Hello, good afternoon, community. I need help with the initial values of the eeprom of the LG CM8450, since the functions of USB1, USB2, Bluetooth, etc. are disabled, only CD, AUX and FM are enabled, please. I need these values from 0P00 to 0P14.
Hello!
Try the initial of the eeprom:
https://ibb.co/8sWHk4S
Thank you for your reply. Yes, I already tried to reset the eeprom with that command and it doesn't work. It's just that its values were changed (with the edit eeprom command), so I will have to enter one by one its 15 values (0P00 to 0P14).
