What capacitor, transistor,and diode can I use to repair a dead Yamaha PSR E353 fuse blown up
it's not working totally
Thanks
I will be grateful for your support
Zaga from Uganda
Did you use the original DC 12 V power supply?Is the polarity OK?
Check the C-E-B voltages at Tr502,check the 5V regulator IC501.
Good luck to repair!
TJ
Hi Zaga,
https://elektrotanya.com/yamaha_psr-e353_sm.pdf/download.html
TJ
