PHILIPS ESSENCE HR1356-05 BAR BLENDER PART LIST 2003 SM
HOUSEHOLD - SERVICE MANUAL
106.5 KB
HOUSEHOLD
PHILIPS ESSENCE HR1356-05 BAR BLENDER PART LIST 2003 SM service manual (1st page)
Preview of PHILIPS ESSENCE HR1356-05 BAR BLENDER PART LIST 2003 SM [1st page]
PHILIPS ESSENCE HR1356-05 BAR BLENDER PART LIST 2003 SM service manual (2nd page)
Preview of PHILIPS ESSENCE HR1356-05 BAR BLENDER PART LIST 2003 SM [2nd page]
    PHILIPS ESSENCE HR-135605 BLENDER LIST HR135605 BAR 2003 HR 135605 HR1356 05 HR1356-05
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips gc558/30 gőzálvány klixon....
Lenne egy ilyen ketyere. A kazánon van egy klixon, szét van rohadva.
Ha áthidalom, megy a cucc.
https://www.youtube.com/watch?v=7f5DQYDBrQs
A video 8-9 percénél látszik, kb. ilyen állapotban van a kazán is.
Mit kéne oda rakni kb.?
Kösz
Philips ADG-817 Mosogatógép aszinkron motor bekötése
A segítségeteket szeretném kérni a fent nevezet mosogatógép aszinkron motorját szeretném ki próbálni direktbe rá kötni egyfázisú hálózatra,ha tudtok kapcsolási rajzot küldeni.A motor ohmikus kivezetései három vezetékből áll kék ,fekete,barna.A fekete-kék(30ohm)kék-barna(40ohm)fekete-barna(20ohm)és van egy gerjesztő kondi ami 400V 12uf.Azt szeretném kérdezni,hogy melyik vezetéket hová kössem,hogy tudjam működtetni az egyfázisú hálózatról.Előre is köszönöm a segítséget.
PHILIPS HR6835 porszívó motorja nem megy, tud-e valaki tanácsot adni a javításhoz? Megoldódott, 10 cm tápkábelt levágtam
Tisztelt Kollégák, a fenti porszívó nem megy (a vízszivattyú lámpa sem világít). Mivel 10 perc alatt nem találtam meg a szétszedés mikéntjét (a google sem segített), inkább a rutinosabb kollégákhoz fordulok segítségért. Közben itt találtam 6841 SM-et, most azt nézem. köszönettel bbgames
