SUPERPHONE SUPER-M1043U 1942 SCH
Type: (PNG)
325.2 KB
Looking for similar superphone manual?
    SUPERPHONE 1942 SUPERM 1043 SUPER M1043U
kod olvasas
sziasztok--azt szeretnem kerdezni,van-e közületek valaki,aki audi chorus kodját sikerült megfejtenie? ennek motorola 68hc05 vagy 68hc705b32 procija van,es nincs külön memoriája...es van rajta egy vonalkodos cimke es az van meg rá irva radionr:24312--ennek estleg van valami köze a kodjához? es van még egy audi concert rádio,de annak van egy 25c160 tipusu memoriája--ennek a kodjat hogy lehet megfejteni? köszönöm...
Samsung MAX N54 torz hanggal
Sziasztok! Javítok egy fent leírt típusu minihifi-t! A készülék torzan és halkan szól minden forrásról. A végfok egy STK 402-090, amire már torz jel jut. Tudna valaki segíteni esetleg valami dokuval, ötlettel? Az STK 100% jó, kipróbáltam külső jelforrással. Előre is köszi a segítséget! Gabi
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Technics SU 8055
Kedves szakik, kaptam egy a címben említett erősítőt, amelynek első megitélésre végfog gondja volt megrendeltem bele a 2db új végfokot és olyat produkál hogy bekapcsolás után elkezd búgni majd kb 10mp eltelte után a erősebben kezd és a hangszórók membránja kifelé mozdul, tovább nem mertem bekapcsolva hagyni, de hangot nem ad ki hiába kötöttem a bemenetére jelet, nem találkoztam ég efféle jelenséggel, ha valaki tudna segíteni ebben azt szivesen venném.
