PHILIPS HD7825-60 HD7825-61 HD7825-66 COFFEE MAKER SENSEO
COFFEE-MACHINE - SERVICE MANUAL
892.9 KB
COFFEE-MACHINE
PHILIPS HD7825-60 HD7825-61 HD7825-66 COFFEE MAKER SENSEO service manual (1st page)
Preview of PHILIPS HD7825-60 HD7825-61 HD7825-66 COFFEE MAKER SENSEO [1st page]
PHILIPS HD7825-60 HD7825-61 HD7825-66 COFFEE MAKER SENSEO service manual (2nd page)
Preview of PHILIPS HD7825-60 HD7825-61 HD7825-66 COFFEE MAKER SENSEO [2nd page]
    PHILIPS HD-782560 MAKER SENSEO HD782560 HD782561 HD782566 COFFEE HD 782560 782561 782566 HD7825 60 61 66 HD7825-60 HD7825-61 HD7825-66
Relevant COFFEE-MACHINE forum topics:
Philips FC8774 / 01 robotporszívót nem lehet bekapcsolni
Sziasztok, hozzám került a tárgybeli gép. Akku, főkapcsoló rendben. SW101-SW102 indítógombokon már nincs feszültség: Merre induljak? Rajzot, ötletet nagyon köszönök!
Laci
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips XSmall HD8743 kávéfőző szivattyúcsere után hibát jelez
A szivattyút egy azonos teljesítményű másik ULKA-ra cseréltem, ami tesztelten működőképes. Összerakás és újraindítás után a jobb alsó LED a vezérlőpanelon lassan villog, ami általában a kávézacc fiók kontakthibáját szokta jelenteni, de itt az ajtó zárása rendben van.
Mi lehet a hiba oka?
Philips HD5730 A központi egység nem áll meg alul, illetve 4-6 mm-l lejjebb áll le.
A fent jelzett gép a címben jelezett hibát produkálja. A kpe nem áll le ahol kellene, ezért a rögzítő csövét letörte. A végállás kapcsolón, állítási lehetőséget nem látok, annak helyzetét  módosítani nem tudom. Másik vázat már szereztem hozzá, azon van ugyanis a KPE rögzítő csöve ami a túlfutás miatt leszakadt. Köszönöm a figyelmet.
