POWER SUPPLY FOR PREAMPLIFIERS-REVISION A-
53.7 KB
Looking for similar power manual?
    POWER SUPPLY FOR REVISION
advice for repairing a DBX BX3 power amp (fused power transistor)
i have a very nice vintage DBX BX3 amp on which at least one channel fused.
power transistors literally burned down.
it is a very nice piece of hardware (4 channels with BTL capability 4x125W or 2x300W)
I would like to fix it myself. Having an electronic engineering degree, i think I should be able to undertake that venture but I never practiced (i've been in software for the last 40 years...)
So I need some guidance on the methodology to diagnose and track what went wrong.
I do have a scope, signal generator and I guess all required tools, as well as the schematics of the amp.
what I need is some help on locating the key parameters to measure and how to incrementally explore the different stages of the amp to find the faulty sections.
I guess I need to isolate the different sections of the amp but then, what ?
any help and advice will be highly appretiated.
Power Suplly board standby Onkyo TX-NR727 -Nice day, I need to buy in good condition, price? to Slovakia.Dakujem very nice.
Demand:Prosím Vás, máte na predaj tento vyhorený plne funkčný pohotovostný zdroj k onkyo TX-NR727 na Slovensku. Dakujem Minko.Poprosim a foto.Urgentne.
https://mail.google.com/mail/u/0/#inbox/DmwnWtDsVgFgtSxMCkwLfVxfzbmbCrWVcxxFsfCLSxZBprvlGtmLKJcDJdRvvPWSXFtRjlhJvpZb?  projector=1&message. EMAIL: milan.gebrlin@gmail.com
[BEAMER/PROJECTOR] SONY VPL-SERIES POWER UNIT RPS9522M-02 / 1-474-223-11 SCHEMATIC DIAGRAM RUBYCON COOPERATION
hi i am looking for the schematic diagram of a sony power unit.
Sony VPL-fx35/fh31/fhz55/f420hz/f425hzl  power unit RPS9522M-02
or from part number 1-474-223-11
i hope somebody can help me out or if you have it partly from reverse enginering please upload or let me know.
Denon DRA-F107 - Dead, no power
Hi to all. Unit arrived dead with no power. The problem is with switching power supply. I checked most of the parts, no faulty found. Unable to check PWM ICs. To determine which one has the problem, Service Manual is more than important and necessary. I would appreciate if someone of you can help me find it or send it to me. Thanks in advance for your kind attention and help. Regards from Greece, John
