hN/wco/8FkrfT486p+yX+zXc+ZO8bebY+LL0v8AhuW6eLaPvbbW3dtyef8AN+mfjn9gm70f/glfN+zj8PfGF54RuNP8FQeEdP8AEzR+XLEqQpFLdOqEbWlVZWdVZW/eNyud1aH/AAS3/wCCc/hP/gmB+yBofww8NzJqU1u732uay9oLebXNQl4luHXLbF2qiIhZmSOONSzEMzAGr/wU08B33xD/AOCZfx38N6Hb+dqeqfDvW7OwtoV2+dK1hKqRL/vNhf8AgVfLX/Bqr4u0zxH/AMET/h3Z2MkUt54f1TW7LUVjbdKsx1O4uVVx2YwTQ/8AAWWv0Yu7SG+hZLiJZEkG11f5hhgwKn82H41+Reu/8G8/x0/Zj+MXjbUP2Sf2lpPg34C8fXBvbzwxc6fLKlhKc8RMN6/LuOx1VJFXau5tu6gA/wCCSUtqn/Bxr+3bJa3sepRqluvno+Y45PPi3wluzRyDysesbV9ofsyf8FgPg7+1Z+2z8R/gB4TuvEkvjz4XterqjXmmPDZTtZ3C2t2In3EkRTuqZdV3fw7l2s2H/wAEgP8AgkdoP/BKj4S67anX7rxx8RPHl4uoeLfE1zD5bajKjSMiIrFnEa+a/wB5mZnkZvlztX0j4G/8Ey/gn+zj+1j42+NXg7wZHo3xI+IC3X9uaoL+5m+1faZ47i4YRPI0aeZKiO2xV+b60Ae/JItvbZY7VXqM7tvtXxR+3z/wQP8A2ff+CkHxz/4WJ8SLXxhL4gbTYdMMun69LDCIYt5TCNuWMfvGJVdqlhuxuZ2f6e/aR+B+n/tKfAHxx8PNYubyz0fx1oV7oF5LavslhhureSCRkJ43eW59uvrX5W/C3/giP+3p+zR4BsfBfw5/bZsLDwT4fj+z6RaXOiv5lvDncIwjpM0Sr/CiyMqr8oCr8tAHHf8ABBvTtO/4JUftuft0fBm+1yfUPht8KLWLxaupXhUT2tpbRSyM8u1VXzfssyb2VVVmgLKFX5a/P/8AZO/bk/Z/8VfsG/tpwfGfWbyz+NH7SWpXWq6bDHpd3cWi3ETNqNo3nRIyxbtRlO//AGYk3fLX6xfAP/g3h8W/Dn9l/wDaa0/xZ8ZG8VfGv9pPTfsOo+LW03bbWKeY0rwje3mOs8jlJT8vyeUqKpQmvsL9iv8A4Ja/Cn9kX9lfwP8ADeTwj4L8W3XhPS0tLvWrzw5b+fq1xlnmuGDh3UtLJI23e23fjNAHgn/Br3+1zD+03/wSW8E6XcXsV14h+F8k3hLUVC7fJihdns/+A/ZXgTj+JGr9GIm3xqdu32NfGP8AwSy/4JUN/wAEyviD8dLnTvGB1rwf8VPEqa/o2hR2AtYfDabp2dOvzNtnRP8Arnaxf7tfZ8b+ZGp27d3agB1FFFABX4y/sff8rAurf9jv4t/9E6lX7NV+Mv7H3/KwLq3/AGO/i3/0TqVfMcQfx8J/18X5o/oLwS/5FHEn/YFV/wDSZn7NUUUV9Ofz6FFFFAHz/wD8FYf+UWP7Sn/ZKvFH/pouq+bf+DVw/wDGkP4T/wDX5rv/AKeb6vpL/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831AH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/7FLVf/SKWvRq85/a6/5NO+KH/Ypar/6RS0AfDv8Awabf8oV/Av8A2G9a/wDS+Wv0or+av/gjH/wcwfDD/gmn+wP4c+Enij4f+PfEGraPfX15Je6U9qtu4ubl5V275Vb5VZR0+9X1X/xG0fBH/okPxU/7/wBh/wDHqAP2lk/L6ferw/4q/wDBN/8AZ/8Ajn4wuPEPjT4J/CvxRr142bjUtU8L2V1dTcbcvK8RZvlVR83QACvzL/4jaPgf/wBEg+K3/f6w/wDj1H/EbR8D/wDokHxW/wC/1h/8eoA/Vn4DfsgfCj9lz7cnw1+GvgbwB9v2reHw9odrp7Xm37vmtCilv+BV6anSvxZ/4jaPgf8A9Eg+K3/f6w/+PUf8RtHwP/6JB8Vv+/1h/wDHqAP2U8af8ibq3/XnN/6A1fkn/wAGV/8Ayiw+IH/ZVdR/9NGj1xetf8HpfwT1jQr63j+E3xUjmuYHiVmlsNqFl2hv9d6+gr4x/wCCDf8AwcLfDn/gkr+yH4i+HfizwN418TahrfjC68SRXOkSWvkxwS2VlbiM+bKp8wNaM3T7rLQB+nX/AAcpf80X/wC45/7jq+rv2OP2x/hD4Y/ZE+Fem6l8VPhvp+paf4P0i2urW58TWUM9tKllCrxujSBldWBBUgEEEGvxO/4KVf8ABx58EP8AgoQ3g1f+EV+KnhH/AIQ/7dyNOsNQF39p+z/9PsWzb9n/ANrO/tjn5a/4eMfBD/n5+K3/AIS1h/8ALOvka1HMaGY1cThqSnGaitZJbJed9z+msrzTgXOOBctyHPsylhq2GlVk1GlUn8dSbSbUHH4Wno3vZ6n9T3/DcnwU/wCiwfC3/wAKuw/+O0f8NyfBT/osHwt/8Kuw/wDjtfyw/wDDxj4If8/PxW/8Jaw/+WdH/Dxj4If8/PxW/wDCWsP/AJZ10fXs6/6Bl/4Ev8zx/wDU/wAKP+h/U/8ACep/8rP6nv8AhuT4Kf8ARYPhb/4Vdh/8do/4bk+Cn/RYPhb/AOFXYf8Ax2v5Yf8Ah4x8EP8An5+K3/hLWH/yzo/4eMfBD/n5+K3/AIS1h/8ALOj69nX/AEDL/wACX+Yf6n+FH/Q/qf8AhPU/+Vn9T3/DcnwU/wCiwfC3/wAKuw/+O0f8NyfBT/osHwt/8Kuw/wDjtfyw/wDDxj4If8/PxW/8Jaw/+WdH/Dxj4If8/PxW/wDCWsP/AJZ0fXs6/wCgZf8AgS/zD/U/wo/6H9T/AMJ6n/ys/qe/4bk+Cn/RYPhb/wCFXYf/AB2j/huT4Kf9Fg+Fv/hV2H/x2v5Yf+HjHwQ/5+fit/4S1h/8s6P+HjHwQ/5+fit/4S1h/wDLOj69nX/QMv8AwJf5h/qf4Uf9D+p/4T1P/lZ/U9/w3J8FP+iwfC3/AMKuw/8AjtH/AA3J8FP+iwfC3/wq7D/47X8sP/Dxj4If8/PxW/8ACWsP/lnR/wAPGPgh/wA/PxW/8Jaw/wDlnR9ezr/oGX/gS/zD/U/wo/6H9T/wnqf/ACs/qe/4bk+Cn/RYPhb/AOFXYf8Ax2j/AIbk+Cn/AEWD4W/+FXYf/Ha/lh/4eMfBD/n5+K3/AIS1h/8ALOj/AIeMfBD/AJ+fit/4S1h/8s6Pr2df9Ay/8CX+Yf6n+FH/AEP6n/hPU/8AlZ/U9/w3J8FP+iwfC3/wq7D/AOO0f8NyfBT/AKLB8Lf/AAq7D/47X8sP/Dxj4If8/PxW/wDCWsP/AJZ0f8PGPgh/z8/Fb/wlrD/5Z0fXs6/6Bl/4Ev8AMP8AU/wo/wCh/U/8J6n/AMrP6nv+G5Pgp/0WD4W/+FXYf/HaP+G5Pgp/0WD4W/8AhV2H/wAdr+WH/h4x8EP+fn4rf+EtYf8Ayzo/4eMfBD/n5+K3/hLWH/yzo+vZ1/0DL/wJf5h/qf4Uf9D+p/4T1P8A5Wf1Pf8ADcnwU/6LB8Lf/CrsP/jtH/DcnwU