SEEBURG L100
712.9 KB
Looking for similar seeburg manual?
    SEEBURG L-100 L100 100
Lg MP3 AS autórádiós cd.. Mechanikát keresnék..ujat,vagy használtat akár ,ami működik...tip:LAC-M1600R
Sziasztok! Lg MP3 AS autórádiós cd.. Mechanikát keresnék..ujat,vagy használtat akár ,ami működik...tip:LAC-M1600R Köszi! Üdv:Sparco
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Phonic keverőpulton az effekt nem fogadja el a select gombot
Egyik barátomé ez a Phonic AM442D keverőpult, azzal keresett meg hogy az effekt nem működik. Nem volt kijelzés sem.
Szétszerelés után a kijelző szegmensek egy része visszajött, de hiányosan. A kis fekete csatlakozó volt kontakthibás, tisztítása után minden rendbejött.
A kezelőgomb encodere stabilan működik, de sajnos a gomb lenyomása (select) után is villognak a tizedespontok és nincs jel az effekt kimenetén. Ha jól emlékszem a program kiválasztása után ha lenyomom a gombot normális esetben a pontok villogása megáll és ezután működik.
Csináltam képet a panelről. Az encoder és a select gomb a 63FIV3T feliratú ic-re van bekötve, a select a 14 -es lábára csatlakozik. 3.3V feszültség van a lábon, a gomb lenyomásakor rendesen testre (0,0V)kerül.
Lehet hogy a hibás csatlakozó miatt a tápellátása ingadozott, szakadozott. Talán ettől hibásodott meg. Ram van rajta, de flash ic-t nem láttam. A fekete szövet alatt csak néhány ellenállás van, nincs oxid alatta. A tápja 5V, stabil, zavarmentes. A két stabilizátor 3.3V és 1.25V feszültséget állít elő, ez is rendben van.
A keverőn az egyik master poti ropog kicsit, de minden más jónak tűnik. A kis gombokat próbáltam mindenféle variációban, de nem ettől van letiltva a select.
Ha valaki találkozott ilyennel vagy ötlete van, kérem segítsen kicsit mert nincs több ötletem.
Pioneer vsx709-ben hangero enkoder javitasa lehetseges? Megoldva.
Sziasztok. Adott egy Pioneer VSX709 tipusu erosito, aminek a hangero enkodere rakoncatlankodik, fel-le valtozik, ha tekerem a gombot. Valaki szedett mar szet ilyet? Esetleg meg is javitotta? Udv. "FONTOS! Olyan fórum téma nevet válassz, ami beszédes, minél pontosabban illeszkedik arra, amivel kapcsolatban írsz. Egy lehetséges jó elnevezés pl: ORION LCD PT26S chassis 17MB12-2, a tápja nem indul Az nem elég, hogy pl: "LG LCD-TV" vagy "HP laptop" és hasonlóak. Illetve érdektelen, nem releváns információt se tartalmazzon a cím! A helytelenül elnevezett topik felfüggesztésre, majd 48 óra után törlésre kerül! Felfüggesztett állapotban nem tudnak mások addig hozzászólni, amíg ki nem javítod a címet. A hibás cím utólagos javítása (48 órán belül) a "Szerkesztés" fülre kattintva végezhető el."
