Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Estimados.
El Televisor Philips 32PFL3605/77 LCD tiene una fuente Philips A961A la cual al cunectar el 220v se quema el fusible . Se procede a controlar la placa de la fuente y se reemplazo el mosfet Q602 (transistor en corto), el ic que controla la tensión de entrada (HS01G) y también se cambio el fusible .
Luego de reemplazar estos componentes se realizo una prueba y el tv encendió, realizo un pantallazo y luego comenzó a parpadear y se se apaga la pantalla. Midiendo tensión en la salida para las lamparas en los conectores CN2 y CN3 , al presionar el boton de encendido, la tensión es de 97V, el led testigo de la fuente prende y luego comienza a mermar su intensidad lentamente hasta apagarse, la pantalla parpadea y al cabo de unos segundos la tensión en los conectores CN2 y CN3 queda en 18v y la pantalla queda oscura .
Me pueden ayudar en la reparación , para determinar cual sera el problema que hace que la tensión no se mantenga fija.!
A televízió egykor sztem bga-s javításon esett át. Utána nem tünt fel hogy ez a bordázottság lett volna rajta. Később egy kis része a bal széltől indult kb 1 cm részen most már 5 cm szakaszon van jelen, de az egész tv hátterében fellelhető egy hasonló rajzolat függőleges vonalban. A képet mellékeltem. Elképzelésem szerint az idő a melegedés kezdi a processzort ujra elengedni.Kérném aki találkozott hasonlóval írja meg a tapasztalatait, sikerült e javítani.
Kerestek a fenti TV-vel, áram alá helyezve 3-at villog ütemesen. 3,3V készenlét megvan, előlapi gombokra pittyeg, de nem kapcsol be, távra nem reagál.
A táp át lett méregetve, zárlat nem található benne, szemre is jól néz ki, elkók nem puposak.
Van valakinek tapasztalata vele?
Üdv: Jácint
