BELMONT RADIO CORP. 6D127 SCH
61.8 KB
Looking for similar belmont manual?
BELMONT RADIO CORP. 6D127 SCH service manual (1st page)
Preview of BELMONT RADIO CORP. 6D127 SCH [1st page]
BELMONT RADIO CORP. 6D127 SCH service manual (2nd page)
Preview of BELMONT RADIO CORP. 6D127 SCH [2nd page]
    BELMONT RADIO CORP. 6D127 127
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Angol autórádió előerősítő hiba(?).
Sziasztok! Hoztak hozzám egy jobb kormányos kocsit, melyben nem szólt a rádió. Pontosabban csak a rádió előerősítő vizsgálata a feladat jelenleg. Mértem az erősítését 1 MHz-en + 100MHz-en és csak 6 DB-t erősít mindkét frekvencián. Két külön erősítő van a panelon a két sáv (KH + CCIR URH) erősítésére és a kimenet előtt van közösítve. A DC munkapontok szerintem jók, az erősítők kivezérelhetők, áramfelvétel kb. 70mA. Lehet, hogy csak ilyen keveset erősít egy gyári előerősítő? Egy alkatrészt nem ismerek, négy lába van, típusszáma: 7130. Teszek fel róla két képet. Egy-egy oldalon a két lába között pár ohmot mérek csak, mintha tekercs lenne. Vajon mi lehet a tokban? Üdv.: Kumi
Technics rs b605 deck,kopott a fej
Kopott a fej a fentebb emlìtett kazettàs magnóban,kiszeretnèm cserèlni de nem tudom hàny ohmos kelhet bele, mèrtem ès kèt èrtèket kaptam a fejen 318 ès 298 ohmot.Szeretnèk utànanèzni hogy tudnèk e hozzà venni,csak nem tudom a mèrt èrtèkek alapjàn hogy is keresgèljek!SM-ben sem talàltam ide vonatkozó èrtèket,szivesen fogadom tanàcsaitokat hogyan is kezdjek neki a fejcserènek!
300W-os erősítő 20KHz-re (lezárva)
Üdv Szükségem lenne egy 300W-os erősítőre aminek 18KHZ-22KHz tartományban kellene működnie. Tud valaki ilyet hol lehet kapni, esetleg kapcsolási rajz az építéséhez? Balázs
