Rock-ola series b rm16 jukebox unreadeable parts, need schematic
I am looking for a rockola series b rm16 type schematic.
 The tube line up is one 5Z3, two 6B5's and one 6C5. It has
one cut resistor lead and several other open resistors that I
can't read. Any help would be appreciated! Thank You
Chuck Cram
Chuck Cram picture
Kerry, I have a Model B amp carcass with that tube lineup.  Mine's missing the tubes and more, and is not worth trying to restore.  Sometime in the past it had its ecaps replaced but otherwise the components underneath look original.  If you're still looking for correct component values then email me at chuck.cram "at" lightspeed.ca and describe the connection points of your mystery components, then I can identify them for you.  Cheers, Chuck
Ferenc.P
Ferenc.P picture
