PHILIPS HD4634C
HOUSEHOLD - SERVICE MANUAL
208.1 KB
HOUSEHOLD
PHILIPS HD4634C service manual (1st page)
Preview of PHILIPS HD4634C [1st page]
PHILIPS HD4634C service manual (2nd page)
Preview of PHILIPS HD4634C [2nd page]
    PHILIPS HD-4634C HD4634C HD 4634
908621 Philips FC6405/01/F/A forgókefe
Ti ezt hogy javítjátok, egyáltalán próbálta már valamelyikőtök? Csak a csere segít?
Nem tudom mitől, de eléggé le van darálva. Láttam tízezerért, meg most itt a linken van tök olcsón. Erről az oldalról viszont én nem merek rendelni.
https://www.fruugo.hu/porszivo-hengerkefe-kefek-philips-fc6400-6401-fc6402-fc6404-fc6405-fc6408-6409-fc6162-fc6164-fc6166-fc6168-fc6169/p-287893883-642419757?language=hu&ac=KelkooCSS&asc=pmax&gad_source=1&gclid=CjwKCAjw3NyxBhBmEiwAyofDYXqiDF9LqrOTcZ5yMbcKthLi3K_ZLB9Y4rDY0YgG2CNn2bJxiPVyTBoC3yIQAvD_BwE
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips GC9220 gőzállomásos vasaló kazán hőfok érzékelő értéke
Van egy ilyen gőzállomásunk. Nem termeli a gőzt, pontosabban csak alig gőzöl. Fűtést bekapcsolja pár másodpercre majd le. Első körben, még meleg állapotban megmértem a hőfok érzékelő (NTC) ellenállást, 123 kOhm körülit mértem. Majd mikor kihűlt újra megmértem, de már szakadást mutat.. Hosszas kutakodás után megtaláltam milyen kell bele, de konkrét értéket nem adnak meg sehol, még a szerviz manuálban sem, csak annyit, hogy 10-100 kOhm között van.
Itt látható hogy néz ki maga az érzékelő:
https://tr.ifixit.com/Guide/Philips+Pressurised+Steam+Generator+Iron+GC8220+and+Similar+Models%27+Temperature+Sensor+(NTC+Thermistor)+Replacement/95767#s177282
Esetleg valaki nem szerelt mostanában ilyen gépet?
Ilyen egyébként, de sehol sem rendelhető:
https://ersatzteildirect.de/de/Philips-Thermistor-fuer-GC9220-GC9230-GC9235-GC9245::6389.html
Üdv.: nils
Philips HI5916 gőzölős vasaló proci zálat !
Sziasztok ! A markolatban  elhelyezett  elektronikában található jelfogó megolvadt és az első kis panelon lévő proci zárlatos lett SH 79F084AL felirattal ! Az ALIN beszerezhető viszont nem vagyok igazán járatos a témában a kérdés az ezek a procik fel vannak  programozva ? Üdv!