/6LB8Lf8Awq7D/wCO1/LD/wAPGPgh/wA/PxW/8Jaw/wDlnR/w8Y+CH/Pz8Vv/AAlrD/5Z0fXs6/6Bl/4Ev8w/1P8ACj/of1P/AAnqf/Kz+p7/AIbk+Cn/AEWD4W/+FXYf/HaP+G5Pgp/0WD4W/wDhV2H/AMdr+WH/AIeMfBD/AJ+fit/4S1h/8s6P+HjHwQ/5+fit/wCEtYf/ACzo+vZ1/wBAy/8AAl/mH+p/hR/0P6n/AIT1P/lZ/U9/w3J8FP8AosHwt/8ACrsP/jtH/DcnwU/6LB8Lf/CrsP8A47X8sP8Aw8Y+CH/Pz8Vv/CWsP/lnR/w8Y+CH/Pz8Vv8AwlrD/wCWdH17Ov8AoGX/AIEv8w/1P8KP+h/U/wDCep/8rP6nv+G5Pgp/0WD4W/8AhV2H/wAdr8rf2ItdsfE//Beu61LTby11DTdQ8YeKrm1uraVZoLmJ7fUmSRHUlWVlIIYEgggivyz/AOHjHwQ/5+fit/4S1h/8s69S/Yt/4LWfBD9kH9pfw18RP7O+K3iL/hHftX/Ev/sKws/tHnWs1v8A63+0H27fN3fdOduOM5HFiKeaYuvRdagoxhNNtST0ur9T6jJsd4dcNZPm1LKs2lXq4rD1KUYyo1Y+84SUUn7NJXbSu2kurP6nqK/Ff/iNo+B//RIPit/3+sP/AI9R/wARtHwP/wCiQfFb/v8AWH/x6vsz+VT9qKK/Ff8A4jaPgf8A9Eg+K3/f6w/+PUf8RtHwP/6JB8Vv+/1h/wDHqAP0o/4Kw/8AKLH9pT/slXij/wBNF1Xzb/wauH/jSH8J/wDr813/ANPN9Xw/+2Z/wd3/AAf/AGmf2P8A4q/DrS/hh8TNN1H4geENW8OW1zdvZNBby3lnLbh32ys21fMH3Vr7i/4NYP8AlCB8J/8Ar71z/wBO95QB+iFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV5z+11/yad8UP8AsUtV/wDSKWvRq85/a6/5NO+KH/Ypar/6RS0AfDv/AAabf8oV/Av/AGG9a/8AS+Wv0or81/8Ag02/5Qr+Bf8AsN61/wCl8tfpRQAUUUUAFFFFAGX40/5E3Vv+vOb/ANAavyT/AODK/wD5RYfED/squo/+mjR6/Wzxp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj0AfoB/wAFSfjd4o/Zz/YS8deMvBup/wBj+JNH+wfY7z7NFceT5uoW0L/JKro2Y5HX5lOM5GCAR+Wfw3/4KRftyfGPQ5dU8IX3jbxVpsE5tZbvR/ANnfQRzBVYxl4rJlDhXQlSc4ZT3FfpD/wW2/5Rh/E3/uFf+nazryr/AINwv+TIPFX/AGPN3/6QafX7LwpiMDl/CNbNa+Ep15xr8q54p6OMNLtN2V27bas8nFRnUxSpRk4q19H5s+U/+Gyf+Ch3/QH+K3/hsIf/AJAo/wCGyf8Agod/0B/it/4bCH/5Ar9rKK8//iJGA/6FGG/8Aj/8iaf2fP8A5+y+8/FP/hsn/god/wBAf4rf+Gwh/wDkCj/hsn/god/0B/it/wCGwh/+QK/aym5/76o/4iRgP+hRhv8AwCP/AMiH9nz/AOfsvvPxV/4bJ/4KHf8AQH+K3/hsIf8A5Ao/4bJ/4KHf9Af4rf8AhsIf/kCv2ogkWaPcrbh0zVHxB4l0/wAK2DXWp31np9upx5txKsSfm1H/ABEjAf8AQow3/gEf/kQ/s+f/AD9l95+Mv/DZP/BQ7/oD/Fb/AMNhD/8AIFH/AA2T/wAFDv8AoD/Fb/w2EP8A8gV+zXh/xDp/ibTlutMvrPULWQ4Wa1lWaNv+BLxVy2mS4i3IyuuSMr060f8AESMB/wBCjDf+AR/+RD+z5/8AP2X3n4s/8Nk/8FDv+gP8Vv8Aw2EP/wAgUf8ADZP/AAUO/wCgP8Vv/DYQ/wDyBX7TzSpFhWbb5nyipaP+IkYD/oUYb/wCP/yIf2fP/n7L7z8U/wDhsn/god/0B/it/wCGwh/+QKP+Gyf+Ch3/AEB/it/4bCH/AOQK+wv2/P8AgsQv7LP7eHwY/Z38C+DR8R/iB8TNUtjrVtFfeV/wjelvKqvMyhG3SNELiXDMqpHBvb5XWvs/V/FmmeFkt11TVNP017qTZF9quEg81/RN33qP+IkYD/oUYb/wCP8A8iH9nz/5+y+8/G7/AIbJ/wCCh3/QH+K3/hsIf/kCj/hsn/god/0B/it/4bCH/wCQK/amMhkUr8wp9H/ESMB/0KMN/wCAR/8AkQ/s+f8Az9l95+Kf/DZP/BQ7/oD/ABW/8NhD/wDIFH/DZP8AwUO/6A/xW/8ADYQ//IFftZUNxMkMbPI8aovc/wANH/ESMB/0KMN/4BH/AORD+z5/8/Zfefiz/wANk/8ABQ7/AKA/xW/8NhD/APIFH/DZP/BQ7/oD/Fb/AMNhD/8AIFftUn3Rt+7Ucl1HDcJG0iq8n3V/vUf8RIwH/Qow3/gEf/kQ/s+f/P2X3n4s/wDDZP8AwUO/6A/xW/8ADYQ//IFH/DZP/BQ7/oD/ABW/8NhD/wDIFftWn3aWj/iJGA/6FGG/8Aj/APIh/Z8/+fsvvPxT/wCGyf8Agod/0B/it/4bCH/5Ao/4bJ/4KHf9Af4rf+Gwh/8AkCv2soo/4iRgP+hRhv8AwCP/AMiH9nz/AOfsvvPxT/4bJ/4KHf8AQH+K3/hsIf8A5ArK8b/8FBP28vhn4Yutc8SN8QPD+i2Oz7Rf6l8O7W0tbfe6ou+SSxCrudlUZPJYDqRX7g18qf8ABbb/AJRh/E3/ALhX/p2s69PJeOMux2Y0MFPKcOlUnCDahG6UpJX+HpcyrYOpCnKaqy0Te5lf8EUv2pPHn7W/7K+v+JPiFrv/AAkGtWPiu402G4+xW9pst0tLORU2wRopw8shyRn5sZwAB9gV+f8A/wAG4X/JkHir/sebv/0g0+v0Ar4PjvDUsPn+Ko0IqMIzskkkkrLZLRHbg5OVCLlvYKKKK+TOo+f/APgrD/yix/aU/wCyVeKP/TRdV82/8Grh/wCNIfwn/wCvzXf/AE831fSX/BWH/lFj+0p/2SrxR/6aLqvm3/g1cP8AxpD+E/8A1+a7/wCnm+oA/RKiiigAooooAKKKKACivxW/4h4P23P+ki3xW/8AB5r3/wAsKP8AiHg/bc/6SLfFb/wea9/8sKAP2por8Vv+IeD9tz/pIt8Vv/B5r3/ywo/4h4P23P8ApIt8Vv8Awea9/wDLCgD9qaK/Fb/iHg/bc/6SLfFb/wAHmvf/ACwo/wCIeD9tz/pIt8Vv/B5r3/ywoA/amivxW/4h4P23P+ki3xW/8Hmvf/LCj/iHg/bc/wCki3xW/wDB5r3/AMsKAP2por8Vf+IeD9t77v8Aw8U+Km3/ALDmvf8AydTv+Id79t3/AKSKfFb/AMHmvf8AywoA/aivOf2uv+TTvih/2KWq/wDpFLX5Of8AEPB+25/0kW+K3/g817/5YVzXxr/4IIftk+B/gn4v1nVf+CgHxP1vT9K0O9u7zT5tY1xor6GO3dngO++ZWDr8vzL3oA+pv+DTb/lCv4F/7Detf+l8tfpRX5sf8Gnfzf8ABFzwP/2HNa/9L5a/SegCF8F/896+Efj7/wAHJv7H/wCzl8VdU8F658Tpr7XtBumsdSTStDv7+2tJ1++nnRwmN2VuG2M21gV+8rLX2B8e/AupfFP4IeM/Deia5c+F9a8RaHe6XYazarum0u4nt3jS4Qd2jYq4/wB0V8U/8E1/+De34D/sZfs0af4T8d/D/wCGPxk8ZTXMl7q3ifXvClrqDXTyP8kcKXQmaGKOLy12oVVsFzhmNAH1T+yB+2/8Lv29vha3jb4S+LrDxl4fgna0uJ4Y5bea1uFVT5UsMyJJG21g3zKu5SrDKtXr6dK/FX/gjd4I039mD/g49/a8+E/w3i/sf4S2vhxNWOlWu/7DY6gJdMdURc/L5f2y/RVX5VUbV+VVr9qo/uCgDN8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9frZ40/wCRN1b/AK85v/QGr8k/+DK//lFh8QP+yq6j/wCmjR6APtX/AILbf8ow/ib/ANwr/wBO1nXlX/BuF/yZB4q/7Hm7/wDSDT69V/4Lbf8AKMP4m/8AcK/9O1nXlX/BuF/yZB4q/wCx5u//AEg0+v1XA/8AJvsR/wBhK/8ASYHmy/36P+H9WffUvytu/wAtXi/jj/go5+z38KvF1/4d8VfHb4NeF/EOlP5V7pmreNtNs7y0fbu2vFLMro21lb5l6EV7M+3zG4/z6/pXwD8Yv+DY79kH45/FPxB4y1vwHrS6x4ov5dSvvsniG8tYWnlO52WJX2ruYs3H8Rr8qPSPpDwp/wAFLv2cviB4jsdH0P4/fBPXdY1SYQWWn6f430y5uruVukcaJOWZ/Za8L/4L+f8ABSg/8E0f+Cf3iLXNHvjZ/ELxsr+HPCYRws1tdSo2++Xhv+PaMmX7u3zPLU/fWuP8Gf8ABrT+xv4G8Yabq9r4C16a40m6ju4ILnxNeyws6NuXeu/5lJA6/wB2vqn9rT9i74aftUR+G9X+IHhHS/FF98O7mTWNAF8z+VY3SxMvm7FdY5eMbUl3IrYfbuWgD87P+DNPxPqfif8A4JyfEKO+1S+1JbP4jXiw/abl5FiD2FhLJsVj8u6R5H+XG5nZm+arHxb/AOCGvxS/4Kpf8FF/ib4u/aq8Ua1p/wAGPC+pCz+Hnhfw5r6tBfWexdlxsZG8ncv+tZlWV5fMVW8tEZsn/gywDH/gnH8SlkGY/wDhY9wv/lL05SP/AEGtT9qT/gtX+1P8ef27fiR8GP2L/hL4P+IVr8I3+weJNX1txvW83+U6xO95awRKkqyRbX3uzRSMPlU0AeLfDv8AZf8A+HEP/BeH4G/Dv4P+NvGd98Lfj7BPFrXhzW7oSxQMzyxof3exZPKdImjlZN+1XTzHV3r2P/g3Q+IGvfAL9tv9rj9ljxfq2pX154L8V3Xinw8mp37XVzNZy3TJNcfMzLtdZNPmbHzb7li3zMav/sif8EvP2rv2kP8AgqD4J/aQ/a81rwHbx/C/S5bfw1oHhqXzI2nZp/KbYqsiKrXDymXzGlZooVPyrXm3/BVj4kab/wAElP8Ag4i+En7RuobbHwR8XPCd1pHihkQs1xNbw/ZnJx/dVtMb/tlQB3eo/EzxN+29/wAHXGk+HdE1nVrPwB+y14Xmn1GCCZ/sd1dz2uyVvl+XzGl1GKFlf+Cxk21+i/7dv7YvhX9gL9lTxl8VvGEwbSfCtizpbCbZcalcsypb2sX/AE0lkKqD/Dnd90Ma/PH/AINPPhDf+MPgv8af2l/Eltt8UfH/AMcXd0JFB2/ZYp5JHdP968ubpW/691ry/wDbf1i6/wCDhT/gsPo/7O+g3FxN+z1+z5dNqnji/tpNsepXy7opERl+bduzaJyNv+lPQB2H/BCH4AaxpXgj4tf8FEP2hmgm8cfEXTb7XtOZnEUej6DBF5ssyK5/dLJHbokQZjttoovm2yvXg/7Av/BKLxB/wcd+DPFH7SP7S3xU8eWsGsare6X4P0fQ5LeODSYIn6r5qOqwJKzJ5SpGzeRuZ2Z/l/Yz/go14B8//gl78dvDPh+xVGk+FniDS9MsII/LUZ0i4iihRf4R91QvbFfM3/BqdrNtqf8AwRR+GkNvcLLNp+p63BdID80Mrapcy7T/AMAdW/4FQB5d/wAG8vxX+KXwO/al/aF/ZA+JPi+6+Itn8D5oLjw7rlwztOto74EW2R3ZI2je3dYtzCJmdAzKFr9bo/uCvyF/4JOxDTP+Djb9uq2Zorp5YbK4WVM/KrPE3lf3f4wvP92vvL4F/wDBTr4K/tKftZeOvgl4O8Yrq3xH+HguDrunLZ3EaWxt50t7nZM6CN/KldEbY33qAPol/u1/Pr/weF/8FO5r3xNo37MHhHUZI7exWHxD43kt7jb5jvEzWlg6r821Yz9odW+95tv/AHa/oFB/dr/B9e3tX5Ef8HQ37Fvwv+HH/BP74yfGLRvBul2fxO8a6hoNjrXiFd73NxbpeWcaJ8zMsS/6JAv7tV3becnc1AH6a/sn391qv7Lfw2ury4lur668L6XLPcTSebJcSm0iZ3Zv4mZicmvwC/4OFP8Agppr3w8/4LweAtT8M32uTaJ+zINJvLy2s2PledNKlzfH+H5Z7e4trVtzbP4f46/eb9mzxLY+CP2JfAOsalNHa6Vo/gjT7y6m+6sMMVhG7N7KqKT1r+ZT4Z/tYfAD4+/ss/t2eJPi343bQ/i98eNXbWPB+iy6bf30ym1uH1O3iW5it3iiWSVktfnlVVWL5lVdrUAf1b+FNes/FPhyw1PT5o7jT9St0urWZTlZInUOjD22kVp18F/8G5P7XFr+1j/wSf8Ahm0mo2974h8A2Z8JaxClwZpbV7ImK2LhgGVntRbvz/f79a+8k6UAOooooAK+VP8Agtt/yjD+Jv8A3Cv/AE7WdfVdfKn/AAW2/wCUYfxN/wC4V/6drOvouEP+R9gv+v1P/wBLic+K/gT9H+R5V/wbhf8AJkHir/sebv8A9INPr9AK/P8A/wCDcL/kyDxV/wBjzd/+kGn1+gFej4h/8lJjP8b/ACRGB/3eHoFFFFfGHWfP/wDwVh/5RY/tKf8AZKvFH/pouq+bf+DVw/8AGkP4T/8AX5rv/p5vq+kv+CsP/KLH9pT/ALJV4o/9NF1Xzb/wauH/AI0h/Cf/AK/Nd/8ATzfUAfolRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFec/tdf8mnfFD/ALFLVf8A0ilr0avOf2uv+TTvih/2KWq/+kUtAHw7/wAGm3/KFfwL/wBhvWv/AEvlr9KK/Nf/AINNv+UK/gX/ALDetf8ApfLX6UUAeUftn/tDD9lL9lP4j/ExrT7c3gXw3f6zFaMdq3kkELSpF/wJlC+vzHpX46fsf/sbftt/8Fvv2fNF+Mnj79rrxB8K/BXja9ubjTdA8L2U1q/2SK4lg2+VbTW67N0TbPNadtu12ZmZs/sT+2p+zNYftlfsrePvhdqerX2h2fjrR5dKlvrNd09t5g+8q5+bp8yfxLxX5O+EP+DTH4s+CvDdppOg/t4fEbRNIsU8q2srLw3eW1tbpnokSawFRfbFAH35/wAEtP8Agj/8OP8