As dori sa aflu ce fel de tranziztori power mosfet se folosesc in etajul final in clasa D al mixerului amplificat Dynacord Powermate 1000-3.....si eventual de la ce firma, producator.......Va multumesc
Hello...I would like to ask a specialist in the field to tell me what kind of power mosfet transistors are used in the final class D stage of the Dynacord Powermate 1000-3 amplified mixer.....and possibly from what company, producer.......Thank you
ÜDV!
Itt ezt találtam
https://elektrotanya.com/dynacord_powermate_1000-3_1600-3_schematic.pdf/...
From the schematic it looks like they are a pair of FDA59N30 MOSFETs. N Channel, 300 V, 59 A, 0.047 ohm, TO-3P, Through Hole. Made by OnSemi.
Din schema se pare ca sunt o pereche de MOSFET FDA59N30.Canal N, 300 V, 59 A, 0,047 ohmi, TO-3P, orificiu traversant. Realizat de OnSemi.
