Hello Seniors,
I’ve an issue with MacBook Pro a1502 it’s not powering up but shows charging first green light then orange i found a broken and missed part but it doesn’t contain any numbers on this because of breaking.
I can tell location of that part “it is located at right of behind the battery terminal there is a middle board holder screw hole on the right bottom of that screw hole’
TIA
