the first problem with this amplifier is turning off for a period of time and turn on again, so i replace the ic and the burned resistor, the problem was solve but the sound output is distordid, i already replaced IC, and two 12v zener diode, But still the 100 ohms resistor get burned, what could be the Main problem?
and there's no input.
Thanks for the help.
red red brown gold
Hello!
https://elektrotanya.com/crate_gx-30m_amp_07s202-01_sch.pdf/download.html
Is it this amp?
Please clarify the type and enter the position number of the faulty, replaced parts.
Regards: Tony
