PHILIPS HQ406
HOUSEHOLD - SERVICE MANUAL
220.3 KB
HOUSEHOLD
PHILIPS HQ406 service manual (1st page)
Preview of PHILIPS HQ406 [1st page]
PHILIPS HQ406 service manual (2nd page)
Preview of PHILIPS HQ406 [2nd page]
    PHILIPS HQ-406 HQ406 HQ 406
Philips GC 4630 vasaló nem melegít (megoldva)
A másik....
Relé kocogtatásra indul, tehát a relé rossz.
De ez meg ki van öntve, köszönjük szépen :(
Philips Saeco HD8745 kávégép hibalámpa gyorsan villog. Megoldva.
Szép estét.
Szívesen odaadom ha valaki javít ilyet Budapesten vagy környékén.
Philips gc558/30 gőzálvány klixon....
Lenne egy ilyen ketyere. A kazánon van egy klixon, szét van rohadva.
Ha áthidalom, megy a cucc.
https://www.youtube.com/watch?v=7f5DQYDBrQs
A video 8-9 percénél látszik, kb. ilyen állapotban van a kazán is.
Mit kéne oda rakni kb.?
Kösz
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
