PHILIPS QC5015
HOUSEHOLD - SERVICE MANUAL
837.3 KB
HOUSEHOLD
PHILIPS QC5015 service manual (1st page)
Preview of PHILIPS QC5015 [1st page]
PHILIPS QC5015 service manual (2nd page)
Preview of PHILIPS QC5015 [2nd page]
    PHILIPS QC-5015 QC5015 QC 5015
Philips gőzös vasaló mágnesszelep tekercs
Sziasztok ! Szakadt lett a képeken látható vasaló gőzállomás mágnesszelep tekercse.230 V-os, 17 VA-es, a "tengely" amiről levettem, 13 mm átmérőjü.. Mérete 35X35X35-ös kocka nagyjából.Lényeges, hogy gőzt kapcsol, ezért 150, illetve 120 Celsius fokosnak kell lennie.Ha véletlenül valakinek lenne egy ilyen tekercse a sufniban. szívesen megvenném. Esetleg egy hasonló komplett 230-as gőzre való mágnesszelep is szóba jöhetne..Köszönöm szépen a válaszokat. Üdv.: Balatinecz Sándor
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Saeco/Philips Minuto kávégép javítás
Van nálam 2 db Philips Minuto kávémasina. A két lányomé. Én vettem nekik ajándékba pár éve, de nem egy megbízható masina.
Az egyik darálójával van gond. Megy a daráló motor, de nem darál. Hogy lehet szétszedni a darálót.
Az SM fent van a tanyán és próbálom értelmezni.
A másiknál elektronika hiba van. A vezérlés tápja az alaplapon van. 2A bizti stabilan kimegy rajta akkor is ha a panel az asztalon van már.
Gratez egyenirányító után puffer kondi van. FSQ0265R a kapcsolóeszköz. Gyanítom ez dobta fel a talpát. Aki javított ilyet az talált más elfáradt alkatrészt is a környékén?
FSDM0265RN és a nagyobb  FSDM0365RN van a HQ-ban. Vegyem a 265-öt?
Esetleg egy kapcsolási rajz valakinél?
Üdv Feri
Philips SCH580 Ultrahangos párásító nem működik (nem párásít).--Megoldva!--
Üdv mindenkinek. A fent nevezett készülékkel az a probléma,hogy nem párásít. A panelre rámegy a tápfeszültség de semmi égést púposodást nem látni a panelen. Mi mehet ki ebben? A motor forog. Javítható? Még nem szedtem szét ilyen típusút? Válaszotokat és segítségeteket köszönöm. Üdv:Gábor Csatolok pár képet. Kép1 Kép2 Kép3 Kép3 Kép4 Kép5 Kép6 Üdv:Gábor
