I have a Ford Mondeo, 2.0 L from 2010, petrol, sedan with 5 doors.
In reverse gear, the reverse lights don't light.
The reverse switch on the gearbox is OK. The fuses are OK (except if there is one I did not find).
Everything else works.
If the screen wipers are on, and I go into reverse, then the wiper of the back windows switches on, which is normal.
In short, I checked everything and everything seems to be OK.
Dumb question, but what about bulb. Did you check it? Or any contact fault in the bulb socket? Is voltage present in the bulb socket, when shift to reverse? If I remember correctly, the reverse lights are in the inner part of the lamp, in the trunk door. Maybe a damaged wire in/near the grommet (where the wiring loom goes from the body into the door).
