Hi everyone
so, I accidentally touched one of the controller port pins and shorted it to the ground (or between each other) while ps2 was powered on (don’t ask, it’s a long and not so interesting story), it turned off, but when I powered it on again, 1st controller port stopped working, 2nd works fine
maybe someone knows exactly what components I should check first, fuses, maybe resistors etc, because they are not so easy traceable
thank you very much in advance!
