Yamaha clavinova clp-120 no suena
Tengo un Yamaha clavinova clp 120 y no suena ¿?
Fernando Pérez Urizarna
Fernando Pérez Urizarna picture
Solución:
El problema era que tenia seleccionado los headphones por eso no sonaban las teclas.
Esotech
Esotech picture
Greetings, The Clavinova has a selectable sound engine midi mode that allows it to either be controlled by the (local) keyboard or from the midi in socket. It is very likely that the unit has forgotten it's local setting and has reverted to external midi mode. I haven't looked the manual, but if it has a battery, replace that and check to make sure the sound engine is in LOCAL mode.
https://elektrotanya.com/yamaha_clp-120_sm.pdf/download.html
Cheers
