nordmende stradella , when de volume is turn up de sound is terrible. now someone want is the problem?? ton Add new comment Comments 2023, October 12 - 15:32 #525679 torokj 15 years 11 months Hello Ton, Service manual is here I would check and replace C143-C144 10uF elkos,and the output AC 1xx series germanium transistors (Tr8-Tr9)Check the voltages at pins of the transistors. Good luck, tj 0
Hello Ton,
Good luck,
tj
