Külföldi út előtt állok, kéne egy navigációs készülék. Ki milyen típust, gyártót ajánl, amivel nincsenek hardveres és szoftveres gondok, megbízható, nem megy tönkre a garancia lejáratának másnapján? Nem kell mindentudó, csak alapkészülék, elfogadható áron, Európa térképpel. Mik a jobb márkák és melyeket kell kerülni?
A válaszokat előre is köszi, üdv:
Gábor
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Egyik volt kollégánk bioptron lámpáját javítom.
A tápja már megy de elhalálozott a mikrovezérlő a vezérlő paneljén a programmal együtt.
Egy pic16c54 volt benne PKLAMP1.0 felirattal.
Ha esetleg valakinek meglenne a programja vagy bármi megoldás hozzá hogy hogyan tudnám feléleszteni a vezérlőjét nagyon hálás lennék érte.
Köszönöm előre is.
Tegnap cseréltem ennél a boxnál /THD2880/ antennát de a vételi érzékenysége egy katasztrófa, 80%-on felüli jelnél még szaggat, másik irány, 91-2% jel és minőség, itt már működik csak a feliratozást nem tudom eltüntetni. Menü-OSD beállítások-felirat megjelenítése ki-visszakapcsol és megy a felirat. Ha belenézek a menübe a felirat be van kapcsolva, kikapcs után hiába lépek ki akár a menü akár az exit gombbal a felirat ott van a képernyőn és visszanézve a menübe be van kapcvsolva.
A tulaj viszont állítja hogy az új antenna lehet a hibás mivel a régivel nem volt felirat sehol csak néhány adó nem jött vagy gyakran szaggatott a kép.
Csináltam többször gyári beállítást is de nem tűnik el a feliratozás-help.
