hi everybody,
the washing-machine in object doesn't start the program!
i checked the core board and there was a bad capacitor of 0.047uf, i changed it and the washing machine has worked.
after a few of days the whashing-machine again doesn't work!!!
i downloaded here the service manual and i have seen that he model of the core board is : gias 41003726
where i can find the logical scheme of this core board??
can you suggest what i can check on the core board for my problem??
if i select any program it doesn't start!
thx
Hi !
This machine is fitted with MDL platform board. Usualy problem the 1,5UF 275V MKP X2 capacitor, and the 100uF 25V capacitors in the power suply. If the board is OK check the carbon brushes in the washing motor, or the common problem the program selector switch contact failure.
Hi
I changed these capacitors.
the carbon brushes and the selector are OK!
The problem is again present!
Is it possible that the problem is the processor?
Hi!
Yeah maybe, but still check your peripherals!
Felesleges rajz,és szerszám nincs,csak ritkán használt.
elwo
what i can control?
can you help me?
i tried with a new selector, it doesn't work.
can you tell me the procedure to load the eprom?
which histruments i need?
on the site i found the procedure?
thx
Hi!
So I wrote the check to the peripherals!
What does this have to write to the EEPROM?
Maybe I should not get involved more!
elwo
sorry...
i asked your help to understand which peripherals i have to check and if you know also how to wirte to the eeprom..only for study and not for my problem.
sorry for my bad english but i am italian
sorry ...
Peripherals.
Motor carbon brushes.
Drain pump.
Water valve.
Pressure switch, thickener tank .
If these tried work remains in the control.
EEPROM write ..
Well it is not because it's going to talállni, there's not a lot érteme írogatni.
By the way, it really is rarely break down, and are hence not the 99% ..
Elwo
elwo
HI!
:-D
elwo
I solved the problem!
I changed the core board.
The processor wasn't good.
Now works!
THX to all
Hi Alex,
congratulations! :oke:
Kari
Hi!
Such manuals are not specific servie, no other place is not really going to find.
Try to check the peripherals, again, far from being for sure whether the control is bad!
Elwo
Needless drawing tool and is only rarely used.
thx a lot.
tomorrow i will try to find the problem i hope! :-)
