FIGYELEM! Olvasd el az alábbiakat!
Ezek az információk csak szakemberek számára hasznosak!
Súlyos és maradandó károsodást lehet tenni a készülékekben, ha nem vagy jártas azok beállításában, javításában. A belépés GARANCIAVESZTÉSSEL jár!
A szerviz menü csak egy lehetőség bizonyos működési paraméterek beállítására/hangolására, az elromlott készüléket nem lehet ezen keresztül megjavítani!!
Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
The buttons on top of the remote are set to TV & VCR respectively.
Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
The main service menu will be displayed with choices #1 through #9.
Press one of the corresponding number keys to enter that menu.
Use the {CH+} {CH-} buttons to navigate within a menu.
Use the {VOL+} {VOL-} buttons to change the values.
Use the {MUTING} button to memorize the changed value.
Use the {BACK} button to exit the service menu.
Turn the TV on.
Using the remote control:
Press the {INFO} & {MUTE} buttons at the same time.
The Service Menu will be displayed
Use the number keys to select the category.
Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don't have category selection.
Use the {CH+} {CH-) buttons to select item to be adjusted.
Use the {VOL+} {VOL-} buttons to change values.
Press the {INFORMATION} button to exit.
Turn the TV on.
Press {DISPLAY} & {PIC MODE} buttons at the same time.
Use the {UP} {DOWN} buttons to enter a category.
Use the {LEFT} {RIGHT} buttons to select items.
Use the {UP} {DOWN} buttons to change values.
Press the {DISPLAY} button twice to exit.
Press the {MENU} button.
Select "Clock Set".
Set clock to 3:21 AM and press "Start Clock".
While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
The Service Menu will come up.
Use {UP} {DOWN} to select items.
Use {LEFT} {RIGHT} to change values.
To exit, turn the TV Off.
Kedves pihe!
Majd kiderül ezzel jót, avagy rosszat tettél: mivel a működésképtelen alaplapból is kiolvasom mikor volt "lost service activ controll" (ez vonatkozik a SONY-ra is!
Ha a kedves tulaj nem tud felmutatni arra az időszakra garanciás munkalapot (de még az sem kell, mivel a belső rendszerben rögzítve vannak) onnantól buktak a garanciális feltételek! Természetesen egy ilyen cselekményből okozott hibát nem vagyunk hajlandóak szoftveresen javítani (az esetben sem, ha ez lehetséges lenne).
Várom a Panasonic, LG, SAMSUNG, PHILIPS, stb kódokat is! :rohog: :oke:
Szia,
Jön majd a többi is, csak nem volt több időm rá tegnap. :oke:
A garanciavesztésről a figyelmeztetés valóban kimarad, pótoltam.
Szervusz M.Gábor!
Ezeknek a készülékeknek sem tart örökké a garanciája!
Sok esetben a "fizetős" szakszervízt nem tudják megfizetni a kedves ügyfelek, és ilyenkor a kissebb költségvetéssel üzemelő, tehát sokszor olcsóbb javítóműhelyt keresik fel. Ez az anyag, a címben írt figyelmeztetéssel együtt, igen hasznos, ezeknek a műhelyeknek. Természetesen vállalniuk kell, az anyagi kockázatot is, ha valami mégsem sikerülne! :-)
exGelkás
Szia exGelkás!
Előre lezsírozom: nem fog sikerülni! , hogy miért?? ezt sajnos nem vagyok publikus közölni, de EZ VAN! :oke: :rohog: :king:
Szervusz M.Gábor!
Azért valamilyen szinten, én is megjósolhatom. A csapnivaló minőségük miatt, gar idő után, egyszerűen E-szemétté alakulnak át! Még egy vacak üveggömb sem kellett hozzá! :-)
exGelkás
Mondod TE, én ennek csak azzal a megállapítással ellent mondanék: "anyag van"
Ja, hogy nem tudják kicserélni-feltölteni? (az utóbbi esetig el sem jut a dolog, mivel túlmelegítik és tönkre is megy mire fel lehetne flash-elni)
Veszünk egy ÚJ modult a SINI-től?-hát az sajna "üres" -ott már kifizettük a: (márkaszerviz által kicserélt-feltöltött modul árát 2,5 szorzóval)-EZÉRT sajnos az ott kifizetett ár feléért vagyok csak hajlandó szóba állni az ilyen esetekkel!
Mindenkinek sok sikert kívánok! :D