AglJ4a8RjwpqGveKfFHjKZLnXvEuuzpJeXu1mZE+QKqRqzO3RmZnZmavruAbYFG3bx0PaviH/AIJMf8EovG//AATYv/F1x4u/aN+IHxwbxKkEUFtrFvNb2OmrES29Ipbm6YytuxuV0+X+E/er7fh/1QG3b2xQBneNP+RN1b/rzm/9AavyT/4Mr/8AlFh8QP8Asquo/wDpo0ev1s8af8ibq3/XnN/6A1fkn/wZX/8AKLD4gf8AZVdR/wDTRo9AH2r/AMFtv+UYfxN/7hX/AKdrOvKv+DcL/kyDxV/2PN3/AOkGn16r/wAFtv8AlGH8Tf8AuFf+nazr4+/4Ipf8FEvg7+yR+yvr/hv4heMP+Ef1q+8V3GpQ2/8AZV9d77d7SzjV90ELqMvFIME5+XOMEE/sGS4HE4zgKvRwlOVSf1i9opyduSHRJs8qtUjDGpydly9fVn62UV8qf8Ptv2Yf+im/+W7q3/yLR/w+2/Zh/wCim/8Alu6t/wDItfA/6oZ9/wBAVb/wVP8A+RO361R/nX3o+q6+QP8Agrn4n/av8MfCDQf+GU/Bvgvxlrl3fvDr1vrt3Fbzx2pj2p5PnTQQn5/vFpd/3Nit8zLqf8Ptv2Yf+im/+W7q3/yLR/w+2/Zh/wCim/8Alu6t/wDItH+qGff9AVb/AMFT/wDkQ+tUf5196Pgv/g2p/Yi/bM/4J5+Lte+HvxM+GPhvwt8G9emuPEFzqE+vWN1qkOptDBBGIRZzTLIpWFd0UqIq/fEuV8uTx/4Sfsa/8FK/+Cc/7YX7QniT4IfCjwT4l0f4weK5dXn1G/1rSpY7qFLq7nt2iSa+t5UbbeSqwkT7wP8AvV+qn/D7b9mH/opv/lu6t/8AItH/AA+2/Zh/6Kb/AOW7q3/yLR/qhn3/AEBVv/BU/wD5EPrVH+dfej5y/wCCeHxe/wCCmvi39p7Q7P8AaA+Ffww8L/C9kmOsX8OoWX2mPCfJ5AtL64dpDJ/C6BNv8S11/wDwcO/8EtfFP/BUz9j7QdD8BjST488H69Dqtguoz/Zorq3ZJILmHftbZuV0f/a8rbXr3/D7b9mH/opv/lu6t/8AItH/AA+2/Zh/6Kb/AOW7q3/yLR/qhn3/AEBVv/BU/wD5EPrVH+dfejH0X9jD4h/ss/8ABGu0+CPwb1TSdP8Aif4f8Dx6HpmqMzRW39pui/a7xMkmNmle4lQ/Ntdlba33aof8ESv+CWGn/wDBKn9jyx8Iztp99498QOur+MNUtAzpcXrLtWCJ2XmGBNqINq7m3ybV8zbXT/8AD7b9mH/opv8A5burf/ItH/D7b9mH/opv/lu6t/8AItH+qGff9AVb/wAFT/8AkQ+tUf5196PpfU9Ph1CyeC6hhktZoWimidN4dG6pjb8ysudwr8UPCH/BNz9vL/gjd8Q/Hfh39kOHwP8AEj4M+ONXOqWOn6/e28d14dlZBG0r/aJrf94kaIhdHlWRYo9ybty1+jH/AA+2/Zh/6Kb/AOW7q3/yLR/w+2/Zh/6Kb/5burf/ACLR/qhn3/QFW/8ABU//AJEPrVH+dfejyH/ghv8A8EqPGX7AunfEb4ifGTxNp/jL45fGjUl1LxLe2krSwWUaPI4iEjIm+RpJZHdlRVBMaLuVA7er/sz/APBIL4Ofsqftv/Eb4/8AhW38Sf8ACd/FA3r6mL3UjNYwG8uo7q7MMW3cnmTxh9rs21mZV2rtVZ/+H237MP8A0U3/AMt3Vv8A5Fo/4fbfsw/9FN/8t3Vv/kWj/VDPv+gKt/4Kn/8AIh9ao/zr70fUvHl+39K/HX/g4L/Z9/by/bc17xF8IPhp8LfBvib4DanHp13Z39rrOn22qS3UL+c/m/a7qJo3WRCuFRozHsO/ezKv3L/w+2/Zh/6Kb/5burf/ACLR/wAPtv2Yf+im/wDlu6t/8i0f6oZ9/wBAVb/wVP8A+RD61R/nX3o+fvhr8CP2wvj7/wAEQviV8KPij4d8B+Cvi1qmgXHhPw7bWuopJHcaX9nittly0LyQpPLAJkR1lZfnTeqfMtdF+w1/wb1/s/8AwQ/ZM8A+FfiR8I/hr448faTpIXxDrVzpn2pry9lZpJtkrorSRI7ukbMqt5aRfdr1/wD4fbfsw/8ARTf/AC3dW/8AkWj/AIfbfsw/9FN/8t3Vv/kWj/VDPv8AoCrf+Cp//Ih9ao/zr70eSf8ABEL/AIJhePv+CX/in9oDQtau/Dcnw78XeMBrPgaz0ud5nt7VvO/1xdVZJPK+yRMvzDdA2GZcM36CR/cXua+Vv+H237MP/RTf/Ld1b/5Fo/4fbfsw/wDRTf8Ay3dW/wDkWj/VDPv+gKt/4Kn/APIh9ao/zr70fVdFfKn/AA+2/Zh/6Kb/AOW7q3/yLR/w+2/Zh/6Kb/5burf/ACLR/qhn3/QFW/8ABU//AJEPrVH+dfej6rr5U/4Lbf8AKMP4m/8AcK/9O1nR/wAPtv2Yf+im/wDlu6t/8i18/wD/AAVJ/wCCpPwJ/aM/YS8deDfBvjr+2PEmsfYPsdn/AGLqFv53lahbTP8APLAiLiON2+ZhnGBkkA+9wrwtnVLOsHVq4OrGMatNtunNJJTTbbaskluzHE4mi6MkpLZ9V2Or/wCDcL/kyDxV/wBjzd/+kGn1+gFfn/8A8G4X/JkHir/sebv/ANINPr9AK4vEP/kpMZ/jf5IvA/7vD0CiiivjDrPn/wD4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9X0l/wVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/wDpFLXo1ec/tdf8mnfFD/sUtV/9IpaAPw5/4IQf8HCP7Ov/AAT3/wCCcfhb4X/Ea+8Xw+J9L1HULm4TT9Da6g2T3UsiYdX+b5Sv519lf8Ren7Haj/kJfET/AMJl/wD4uof+DVr4Z+GfE3/BGzwPfap4e0HUbt9Z1hTNcafFLKf9OkHLMuT2r9HP+FIeCf8AoT/C/wD4KIP/AIigD86f+IvX9jr/AKCnxE/8Jh//AIuj/iL1/Y6/6CnxE/8ACYf/AOLr9Fv+FHeCP+hP8L/+CiD/AOIo/wCFHeCP+hP8L/8Agog/+IoA/On/AIi9f2Ov+gp8RP8AwmH/APi6P+IvX9jr/oKfET/wmH/+Lr9Fv+FHeCP+hP8AC/8A4KIP/iKP+FHeCP8AoT/C/wD4KIP/AIigD81/En/B3D+yDqmg31vFqXxCaS4tniQHw06biysv3t/yjOK+Df8Ag3G/4LnfAX/gmT+xJ4o8A/FK78U22vat45utft103R3vImtpLDToEYsr/K/mWr8V/QJ4v+CHguLwxqsieEfDKvHaS7SNJt933CeMJur8qf8Agze+Hfh/xn/wTF8cXGqaHo+qTR/E/UIEku7OKV40/snSWwrMm7vQBqftQ/8ABzH+w/8AtafAXW/h54k174s2Wi+IBb/aJtN8O+XdJ5NxFcLsaTeoy8Sg5U8E9Dgj5B/4a4/4Jlf9D7+01/4K7P8A+Ra/oW/4Uh4JPJ8H+F2/7hUDf+yUf8KO8Ef9Cf4X/wDBRB/8RX0GU8VZtllF0MBXlTi3dpbXslf7kvuMKmGpVHzTjdn89P8Aw1x/wTK/6H39pr/wV2f/AMi0f8Ncf8Eyv+h9/aa/8Fdn/wDItf0Lf8KO8Ef9Cf4X/wDBRB/8RR/wo7wR/wBCf4X/APBRB/8AEV6f/EQ+JP8AoMn96/yM/qGH/kR/PT/w1x/wTK/6H39pr/wV2f8A8i0f8Ncf8Eyv+h9/aa/8Fdn/APItf0Lf8KO8Ef8AQn+F/wDwUQf/ABFH/CjvBH/Qn+F//BRB/wDEUf8AEQ+JP+gyf3r/ACD6hh/5Efz0/wDDXH/BMr/off2mv/BXZ/8AyLR/w1x/wTK/6H39pr/wV2f/AMi1/Qt/wo7wR/0J/hf/AMFEH/xFH/CjvBH/AEJ/hf8A8FEH/wARR/xEPiT/AKDJ/ev8g+oYf+RH89P/AA1x/wAEyv8Aoff2mv8AwV2f/wAi0f8ADXH/AATK/wCh9/aa/wDBXZ//ACLX9C3/AAo7wR/0J/hf/wAFEH/xFH/CjvBH/Qn+F/8AwUQf/EUf8RD4k/6DJ/ev8g+oYf8AkR/PT/w1x/wTK/6H39pr/wAFdn/8i0f8Ncf8Eyv+h9/aa/8ABXZ//Itf0Lf8KO8Ef9Cf4X/8FEH/AMRR/wAKO8Ef9Cf4X/8ABRB/8RR/xEPiT/oMn96/yD6hh/5Efz0/8Ncf8Eyv+h9/aa/8Fdn/APItH/DXH/BMr/off2mv/BXZ/wDyLX9C3/CjvBH/AEJ/hf8A8FEH/wARR/wo7wR/0J/hf/wUQf8AxFH/ABEPiT/oMn96/wAg+oYf+RH89P8Aw1x/wTK/6H39pr/wV2f/AMi0f8Ncf8Eyv+h9/aa/8Fdn/wDItf0Lf8KO8Ef9Cf4X/wDBRB/8RR/wo7wR/wBCf4X/APBRB/8AEUf8RD4k/wCgyf3r/IPqGH/kR/PT/wANcf8ABMr/AKH39pr/AMFdn/8AItH/AA1x/wAEyv8Aoff2mv8AwV2f/wAi1/Qt/wAKO8Ef9Cf4X/8ABRB/8RR/wo7wR/0J/hf/AMFEH/xFH/EQ+JP+gyf3r/IPqGH/AJEfz0/8Ncf8Eyv+h9/aa/8ABXZ//ItH/DXH/BMr/off2mv/AAV2f/yLX9C3/CjvBH/Qn+F//BRB/wDEUf8ACjvBH/Qn+F//AAUQf/EUf8RD4k/6DJ/ev8g+oYf+RH89P/DXH/BMr/off2mv/BXZ/wDyLR/w1x/wTK/6H39pr/wV2f8A8i1/Qt/wo7wR/wBCf4X/APBRB/8AEUf8KO8Ef9Cf4X/8FEH/AMRR/wARD4k/6DJ/ev8AIPqGH/kR/PT/AMNcf8Eyv+h9/aa/8Fdn/wDItH/DXH/BMr/off2mv/BXZ/8AyLX9C3/CjvBH/Qn+F/8AwUQf/EUf8KO8Ef8AQn+F/wDwUQf/ABFH/EQ+JP8AoMn96/yD6hh/5Efz0/8ADXH/AATK/wCh9/aa/wDBXZ//ACLR/wANcf8ABMr/AKH39pr/AMFdn/8AItf0Lf8ACjvBH/Qn+F//AAUQf/EUf8KO8Ef9Cf4X/wDBRB/8RR/xEPiT/oMn96/yD6hh/wCRH5E/sUf8HD37CH7B/wAK9Q8IeEPEfxk1LTdS1WTWJZdY8PrNOszwwwlQYljXZtgQgFScluegHsH/ABF6/sdf9BT4if8AhMP/APF1+i3/AAo7wR/0J/hf/wAFEH/xFH/CjvBH/Qn+F/8AwUQf/EV8tjMZXxdeWJxMnKcndt7tnTCKjHljsfnT/wARev7HX/QU+In/AITD/wDxdH/EXr+x1/0FPiJ/4TD/APxdfot/wo7wR/0J/hf/AMFEH/xFH/CjvBH/AEJ/hf8A8FEH/wARXKUfkh+3b/wdF/sq/tD/ALEvxk8BeHb3x6/iDxz4H1rw9pqz+HjHHJc3WnzwQ723/KnmSr81fRP/AAauf8oQPhL/ANfmuf8Ap3vK9s/4KnfB7wnpP/BMr9oq6tfC/hy2uLf4YeJpY5Y9OijkicaTc8qypmvE/wDg1b/5Qf8Awl2/8/mu/wDp3vKAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/wAmnfFD/sUtV/8ASKWgD4d/4NNv+UK/gX/sN61/6Xy1+lFfmv8A8Gm3/KFfwL/2G9a/9L5a/SigAooooAKKKKAMvxp/yJurf9ec3/oDV+Sf/Blf/wAosPiB/wBlV1H/ANNGj1+tnjT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHoA/YCiiigAoor4T/wCDib9sq6/Yl/4JdfEHXtJ1J9J8UeLEi8K6BcQXjWt1HdXTbZXhdfmEsdqtzKrDG3yvvc0AfdlFfln/AMGn/wC2Nrn7Tf8AwTivvC/i3VNT1fxX8KfENzoskup3j3V9JZSqtxb72k+cKrPNCqszbVtwo2qFVfm744/CT4gf8HA//BYT46fCPU/jF4g8H/AX4ENFp8mlaDh47+bKwOjpv8t5WuYrlt8qybVi2KnzUAfu7RX44fsT/sCfHr/gjV/wVX8D+A/h/rnjz4qfss/E7TLqK7fVN0tv4RuYLeVw8pX91FIHRdrxrF56Tsm1mRWr5g/4IYf8FovEnwt/4KtfEb4R/Fjxdr2u+E/ix4t1C30i51nUjNHoOsfapfJVd7fuo7jmFkT5fMaD5du6gD+i6ivyY/4K3/tI+Pvhf/wXN/Y48LeH/F3iDR/D+rWd8b3Sra8ZLPUHlaWFnnQHbL8qpt3q21l3Ltb5q+Fv+CEP/BKO+/4K6/sx+MPiJ41+P3xw8P6to/iybRFi0nXHdZ4ltbW581nm3NuZp36nHHrQB/ShRX4f/sey/Gj/AIJA/wDBcj4d/su+JPjZ4s+Lvwp+K3hy51LTP+EikcNpbhL57aOJpHm2yo+niIojxxv9qDeWu6v28tyvkrtbcMcEd6AJKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+f8A/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831fSX/AAVh/wCUWP7Sn/ZKvFH/AKaLqvm3/g1cP/GkP4T/APX5rv8A6eb6gD9EqKKKACiiigAooooA/G3/AIYL/wCCw3/R2vwR/wC/f/3io/4YL/4LDf8AR2vwR/79/wD3ir9kqKAPxt/4YL/4LDf9Ha/BH/v3/wDeKj/hgv8A4LDf9Ha/BH/v3/8AeKv2SooA/G3/AIYL/wCCw3/R2vwR/wC/f/3io/4YL/4LDf8AR2vwR/79/wD3ir9kqKAPxt/4YL/4LDf9Ha/BH/v3/wDeKj/hgv8A4LDf9Ha/BH/v3/8AeKv2SooA/Gtv2B/+Cwmd3/DWvwV3dv3X/wB4qd/wwX/wWGH/ADdr8E/xi/8AvDX7JUUAfjb/AMMF/wDBYb/o7X4I/wDfv/7xVyvx0/Ye/wCCtGkfBTxldeJf2pvg/qXh+10O9n1S2tov31xarbu00af8SVPnaPKr8y/7y1+3lec/tdf8mnfFD/sUtV/9IpaAPh7/AINO/wDlC34G+7/yHNa6Lt/5f5a/SevzX/4NNv8AlCv4F/7Detf+l8tfpRQBTudsfmMxb5hs4O39f19ua/nV/wCCqn/Ba7xV+1P/AMFhfhX8PvhN4u1zR/hj8M/HulaPdXOm3T20Wv6q+oRxXEsjIy+dAqq0USt95Ulf7r1/RXMm6dj/AA7ckfePbjH4GvxE/wCC5f7Evwv/AGFdY/ZC0P4W+E9O8K2GvfHCDV9RRJ5Z5Ly6eS13Su8ru/8AwHdtVcKNq7VoA/cSH7n3dtOpsfCCnUAZfjT/AJE3Vv8Arzm/9AavyT/4Mr/+UWHxA/7KrqP/AKaNHr9bPGn/ACJurf8AXnN/6A1fkn/wZX/8osPiB/2VXUf/AE0aPQB+wFFFFABX4d/8HInxt8JfHj/gqL+y3+zx4w8W6H4Z+H+i36eMfG1xrdzDBpawvJ8iTPLtVZGtra7RQzbd15H/AHq/bqbcJeTwvp/h+VfkZ4O/4IKSfts/8FU/2kviz+1l4Ltde8E6vqcFj4Bs7fxNcwreWsSLFFcMbSWKVNltFCmx2X97LL8rfeoA8r/4JXfH34e/Av8A4OU/j14J+HPi/wAHeJPhj8ftOfXdIutE1KO/tZNTQDUGiEyEqm3zdW/dLxt8vtWp/wAEHNT8UaJ+3D/wU+bwhp+j6x8SovGEz6Ha6xdfZoby7XUvEG1JnUMyK0uzftHcfd+9XW/tQ/8ABu7Y/s0ftn/sz/FL9jzwRb+E18H+MoJfG9vN4hurpTYtPB/pAa9mlZkWBbtHSL52WdTtqv8AtH/sh/thf8E6f+CrvxM+P/7Mvw/8N/FrwL8b7eA65od5dJFNps6eRu3K00Mqv5qyujx70VJXV03KlAHJp/wWb/b8/Zk/bd+BPw5/aG+EPwn8KaX8ZPFVlotrBp8yT3lxDJeW9tM8UsOo3CxOn2hP9avzV8k/saf8EyP+Hhv7FH7X9x4asZJPi78MfiXJr/g29tYxHfTSp57TWKSKysrXCxKFXd8sqwNX27+zJ+yP+1//AMFFv+CtPw1/aD/aU8A6H8H/AAP8G7aZtB8PWl4sst9Mwl2AKk0r7vMkjaWWTYrJAiKnzV9A/wDBAn/gnh8Tf2Cz+0N/wsXTdP03/hO/H82paMbe8F0bizXftn+X5VV/N+Xd8/3ty0AflX4Q/wCClUn/AAUx/wCCjP7Cet65I0PxG8Fw3HhzxlFIjJ5l3FLLtuN21flnj2OyfwO7p822vt7/AIMqCv8Aw7s+J2PlH/Cybjj+7/xK7CsL45/8EAPGfgz/AILz+Afjn8KtD0+b4U+JNWk8ReIQb9LZPDOoeVN5yCLHmNFO7I8TxK6rJJIrKiKhbyT/AIJfeCv+Cgn/AARt+FXjL4Y+F/2VNN+IGnal4mn1h9Vl1uFUmfyYrXMO2Zd0TLbqy7l3fN92gD6S/wCCsGn/ANq/8HJv7DMP2iS38uxvZ8r/ALBuX/8AHtm2v12j+4Pl2+1fjn+w7+xT+1T+27/wV+8L/tYftPeA/D3wp0/4a6LPpHhzQdPlSWe93LeLbh0WadkVDfXMryyOm6RYlVNv3f2MT7g70AOooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD5/wD+CsP/ACix/aU/7JV4o/8ATRdV82/8Grh/40h/Cf8A6/Nd/wDTzfV9Jf8ABWH/AJRY/tKf9kq8Uf8Apouq+bf+DVw/8aQ/hP8A9fmu/wDp5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/+kUtejV5z+11/wAmnfFD/sUtV/8ASKWgD4d/4NNv+UK/gX/sN61/6Xy1+lFfib/wbi/8FZ/2cf2Tv+CVHg/wZ8Rvi54X8JeKNP1TVZp9OvWlWWFJL13QnajD5ldW/wCBV92f8P8A39jbv+0F4Dz/ANdZv/iKAPrjUN4HyqrNk7QzsB93v+P+Pavwb/4Krab+3z+3n8Z/h+sv7Jtrpul/BXxw+v6LdafrkF4usLFOrRb5XmT926Qp86qm7P8AD92v0s/4f/8A7Gv/AEcF4F/7+zf/ABFH/D//APY1/wCjgvAv/f2b/wCIoA+hP2XPG/jb4kfs9+Ede+I3hODwL451XT47jWtBhvRex6XcN96JZV69m77d23c2Nx9Cr45/4f8A/wCxr/0cF4F/7+zf/EUf8P8A/wDY1/6OC8C/9/Zv/iKAPrLxp/yJurf9ec3/AKA1fkn/AMGV/wDyiw+IH/ZVdR/9NGj19TeK/wDgvj+x7f6BqEFv8fvA7ySW0qLiSXdlkbplPUD86/OH/g1Z/wCCnXwF/Ys/4J7eMPDHxU+J3h3wT4g1L4iXuqWtlqDS+ZJbPpumRJKu1T8u+KRf+A0AfvxRXxvH/wAHAH7Gpj/5OC8C/wDfydf/AGSnf8P/AP8AY1/6OC8C/wDf2b/4igD7Gor45/4f/wD7Gv8A0cF4F/7+zf8AxFH/AA//AP2Nf+jgvAv/AH9m/wDiKAPsaivjn/h//wDsa/8ARwXgX/v7N/8AEUf8P/8A9jX/AKOC8C/9/Zv/AIigD7Gor45/4f8A/wCxr/0cF4F/7+zf/EUf8P8A/wDY1/6OC8C/9/Zv/iKAPsaivjn/AIf/AP7Gv/RwXgX/AL+zf/EUf8P/AP8AY1/6OC8C/wDf2b/4igD7Gor45/4f/wD7Gv8A0cF4F/7+zf8AxFH/AA//AP2Nf+jgvAv/AH9m/wDiKAPsaivjn/h//wDsa/8ARwXgX/v7N/8AEUf8P/8A9jX/AKOC8C/9/Zv/AIigD7Gor45/4f8A/wCxr/0cF4F/7+zf/EUf8P8A/wDY1/6OC8C/9/Zv/iKAPsaivjn/AIf/AP7Gv/RwXgX/AL+zf/EUf8P/AP8AY1/6OC8C/wDf2b/4igD7Gor45/4f/wD7Gv8A0cF4F/7+zf8AxFH/AA//AP2Nf+jgvAv/AH9m/wDiKAPsaivjn/h//wDsa/8ARwXgX/v7N/8AEUf8P/8A9jX/AKOC8C/9/Zv/AIigD7Gor45/4f8A/wCxr/0cF4F/7+zf/EUf8P8A/wDY1/6OC8C/9/Zv/iKAPsaivjn/AIf/AP7Gv/RwXgX/AL+zf/EUf8P/AP8AY1/6OC8C/wDf2b/4igD7Gor45/4f/wD7Gv8A0cF4F/7+zf8AxFH/AA//AP2Nf+jgvAv/AH9m/wDiKAPsaivjn/h//wDsa/8ARwXgX/v7N/8AEUf8P/8A9jX/AKOC8C/9/Zv/AIigD0b/AIKw/wDKLH9pT/slXij/ANNF1Xzb/wAGrh/40h/Cf/r813/0831c/wD8FG/+C3X7KPxZ/wCCfnx38L+Hfjd4N1jxF4k+HfiDStLsoWl33l1PplzFDEhZNu9ndV6/x10H/Bq3/wAoPvhP/wBfmu/+ne8oA/RKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK85/a6/wCTTvih/wBilqv/AKRS16NXnP7XX/Jp3xQ/7FLVf/SKWgD8pP8Ag2z/AOCY/wCz3+05/wAEoPBvi74hfB/wJ4w8TXmq6rDPqeqaUk88qR3siorO3Xaqqv8AurX3r/w4/wD2RJPmb9nf4V7u/wDxI468D/4NNv8AlCv4F/7Detf+l8tfpRQB8q/8OO/2Q/8Ao3X4U/8Agjio/wCHHf7If/Ruvwp/8EcVfVVFAHyr/wAOO/2Q/wDo3X4U/wDgjio/4cd/sh/9G6/Cn/wRxV9VUUAfKv8Aw47/AGQ/+jdfhT/4I4qP+HHf7If/AEbr8Kf/AARxV9VUUAfKv/Djv9kP/o3X4U/+COKj/hx3+yH/ANG6/Cn/AMEcVfVVFAHyr/w47/ZD/wCjdfhT/wCCOKj/AIcd/sh/9G6/Cn/wRxV9VUUAfKv/AA47/ZD/AOjdfhT/AOCOKj/hx3+yH/0br8Kf/BHFX1VRQB8q/wDDjv8AZD/6N1+FP/gjio/4cd/sh/8ARuvwp/8ABHFX1VRQB8q/8OO/2Q/+jdfhT/4I4qP+HHf7If8A0br8Kf8AwRxV9VUUAfKv/Djv9kP/AKN1+FP/AII4qP8Ahx3+yH/0br8Kf/BHFX1VRQB8q/8ADjv9kP8A6N1+FP8A4I4qP+HHf7If/Ruvwp/8EcVfVVFAHyr/AMOO/wBkP/o3X4U/+COKj/hx3+yH/wBG6/Cn/wAEcVfVVFAHyr/w47/ZD/6N1+FP/gjio/4cd/sh/wDRuvwp/wDBHFX1VRQB8q/8OO/2Q/8Ao3X4U/8Agjio/wCHHf7If/Ruvwp/8EcVfVVFAHyr/wAOO/2Q/wDo3X4U/wDgjio/4cd/sh/9G6/Cn/wRxV9VUUAfKv8Aw47/AGQ/+jdfhT/4I4qP+HHf7If/AEbr8Kf/AARxV9VUUAfKv/Djv9kP/o3X4U/+COKj/hx3+yH/ANG6/Cn/AMEcVfVVFAHyr/w47/ZD/wCjdfhT/wCCOKj/AIcd/sh/9G6/Cn/wRxV9VUUAfKv/AA47/ZD/AOjdfhT/AOCOKj/hx3+yH/0br8Kf/BHFX1VRQB+dH/BSH/gj9+y78MP+CeHx58ReHfgP8NNH1zw98O/EGpabf2+jRLPZXMGm3MsMsbdVdHVW/wCA1L/waw/L/wAERPhOOn+m678v93/icXvFfSX/AAVh/wCUWP7Sn/ZKvFH/AKaLqvm3/g1cP/GkP4T/APX5rv8A6eb6gD9EqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArzn9rr/k074of9ilqv/pFLXo1ec/tdf8AJp3xQ/7FLVf/AEiloA+Hf+DTb/lCv4F/7Detf+l8tfpRX5r/APBpt/yhX8C/9hvWv/S+Wv0ooAKKKKACiiigAooooAKKKKACiiigAooooA4z46fG7w3+zb8JvEXjzxlqa6R4W8KWT6hqV4YHl+zwoPnbaiszdvurXw9/xFRfsQRYX/hbGqHd/wBSlrP9bavS/wDgv9x/wRz/AGgON3/FN+nT/SIsY91bmvGP+CJH/BOj9n34r/8ABKX4I+JPFHwH+C/ibxDq3h1Zr3VNV8E6deXl6/nSLukkmiaR22qOWagD6c/ZZ/4Ks/s+/tlfC/xX428A/E7Q9U8N+Bbb7Z4huLwS6a+g2+JG865S4VGSLbFIwdl24jf5q8J1v/g6F/Yk0DW7uzk+L1xcSWbtC8lt4V1eaOVh12SLbbWXj7y/K3VWK/NX4v8A/BSrH7J/7en/AAUC8CfCmxsPB3gW58E6PBdaTpFulvYwxPqXhpXCRoNq7nu7hCq/w3Utfs1/wSe/4Jlfs3+OP+CZfwJ1jWfgP8GfEOta94F0jUNQ1PVPB9hqF5eXMtrG7yySyxNIzMzPzu+X7v8ADQB7jpv/AAV1/Z18Q/sd6x8eNN+Juk3fwx8Pzi01HV4YZ2lsrlmiVLd7Yp56zM0sW1DH8wZW+6Q1eEx/8HU/7D6Rhf8Aha+qL/3KGr//ACNXy3/wRN+C/g3wp/wWG/b0+Ctr4d0a++E11NFK3hm8tornSmRbt9sX2dw0TRqtw6qrL8qqq19E/wDBZz4Qfsq/8E4f+Cenjr4hQ/s6/s+w+KLi2/sXwrA/gDSFNxq1wrLDtVoV3eUu+4ZFO7y7eXbzQB9Lfsef8FaPgD+3n4M8aeJfhv8AECz1LRPh3HFL4jur+0uNJXSY5UkkSZzdJF+6ZYZvn+7+4avG5f8Ag5k/YnHj3/hHv+F1WfnfbPsRvG8P6p/Z/mbtufP+zbDHu/5a7vL/AIt+35q/LP8AaB/Zsuv+CWn/AAaw2NrdWt3pvjj9pjxTpMviCUQ+VPaW8iT3trZy/dZUW2sVDo25lkup0Zea/R34u/8ABCf4EaH/AMEi/EXgjRPhL8Pn+IFn8Op1svFE+jWp1ubWIrDfFdPfeV5u5rlQz7Tt2s6javy0Afoz4e1+z8T6DZ6jp95b6hY6lAl1a3VvKs0NxFINyOjoSrKykEMpw2eK8w+Pn7b/AMLf2ZPi14D8F+OvG2k+HvE3xQvxpfhrT5w5lv5/ugfKpEatI6IrylUaR0QfM1fJH/BsN8ar/wCKf/BF74bvfyXGoX3hCfU9BBJVXaKC7eS3iH+ysLwxL7KtfjN8dPH/AMY/2sP+CxP7PX7Q3xW8N614R8P/ABI+LGn6P4H0rVLV7O6sdJ0zVNMdE8p+RHt1BD5n3ZJ2nK/LQB/VhA2Yx/8AFZp9RwbhEu5tzdzUlABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHz/wD8FYf+UWP7Sn/ZKvFH/pouq+bf+DVw/wDGkP4T/wDX5rv/AKeb6vpL/grD/wAosf2lP+yVeKP/AE0XVfNv/Bq4f+NIfwn/AOvzXf8A0831AH6JUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnP7XX/Jp3xQ/7FLVf/SKWvRq85/a6/5NO+KH/Ypar/6RS0AfDv8Awabf8oV/Av8A2G9a/wDS+Wv0or81/wDg02/5Qr+Bf+w3rX/pfLX6UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfG/8AwX/bH/BHL9oHDbWHhknj/rtF19mxivzd/wCCWf8Awbm6D+1h+wD8K/iNcftAfHTwtceLNI+3NpWj6okFnYt5si7YkZW+X5f51+z37V/7N3h79r/9n3xh8MfFi6g3h7xtpsumXr2cvlTxo3R0b+8rbWXO5c9VxUn7KP7OPh/9j/8AZx8HfDLwqt0PD/gvTY9Os3u5fNuJsfM0krdPMdyzNtwu5vlCrhQAfHH7J/8Awbq/AD9j74G/Fzwlfah4u8ZW/wAXtL/s3xPq/iLUYlnW1VmlBhMSIIdsn73e25t6bj8qqteGaJ/waM/DXw3pMlp4U/aG+Pui+G7j9/b2dvqdqqYcZZmMcSI7Mv8AFsWv1E/aO+Buk/tN/Ajxl8O/ET6hD4f8baNdaJqLWc3lTrb3ETROUbB+ba7dfyr8xdI/4NLPB/h+wt7PT/2kv2iNPs7dQkFtBrNukdvj+6qxKNv/AAEUAeQ/8G0P7Nmi/ss/8Fd/2wvAPg/UNQ17wp8OYY/DkWoXbo1zJLFeujK+xVXzN0My/Kq/crpP+Cjly/8AwWc/4L1/Db9mWxxefCf9n0/8JN49Xy/Mtr65Xy5ZoHX+NdrW9p/stc3Ffev/AASu/wCCRHgH/glB4P8AFtj4P1bxF4o13x5fpqGt6/rskUl9ceUrLDCoRVXYu+Z/m3NvldmZhtVdv9ij/glp8NP2D/jB8YPHHg9/EWo+JvjPr83iDXLrVboT+T5s9zKLW3VUVVijkuJPvbpfm+eVl2qoB8gf8HhPwwuvGn/BJGy1Cy8tLXwX470rVbobdw8p7e8sVA/u4kvEr7H+On7VejeH/wDgkt4l+MVm9vfaR/wq2bxNZBm3R3ivpnmwx/8AbRnRP+BV6d+1F+zF4R/bI+AXiX4a+PNMXVvCviyz+zX9vu8t1+ZXjlRsfLJFKiSoSOJIkb+GvzHb/g0K+Hi+G/8AhH1/aA+PTeG/K8htKN/atasiszBNnl+Xt+ZsLt+Vm3UAeuf8GoXge58G/wDBGLwPeXXmL/wk2tatqsCv18v7a9tn8TAT/wACrxX/AIOa/wDlIv8A8E38fKv/AAsa6/8ATl4dr9TPgV+zv4b/AGa/gH4a+GfhG2uNN8LeFNKTR9PVZi08cSALvZgB+9ZmLs/975q/Mn4gf8GkHgH4m+LV1rVf2hPj9qd7bXT3tnJqGp299PZyO6PlZXRmEm5EZn/iZVb+GgD9fKK5L4JfDeH4PfCHwz4TtdX17X4fDmmwacmp61dteajqAiRU8+4mP+tlfbuZ/wCJmJrraACiiigAooooAKKKKACiiigAooooAKKKKAPn/wD4Kw/8osf2lP8AslXij/00XVfNv/Bq4f8AjSH8J/8Ar813/wBPN9X0l/wVh/5RY/tKf9kq8Uf+mi6r5t/4NXD/AMaQ/hP/ANfmu/8Ap5vqAP0SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvOf2uv+TTvih/2KWq/wDpFLXo1ZfiDQbTxNpV7p+oQR3Wn6hA1tcwSDcsyOGV0Yd1ZWxQB+QX/BtJ/wAFEvgJ+zp/wSV8F+FvHvxk+GfgzxJb6vq002m6z4itrO6iR712Uskjqy7lYMP9kq1ffY/4LE/sofd/4aQ+Ca/XxhYL/wC1a8Xm/wCDYb9hrUJpLib4GQrJIS7CPxdr0Sfgq321Rz0HFN/4hdf2FP8Aohn/AJeXiD/5OoA9q/4fG/sn/wDRyHwT/wDCysP/AI7R/wAPjf2T/wDo5D4J/wDhZWH/AMdrxX/iF1/YU/6IZ/5eXiD/AOTqP+IXX9hT/ohn/l5eIP8A5OoA9q/4fG/sn/8ARyHwT/8ACysP/jtH/D439k//AKOQ+Cf/AIWVh/8AHa8V/wCIXX9hT/ohn/l5eIP/AJOo/wCIXX9hT/ohn/l5eIP/AJOoA9q/4fG/sn/9HIfBP/wsrD/47R/w+N/ZP/6OQ+Cf/hZWH/x2vFf+IXX9hT/ohn/l5eIP/k6j/iF1/YU/6IZ/5eXiD/5OoA9q/wCHxv7J/wD0ch8E/wDwsrD/AOO0f8Pjf2T/APo5D4J/+FlYf/Ha8V/4hdf2FP8Aohn/AJeXiD/5Oo/4hdf2FP8Aohn/AJeXiD/5OoA9q/4fG/sn/wDRyHwT/wDCysP/AI7R/wAPjf2T/wDo5D4J/wDhZWH/AMdrxX/iF1/YU/6IZ/5eXiD/AOTqP+IXX9hT/ohn/l5eIP8A5OoA9q/4fG/sn/8ARyHwT/8ACysP/jtH/D439k//AKOQ+Cf/AIWVh/8AHa8V/wCIXX9hT/ohn/l5eIP/AJOo/wCIXX9hT/ohn/l5eIP/AJOoA9q/4fG/sn/9HIfBP/wsrD/47R/w+N/ZP/6OQ+Cf/hZWH/x2vFf+IXX9hT/ohn/l5eIP/k6j/iF1/YU/6IZ/5eXiD/5OoA9q/wCHxv7J/wD0ch8E/wDwsrD/AOO0f8Pjf2T/APo5D4J/+FlYf/Ha8V/4hdf2FP8Aohn/AJeXiD/5Oo/4hdf2FP8Aohn/AJeXiD/5OoA9q/4fG/sn/wDRyHwT/wDCysP/AI7R/wAPjf2T/wDo5D4J/wDhZWH/AMdrxX/iF1/YU/6IZ/5eXiD/AOTqP+IXX9hT/ohn/l5eIP8A5OoA9q/4fG/sn/8ARyHwT/8ACysP/jtH/D439k//AKOQ+Cf/AIWVh/8AHa8V/wCIXX9hT/ohn/l5eIP/AJOo/wCIXX9hT/ohn/l5eIP/AJOoA9q/4fG/sn/9HIfBP/wsrD/47R/w+N/ZP/6OQ+Cf/hZWH/x2vFf+IXX9hT/ohn/l5eIP/k6j/iF1/YU/6IZ/5eXiD/5OoA9q/wCHxv7J/wD0ch8E/wDwsrD/AOO0f8Pjf2T/APo5D4J/+FlYf/Ha8V/4hdf2FP8Aohn/AJeXiD/5Oo/4hdf2FP8Aohn/AJeXiD/5OoA9q/4fG/sn/wDRyHwT/wDCysP/AI7R/wAPjf2T/wDo5D4J/wDhZWH/AMdrxX/iF1/YU/6IZ/5eXiD/AOTqP+IXX9hT/ohn/l5eIP8A5OoA9q/4fG/sn/8ARyHwT/8ACysP/jtH/D439k//AKOQ+Cf/AIWVh/8AHa8V/wCIXX9hT/ohn/l5eIP/AJOo/wCIXX9hT/ohn/l5eIP/AJOoA9q/4fG/sn/9HIfBP/wsrD/47R/w+N/ZP/6OQ+Cf/hZWH/x2vFf+IXX9hT/ohn/l5eIP/k6j/iF1/YU/6IZ/5eXiD/5OoA9q/wCHxv7J/wD0ch8E/wDwsrD/AOO0f8Pjf2T/APo5D4J/+FlYf/Ha8V/4hdf2FP8Aohn/AJeXiD/5Oo/4hdf2FP8Aohn/AJeXiD/5OoA9q/4fG/sn/wDRyHwT/wDCysP/AI7R/wAPjf2T/wDo5D4J/wDhZWH/AMdrxX/iF1/YU/6IZ/5eXiD/AOTqP+IXX9hT/ohn/l5eIP8A5OoA9q/4fG/sn/8ARyHwT/8ACysP/jtH/D439k//AKOQ+Cf/AIWVh/8AHa8V/wCIXX9hT/ohn/l5eIP/AJOo/wCIXX9hT/ohn/l5eIP/AJOoAh/4KWf8FVf2afiH/wAE5/j14f0D4+/B/Wtb174c+IdN07T7PxZZT3F7cz6ZcxQxRIshZneR1XH+1VX/AINZX8z/AIIkfCdt2f8ATdd+bbt3f8Ti95q4f+DX79heKX5fggFHT/kcvEHzf7Oft/WvsH9mr9mvwP8Asi/BnR/h78OfD9n4X8H+H1kSx06CSSVYt8ryud7szszSO7MzMeWagD0OikT7tLQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAf/Z)
Primero, se deben verificar los voltajes producidos por la fuente de alimentación de reserva. Los marcados en azul todavía están allí, el 8 V (verde) es opcional, el + 12 V (rojo) inicia la fuente de alimentación de 35 voltios solo cuando se presiona el botón de encendido. Si todo está bien, reemplace los capacitores C903 y C921. Esto fue traducido por Google.
Hifista.
üdv:
https://elektrotanya.com/showresult?what=LG%20MCD-102&kategoria=&kat2=all
