Került hozzam ez a fent emlitett csoda (a Moszkvai Olimpiara fejlesztettek-szallitottak, de gondolom mas közvetiteseken is megallta a helyet), hogy rendbe tegyem, leheljek bele valami életet: jelenleg "se kép se hang", de man a tàpnàl megakadtam....
Isneri valaki a ketyeret, tudna sugni, hogy mikent juthatok tovabb?
NAGY köszönetem elöre is!!
üdv, Kari
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Valamelyik nap belehet kapcsolni, valamelyik nap nem, amikor bekapcsolódik akkor egész nap jó minden--ezt mondja a tulaj. Nekem nem sikerult még bekapcsolnom.
Csak a piros stby led világít, display-en semmi nincs. Gomb megnyomásakor sem erôlködik ugyanugy világit a piros led.
Van külön stby trafója ez ad +5V-ot, meg +10V-ot! ad 12V-os relé egyik lábára, a GND-t a relé másik lábára egy kis npn tranzisztor kapcsolja rá ha a processzor ad neki valoszinu +5V-ot, de 0V van a processzor MN101C15F kimeneti 52.lábán (POUT). A relé kapcsolja a nagy trafó primerjére a 230V-ot.
A gombok jók- kilehet huzni a szalagkabelt és akkor 2Mohm-os határon is szakadás van. Gombok ellenállást kapcsolnak sorba az 5V-ra, a stby gomb 19kohm-ot kapcsol rá és 3.3V lesz amíg nyomom a gombot.
Még nem mértem rá a kvarcra..
