I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Tiszteletem!
Segítséget szeretnék kérni nálam tapasztaltaktól.
A készülék nagyon koszos volt belül.
Tisztás után, még mindig nem olvasta be a lemezeket. A KSS150-es lencséjét és a lencse alatti kimeneti lencsét megtisztítva már a TOC -ot beolvasta, de lejátszani nem volt hajlandó.
Vettem a bátorságot, és szétszedtem a lézer egységet. Ez a teljesen függőleges felépítésű változat. Az optikai utat egy levehető lemez zárja. Levettem, kifújtam levegő spray-jel. A mozgó lencse egységet 2 db csavar tartja. Levettem és kitisztítottam a lencsét belülről is. Organikus, 0 oldószert tartalmazó eljárással.
Nos, innentől gyárira visszaállított lézer árammal tökéletesen lejátszotta a lemezeket, DE...
Írott lemezt hiba nélkül. Ugrás a számok között, beletekerés, nem probléma. Sem az első, sem az utolsó számnál.
Ellenben gyári CD-t vagy be sem olvassa, vagy lejátsza, a lemez 1/3-ig még az ugrálás és a tekerés is megy, de aztán már nem. Ha pl a 6. számról a 7. re akarok ugrani, akkor le-fel szaladgál a kocsi, ugrálnak a track számok, meg az idő, időnként bele reccsen egy kis hangrészlet, aztán vagy betalál véletlenszerűen egy korábbi szám elejére, közepére, vagy közli, hogy nincs lemez, és leáll.
Nem értem, ezmiez...
Szerviz manuálom sajnos nincs hozzá, nem találok a net-n, max kamugyanús oldalakon fizetöset.
Ha fordítva viselkedne, még érteném (gyári hibátlan, írott zagyva), de így nem fogom...
Előre is köszönöm!
Gábor
Üdv mindenkinek!
A címben említett erősítőn dolgozok, alaposan szét van bombázva. Kibontottam belőle egy marék hibás alkatrészt, ezeket pótolnám. Leginkább a végfokokkal vagyok bajban, hogy mivel helyettesítsem, mert több helyen olvastam, hogy ajánlatos lenne párba válogatott alkatrésszel dolgozni. (erősítőt még soha nem javítottam ilyen mélységekben) Eredetileg passzolok, hogy milyen végfokokkal szerelték, BD249C/BD250C kombó dolgozott benne, amit utólag építettek bele. A manual 3 fajtát említ beépíthetőnek. 2SC3181/2SA1264 kombó, beszerezhető, de szerintem párba válogatásra nincs lehetőség.
Kereszt referencia katalógus "hozza" a 2SA1186/2SC2837 kombót, ami a hq-ban kapható is, párba válogatva. Ezzel a párossal vajon pótolható?
Köszönöm mindenkinek előre is a segítséget.
The file is: marantz_pm493.pdf
And I put under: audio, power amplifier, service manual
The forums not are in English, I don't understand the titles and I can not traslate
